[STM8] STM8S105K4的PF4脚在单片机刚上电时会产生一个1ms多的高脉冲?
6171|2
 楼主| averzgw 发表于 2010-12-7 21:55 | 显示全部楼层 |阅读模式
最近写程序用到STM8S105K4的PF4脚,做普通I/O输出用,但是试验时发现PF4脚在单片机刚一上电就会产生一个1ms多的高脉冲,结果外接的LED,就在上电时闪了一下。我感到很奇怪,就另建了个工程,再写了段简单的程序,用示波器测量PF4脚,发现即使我程序中不操作PF4脚,上电时它还是会产生一个高脉冲。对此十分不解。是我搞错了?或我用的编译器有问题?或这个芯片就有这个问题?有人有相同的情况吗?
附上我的测试程序:
#include <iostm8s105k4.h>
void delay1(unsigned int time)
    while(time > 0)
        __asm("nop");
        __asm("nop");
        __asm("nop");
        time--;
int main( void )
    PC_DDR = (1<<7);
    PC_CR1 = (1<<7);
    while(1)
        delay1(100);
        PC_ODR ^= (1 << 7);
    return 0;
编译环境:IAR Embedded Workbench IDE 6.0.2.1480 (6.0.2.1480)  (IAR FOR STM8S V1.0 EV版)
芯片:STM8S105K4T6C
工程设置:代码最大优化,其他默认
补充:代码无优化 也一样
香水城 发表于 2010-12-8 08:50 | 显示全部楼层
试试看,如果你不操作任何IO口,也就是说在main()中只有一个while(1)循环时,还会有问题吗?
 楼主| averzgw 发表于 2010-12-9 20:10 | 显示全部楼层
DATASHEET有说明,是我没看仔细:
(1) A pull-up is applied to PF4 during the reset phase. This pin is input floating after reset release.
(2)AIN12 is not selectable in ADC scan mode or with analog watchdog.
(3) In 44-pin package, AIN9 cannot be used by ADC scan mode.
(4) In the open-drain output column, ‘T’ defines a true open-drain I/O (P-buffer and protection diode to VDD are not implemented).
(5)The PD1 pin is in input pull-up during the reset phase and after internal reset release.
