| PIC单片机异步串口通信只能发不能收
 我用的是PIC16F877A,用的是开发板,串口的程序只能发送,不能接收,接收中断可以进去,但是数据不对,我是照着视频教程上的成功的例子做的,程序贴在下面,请参考,是不是我的开发板这块MAX232有问题啊,怎么调也调不出,我怀疑是MAX232及周边电路有问题,
 请指点一下呀,谢谢!
 // based on PIC16F877A
 #include<pic.h>
 #define uchar unsigned char
 #define uint  unsigned int
 void init();
 void main()
 init();
 TXREG = 0x31;   //Transmit register
 while(!TRMT);
 while(1)
 void init()
 TRISC=0xff;
 TXSTA = 0x24;   //Transmit status register
 //BRGH =1 : High baud rate bit selected
 //SYNC =0 : Asynchronous mode
 RCSTA=0x90;   //SPEN = 1 : serial port is enable
 //CREN = 1 : continuous receive is enable
 SPBRG = 25;   //ste up baud rate to 9600 bps
 GIE=1;
 PEIE=1;
 RCIE=1;       //enable Receive SCI interrupt
 void interrupt com()
 unsigned char uchTemp;
 if(  RCIF )
 //if ( RCIF )
 TXREG = RCREG;
 while(!TRMT);
