点阵液晶驱动程序192X64
2179|1
msp430ing|  楼主 | 2011-2-24 19:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
此程序不用人为选择块,只要输入位置就可以直接显示所需内容。控制器是KS0108B/A。
void WriteByte2(unsigned char dat)
CheckState2();
PORTA|=(1<<PA0);//SET_RS;//RS = 1;
PORTA&=~(1<<PA1);//CLR_RW;//RW = 0;
DDRB = 0XFF;
Swait();
PORTB = dat;//P2= dat;
Swait();
PORTA|=(1<<PA2);//SET_E;//E = 1;
Swait();
PORTA&=~(1<<PA2);//CLR_E;//E = 0;
Swait();
void WriteByte1(unsigned char dat)
CheckState1();
DDRB = 0XFF;
Swait();
Swait();
Swait();
Swait();
void WriteByte0(unsigned char dat)
CheckState0();
DDRB = 0XFF;
Swait();
Swait();
Swait();
Swait();
//向LCD发送命令
//command :命令
void SendCommandToLCD2(unsigned char command)
CheckState2();
DDRB = 0XFF;
Swait();
PORTB = command;//P2 = command;
Swait();
Swait();
Swait();
void SendCommandToLCD1(unsigned char command)
CheckState1();
DDRB = 0XFF;
Swait();
Swait();
Swait();
Swait();
void SendCommandToLCD0(unsigned char command)
CheckState0();
DDRB = 0XFF;
Swait();
Swait();
Swait();
Swait();
//设定行地址(页)--X 0-7
void SetLine0(unsigned char line){
line = line & 0x07; // 0<=line<=7
Swait();
line = line | 0xb8; //1011 1xxx
Swait();
SendCommandToLCD0(line);
// SendCommandToLCD1(line);
// SendCommandToLCD2(line);
void SetLine1(unsigned char line){
Swait();
Swait();
void SetLine2(unsigned char line){
Swait();
Swait();
//设定列地址--Y 0-63
void SetColumn0(unsigned char column){
column = column & 0x3f; // 0=<column<=63
Swait();
column = column | 0x40; //01xx xxxx
Swait();
SendCommandToLCD0(column);
void SetColumn1(unsigned char column){
Swait();
Swait();
SendCommandToLCD1(column);
void SetColumn2(unsigned char column){
Swait();
Swait();
SendCommandToLCD2(column);
//设定显示开始行--XX
void SetStartLine(unsigned char startline) //0--63
startline=startline & 0x07;
Swait();
startline=startline | 0xc0; //1100 0000
Swait();
SendCommandToLCD0(startline);
SendCommandToLCD1(startline);
SendCommandToLCD2(startline);
//开关显示
void SetOnOff(unsigned char onoff)
onoff=0x3e | onoff; //0011 111x
Swait();
SendCommandToLCD0(onoff);
SendCommandToLCD1(onoff);
SendCommandToLCD2(onoff);
//选择屏幕
//screen: 0-全屏,1-左屏,2-右屏
void SelectScreen(unsigned char screen)   //负有效 cs1: 0--右; cs2: 0--左
if(screen == 2)
  PORTA|=(1<<PA3);//CLR_CS1;//CSA = 0;//右屏
  Swait();
  PORTA|=(1<<PA4);//SET_CS2;//CSB = 1;
  Swait();
  PORTA&=~(1<<PA5);//SET_CS2;//CSB = 1;
  Swait();
if (screen == 1)
  PORTA|=(1<<PA3);//CLR_CS2;//CSB = 0;
  Swait();
     PORTA&=~(1<<PA4);//SET_CS1;//CSA = 1;//左屏
  Swait();
  PORTA|=(1<<PA5);//SET_CS2;//CSB = 1;
  Swait();
if (screen == 0)
  PORTA&=~(1<<PA3);//SET_CS1;//CSA = 1;//左屏
  Swait();
  PORTA|=(1<<PA4);//SET_CS1;//CSA = 1;//左屏
  Swait();
  PORTA|=(1<<PA5);//SET_CS1;//CSA = 1;//左屏
  Swait();
//清屏
void ClearScreen(unsigned char screen)
unsigned char i,j;
// uchar k;
SelectScreen(screen);
if(screen==0)
{ for(i=0;i<8;i++)
  SetLine0(i);
  for(j=0;j<64;j++)
   SetColumn0(j);
   Swait();
   WriteByte0(0x00);
   Swait();
if(screen==1)
{ for(i=0;i<8;i++)
  SetLine1(i);
  for(j=0;j<64;j++)
   SetColumn1(j);
   Swait();
   WriteByte1(0x00);
   Swait();
if(screen==2)
{ for(i=0;i<8;i++)
  SetLine2(i);
  for(j=0;j<64;j++)
   SetColumn2(j);
   Swait();
   WriteByte2(0x00);
   Swait();
void ClearScreenAll()
SelectScreen(0);
SelectScreen(1);
