USART1和USART2之间数据通信配置
5417|2
 楼主| 绿眼孤狼 发表于 2011-1-29 21:56 | 显示全部楼层 |阅读模式
说明:
     本程序能实现USART1和USART2直接通信,发送和接收的
数据正确.
实验条件:
     直接把 USART1 的 TXD,RXD 和 USART2 的 RXD,TXD
对应连接即可.
#include "stm32f10x_lib.h"
#include "stm32f10x_conf.h"
#include "ili9320.h"
vu8 TxBuffer1 = 129; //USART1发送的数据
vu8 TxBuffer2 = 56; //USART2发送的数据
vu8 RxBuffer1;   //USART1接收数据
vu8 RxBuffer2;   //USART2接收数据
/********** 函数声明 *********/
void RCC_Configuration(void);
void NVIC_Configuration(void);
void GPIO_Configuration(void);
void USART_Configuration(void);
void Sys_Init(void);
/********** 系统初始化 ******************/
void Sys_Init(void)
#ifdef DEBUG
     debug();
#endif
//----- 模块初始化配置 -------
     RCC_Configuration();
     NVIC_Configuration();
     GPIO_Configuration();
     USART_Configuration();
/******* 主函数 **********/
int main(void)
     Sys_Init();
     while(1);
/****** 系统时钟配置函数 ********/
     ErrorStatus  HSEStartUpStatus;
     RCC_DeInit();         //RCC system reset(for debug purpose)
     RCC_HSEConfig(RCC_HSE_ON);      //Enable HSE
     HSEStartUpStatus = RCC_WaitForHSEStartUp();  //Wait till HSE is ready
     if(HSEStartUpStatus == SUCCESS)
       FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); //Enable Prefetch Buffer
       FLASH_SetLatency(FLASH_Latency_2);      //Set 2 Latency cycles
       RCC_HCLKConfig(RCC_SYSCLK_Div1); //AHB clock  = SYSCLK
       RCC_PCLK2Config(RCC_HCLK_Div1);  //APB2 clock = HCLK
       RCC_PCLK1Config(RCC_HCLK_Div2);  //APB1 clock = HCLK/2
       RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9); //PLLCLK = 8MHz * 9 = 72 MHz
       RCC_PLLCmd(ENABLE);          //Enable PLL
       while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);  //Wait till PLL is ready
       RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); //Select PLL as system clock source
       while(RCC_GetSYSCLKSource() != 0x08);  //Wait till PLL is used as system clock source
       RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_USART1
             | RCC_APB2Periph_AFIO, ENABLE); //GPIOA and USART1 clock ENABLE
       RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE); //USART2  clock ENABLE
/****** 中断配置函数 ********/
     NVIC_InitTypeDef NVIC_InitStructure;
     //--- 在内存中进行调试 -----
#ifdef VECT_TAB_RAM
     NIVC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
     //--- 在FLASH中进行调试 ----
#else
     NVIC_SetVectorTable(NVIC_VectTab_FLASH,0x0);
#endif
     //---- 配置USART1 和 USART2中断,并使能 -----
     NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
     NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQChannel;
     NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
     NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
     NVIC_Init(&NVIC_InitStructure);
     NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQChannel;
     NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
/********** 通用I/O配置函数 ***************/
     /* Configure USART1 and USART2 Rx as input floating */
     GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_3 | GPIO_Pin_10;
     GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_IN_FLOATING;
     GPIO_Init(GPIOA, &GPIO_InitStructure);
     /* Configure USART1 and USART2 Tx as alternate function push-pull */
     GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_2 | GPIO_Pin_9;
     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
函数名称:USART_Configuration(void)
功能说明:USART通信模块配置,配置USART工作模式;
输入参数:无
返回值  :无
   USART_InitTypeDef USART_InitStructure;
   USART_InitStructure.USART_BaudRate = 9600;
   USART_InitStructure.USART_WordLength = USART_WordLength_8b;
   USART_InitStructure.USART_StopBits = USART_StopBits_1;
   USART_InitStructure.USART_Parity = USART_Parity_No;
   USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
   USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
   /* Configure USART1 */
   USART_Init(USART1, &USART_InitStructure);
   /* Configure USART2 */
   USART_Init(USART2, &USART_InitStructure);
   /* Enable USART1 Receive and Transmit interrupts */
   USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
   USART_ITConfig(USART1, USART_IT_TXE, ENABLE);
   /* Enable USART2 Receive and Transmit interrupts */
   USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);
   USART_ITConfig(USART2, USART_IT_TXE, ENABLE);
   /* Enable the USART1 */
   USART_Cmd(USART1, ENABLE);
   /* Enable the USART2 */
   USART_Cmd(USART2, ENABLE);
#ifdef DEBUG
void assert_failed(u8 *file, u32 line)
   while(1)
#endif
#include "stm32f10x_it.h"
extern vu8   TxBuffer1;
extern vu8   TxBuffer2;
extern vu8   RxBuffer1;
extern vu8   RxBuffer2;
extern vu16  USART_IDx;
/*********** USART1 中断服务程序 *************/
void USART1_IRQHandler(void)
  if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
    /* Read one byte from the receive data register */
    RxBuffer1 = USART_ReceiveData(USART1);
    USART_ClearITPendingBit(USART1, USART_IT_RXNE);
    USART_ITConfig(USART1, USART_IT_RXNE, DISABLE);
  if(USART_GetITStatus(USART1, USART_IT_TXE) != RESET)
    /* Write one byte to the transmit data register */
    USART_SendData(USART1, TxBuffer1);
    USART_ClearITPendingBit(USART1, USART_IT_TC);
    USART_ITConfig(USART1, USART_IT_TXE, DISABLE);
/*********** USART2 中断服务程序 *************/
void USART2_IRQHandler(void)
  if(USART_GetITStatus(USART2, USART_IT_RXNE) != RESET)
    RxBuffer2 = USART_ReceiveData(USART2);
    USART_ClearITPendingBit(USART2, USART_IT_RXNE);
    USART_ITConfig(USART2, USART_IT_RXNE, DISABLE);
  if(USART_GetITStatus(USART2, USART_IT_TXE) != RESET)
    USART_SendData(USART2, TxBuffer2);
    USART_ClearITPendingBit(USART2, USART_IT_TC);
    USART_ITConfig(USART2, USART_IT_TXE, DISABLE);
及时雨微笑 发表于 2011-2-18 17:13 | 显示全部楼层
谢谢分享啊。
zsz89757 发表于 2011-10-26 15:17 | 显示全部楼层
