求教NAND FLASH 参数
2921|2
daschina|  楼主 | 2011-1-6 19:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在配置u-boot 我的nand flash  和 sdram 分别是
K4S281632K-UC60.pdf
K9GAG08U0M.pdf
需要配置的参数是[这是样例]
[SDRAM]
BUSWIDTH        16            ;The bus width of the SDRAM in bits (16|32)
BANKS              4            ;The bank number (2|4)
ROWADDR              12            ;Row address width in bits (11-13)
COLADDR              9            ;Column address width in bits (8-12)
ISMOBILE          0            ;Define whether SDRAM is mobile SDRAM, this only valid for Jz4750 ,1:yes 0:no
ISBUSSHARE          1            ;Define whether SDRAM bus share with NAND 1:shared 0:unshared
[NAND]
BUSWIDTH        8            ;The width of the NAND flash chip in bits (8|16|32)
ROWCYCLES        3            ;The row address cycles (2|3)
PAGESIZE        4096            ;The page size of the NAND chip in bytes(512|2048|4096)
PAGEPERBLOCK        128             ;The page number per block
FORCEERASE        1            ;The force to erase flag (0|1)
OOBSIZE            128            ;oob size in byte
ECCPOS                 24            ;Specify the ECC offset inside the oob data (0-[oobsize-1])
BADBLACKPOS         0            ;Specify the badblock flag offset inside the oob (0-[oobsize-1])
BADBLACKPAGE        127               ;Specify the page number of badblock flag inside a block(0-[PAGEPERBLOCK-1])
PLANENUM        1            ;The planes number of target nand flash
BCHBIT              4            ;Specify the hardware BCH algorithm for 4750 (4|8)
WPPIN            0            ;Specify the write protect pin number
BLOCKPERCHIP        0            ;Specify the block number per chip,0 means ignore
请教大家这个怎么配置,最好授我以渔,谢谢!
daschina|  楼主 | 2011-1-6 20:01 | 只看该作者
两个资料分别在此!
K4S281632K-UC60.pdf (153.79 KB)
K9GAG08U0M.pdf (1.33 MB)
daschina|  楼主 | 2011-1-7 09:16 | 只看该作者
555。。。没有人回答
