大家帮我看看SPI的SD卡初始化。
3302|7
 楼主| kyzb001 发表于 2010-11-20 11:46 | 显示全部楼层 |阅读模式
#include <stdio.h>
#include "NUC1xx.h"
#include "DrvSPI.h"
#include "DrvGPIO.h"
#include "DrvSYS.h"
#include "DrvUART.h"
static void pfnSDCARD_Delay(uint32_t nCount)
         uint32_t i;
         for(i=nCount;i>0;i--)
                   __NOP();
void UARTSPI_INIT()
       STR_UART_T sParam;
       UNLOCKREG();
       /* Set UART Pin */
       DrvGPIO_InitFunction(E_FUNC_UART0);
       /* UART Setting */
       sParam.u32BaudRate   = 115200;
       sParam.u8cDataBits   = DRVUART_DATABITS_8;
       sParam.u8cStopBits   = DRVUART_STOPBITS_1;
       sParam.u8cParity   = DRVUART_PARITY_NONE;
       sParam.u8cRxTriggerLevel= DRVUART_FIFO_1BYTES;
       DrvSYS_SelectIPClockSource(E_SYS_UART_CLKSRC,0);
       DrvUART_Open(UART_PORT0,&sParam);
       DrvSYS_SetOscCtrl(E_SYS_XTL12M,1);
       SYSCLK->CLKSEL0.HCLK_S=0;
       SYSCLK->CLKDIV.HCLK_N=0;
       if(DrvSPI_Open(eDRVSPI_PORT0,eDRVSPI_MASTER,eDRVSPI_TYPE1,32,FALSE)==E_SUCCESS)
                   printf("\nOpen SPI0 is Success.\n");
       DrvSYS_SetIPClock(E_SYS_SPI0_CLK,1);//设置时钟
       DrvGPIO_InitFunction(E_FUNC_SPI0); // enable SPI funztion and pin
       DrvSPI_Open(eDRVSPI_PORT0,eDRVSPI_MASTER,eDRVSPI_TYPE1,8,FALSE);//打开SPI0
       DrvSPI_DisableAutoSS(eDRVSPI_PORT0); //关闭自动片选
       DrvSPI_SetSlaveSelectActiveLevel(eDRVSPI_PORT0, eDRVSPI_ACTIVE_LOW_FALLING);//设置模式
       DrvSPI_SetEndian(eDRVSPI_PORT0, eDRVSPI_MSB_FIRST);   //MSB传输
       DrvSPI_SetClockFreq(eDRVSPI_PORT0,300000,300000); //设确定时钟
       pfnSDCARD_Delay(0x20000);  //延时
       //DrvSPI_SetClockFreq(eDRVSPI_PORT0,12000000,12000000);
uint32_t SPI_WriteByte(uint32_t val)
       uint32_t auSendSPIData[2];
       uint32_t auReadSPIData[2];
       auSendSPIData[0]=val;
       auSendSPIData[1]=val;
       if(DrvSPI_BurstWrite(eDRVSPI_PORT0,&auSendSPIData[0])==FALSE)
              printf("\n\nWrite Data is fail\n\n");
       while(DrvSPI_IsBusy(eDRVSPI_PORT0));
       DrvSPI_DumpRxRegister(eDRVSPI_PORT0,&auReadSPIData[0],1);
       return auReadSPIData[0];
int32_t SD_SendCommand(uint32_t cmd,uint32_t arg)
       int32_t R1 = 0;
       int32_t Retry   = 0;
       DrvSPI_ClrSS(eDRVSPI_PORT0,eDRVSPI_SS0);
       DrvSPI_SetBitLength(eDRVSPI_PORT0,8);
       SPI_WriteByte(cmd|0x40);   //分别写入命令
       DrvSPI_SetBitLength(eDRVSPI_PORT0,24);
       SPI_WriteByte(arg);      //数据段第4字节
       DrvSPI_SetBitLength(eDRVSPI_PORT0,16);
       SPI_WriteByte(arg);      //数据段第3字节
       SPI_WriteByte(arg);       //数据段第2字节
       SPI_WriteByte(arg);          //数据段第1字节
       if(cmd==0)
               SPI_WriteByte(0x95);         //CRC效验和
       else
               SPI_WriteByte(0xff);
       R1=SPI_WriteByte(0xff);
       while((R1=SPI_WriteByte(0xff))==0xffffffff)//等待响应
                printf(" %d ",R1);
                if(Retry++ > 200)
                printf("\n\nCommand Write is time out\n\n");
                          break;//超时退出
       printf("Command : 0x%x ",R1);
       DrvSPI_SetSS(eDRVSPI_PORT0,eDRVSPI_SS0);
        return R1;
uint32_t SD_RESET()
        uint32_t  i;
        uint32_t  Retry;            //重复次数
        uint32_t  R1=0;
        DrvSYS_Delay(10000);
        Retry=0;
        do
              for(i=0;i<10;i++)
              SPI_WriteByte(0xff);  //发送74和命令周期
              R1 = SD_SendCommand(0,0);//发CMD0命令
              Retry++;
              if(Retry>20)
                     printf("11 Time is out ");
                     return 1;   //超时退出
         }while(R1 != 0x01);      //等待IDLE命令返回
/*      Retry = 0;
         do
                  for(i=0;i<100;i++)
                  R1 = SD_SendCommand(1, 0);         //发Active命令
                  Retry++;
                  if(Retry>254)
                         printf("22 Time is out ");
                         return 1;            //超时退出
         }while(R1==0);
         return 0;
int32_t main()
           uint32_t R1=1;
           UARTSPI_INIT();
           SD_RESET();
           if(R1)
                  printf("Init is Fail");
            else
           printf("Init is success");
           while(1){ }
[/code]要求一点都不高,发个0  能返回和0x01,SD卡进入SPI模式就行。关于NUC1xx的SPI真是一头雾水啊!
hotpower 发表于 2010-11-20 13:27 | 显示全部楼层
俺也想知道,没搭硬件。
华邦有自带的两个sd卡的例程,应该用它先调试,通过后再简化。
 楼主| kyzb001 发表于 2010-11-20 14:25 | 显示全部楼层
华邦的例子是SPI2的。100,64脚的只有2个SPI    所以我改成SPI0的。结果显示初始化不能完成。
 楼主| kyzb001 发表于 2010-11-20 15:24 | 显示全部楼层
DSTATUS disk_initialize (
        BYTE drv                /* Physical drive nmuber */
        DSTATUS sta;
        GPIOD->PMD.PMD12=1;
        GPIOD->DOUT&=0xEFFF;
        while((GPIOD->PIN&0x2000)!=0);
这个是例子中  打开SDCARD之前的设置。   不理解啊
hotpower 发表于 2010-11-20 15:46 | 显示全部楼层
PD.12=0打开PMOS管给SD卡供电PD.13=0有SD卡插入,无卡死循环
hotpower 发表于 2010-11-20 16:31 | 显示全部楼层
如果只接了四线,可以屏蔽这些语句
 楼主| kyzb001 发表于 2010-11-21 09:03 | 显示全部楼层
早上调了10分钟波形没出,一看示波器没接地。:funk:
hotpower 发表于 2010-11-22 17:59 | 显示全部楼层
晕,好像片选反了
