STM32库,3.0和3.3的差别这么大,TIM例程发现时钟设置完全不同
2384|1
redcar|  楼主 | 2011-1-23 19:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1个3.0的,1个3.3的,都是  Project\STM32F10x_StdPeriph_Examples\TIM\TimeBase下的例子,连readme.txt里面写的都不一样
就是时钟设置里面,
3.0的是说
The TIMxCLK frequency is set to 36 MHz, the Prescaler is 4 so the TIM2 counter
clock is 7.2 MHz.
The TIM2 CC1 register value is equal to 49152,
CC1 update rate = TIM2 counter clock / CCR1_Val = 146.48 Hz,
so the TIM2 Channel 1 generates an interrupt each 6.8ms
3.3和3.4的一样,是说
The TIM2CLK frequency is set to SystemCoreClock / 2 (Hz), to get TIM2 counter
clock at 6 MHz so the Prescaler is computed as following:
   - Prescaler = (TIM2CLK / TIM2 counter clock) - 1
SystemCoreClock is set to 72 MHz for Low-density, Medium-density, High-density
and Connectivity line devices and to 24 MHz for Low-Density Value line,
Medium-Density Value line and High-Density devices.
The TIM2 CC1 register value is equal to 40961,
3.0.rar
4.06 KB
3.3.rar
4.17 KB
say_sth_freely| | 2011-1-24 08:11 | 只看该作者
版本升级了,改改说法还不允许嘛,原理还是一样滴