SelectScreen(2);
//读显示数据
unsigned char ReadByte()
// uint i;
uchar dat;
CheckState();
RS = 1;
RW = 1;
Swait();
P2 = 0xff;
Swait();
E = 1;
Swait();
dat = P0;
Swait();
E = 0;
return(dat);
void InitLcd() //初始化LCD           不显示的问题
unsigned char i=250; //延时
while(i--);
SetOnOff(0); //关显示
//SelectScreen(2);
//SetStartLine(0); //开始行:0
//SelectScreen(1);
//SetColumn(0);
// ClearScreen(1);//清屏
// ClearScreen(2);
//SelectScreen(0);
SetOnOff(1); //开显示
//SelectScreen(0);
SelectScreen(2);
SelectScreen(1);
SelectScreen(0);
SetStartLine(0);
ClearScreen(1);//清屏
ClearScreen(2);
ClearScreen(0);
void CheckState2()
SelectScreen(2);
uchar temp; //汇编中,这之前有个片选
do{
  PORTA|=(1<<PA1);//SET_RW;//RW  = 1;
  PORTA&=~(1<<PA0);//CLR_RS;//RS  = 0;在这一句后面,汇编里面把数据口都置为1了,我没有改,看效果
  Swait();
  //P2 = 0XFF;
  //PORTB = 0XFF;
  DDRB = 0X00;
  Swait();
  temp = PINB;//temp = P2;
  templong = temp;
  //Swait();
  temp = 0x80 & temp;      //当第7bit为0时可以操作
}while(!(temp == 0));
void CheckState1()
SelectScreen(1);
do{
  Swait();
  //P2 = 0XFF;
  //PORTB = 0XFF;
  DDRB = 0X00;
  Swait();
  templong = temp;
  //Swait();
void CheckState0()
SelectScreen(0);
do{
  Swait();
  //P2 = 0XFF;
  //PORTB = 0XFF;
  DDRB = 0X00;
  Swait();
  templong = temp;
  //Swait();
void Show(uchar lin,uchar column,uchar linechar,uchar columnchar,const uchar *p,uchar num)
uchar i,j,k,screenbz;
const uchar *p1;
p1=p + 32 * num;
k=column;
screenbz=0;
if(k>192) {return;}
if(k<64)
  SelectScreen(0); //如果列数<8(0,1,2,3,4,5,6,7)则写在第一屏上
  SetColumn0(k);
  screenbz=0;
else if(k<128)
  SelectScreen(1); //否则 (8,9,10,11,12,13,14,15)写在第二屏上
  //k=k-64;  修改20090410--1  这一句在这里有点多余,而且在后面判断的时候会引发错误
  SetColumn1(k);
  screenbz=1;
else
  SelectScreen(2);
  //k=k-128;  //这里同上,没有必要做减法
  SetColumn2(k);
  screenbz=2;
SetLine0(lin);
SetLine1(lin);
SetLine2(lin);
//SetColumn0(k);
for(i=lin;i<linechar+lin;i++)
  if(screenbz==0)
   for(j=k;j<k+columnchar;j++)
    if(j>=64)
     SelectScreen(1);
     SetColumn1(0);
     SetLine1(i);
     for(j=64;j<k+columnchar;j++)//这里应该是从64开始往上加,但是总的上界不边,原来从K开始加的话,就又回去了
      // if(j==128)
      //  SelectScreen(2);
      //  SetColumn2(0);
      //  SetLine2(i);
      //  for(j=128;j<k+columnchar;j++)
      //   WriteByte2(pgm_read_byte(p1));
      //   p1++;
       WriteByte1(pgm_read_byte(p1));
       p1++;
    //if(j<64)
    else
     WriteByte0(pgm_read_byte(p1));
     p1++;
   SelectScreen(0);
   SetLine0(i+1);
   SetColumn0(k);
  if(screenbz==1)
    if(j>=128) //对应前面的  修改20090410--1  ,如果前面不修改,这里的K根本到不了128,也就是到64的时候,事实上屏幕已经到边了,但
是数据还继续往里面写
     SelectScreen(2);
     SetColumn2(0);
     SetLine2(i);
      p1++;
    //if(j<128)
    else
     p1++;
   SelectScreen(1);
   SetLine1(i+1);
   SetColumn1(k);
  if(screenbz==2)
    p1++;
   SelectScreen(2);
   SetLine2(i+1);
   SetColumn2(k);
void ShowChar(uchar lin,uchar column,uchar linechar,uchar columnchar,const uchar *p,uchar num)
const uchar *p1;
p1=p + 16 * num;
k=column;
screenbz=0;
if(k>192) {return;}
if(k<64)
  screenbz=0;
  SetColumn0(k);
else if(k<128)
  SelectScreen(1); //如果列数<8(0,1,2,3,4,5,6,7)则写在第一屏上
  k=k-64;
  SetColumn1(k);
  screenbz=1;
else
  SelectScreen(2); //否则 (8,9,10,11,12,13,14,15)写在第二屏上
  k=k-128;
  SetColumn2(k);
  screenbz=2;
SetLine0(lin);
SetLine1(lin);
SetLine2(lin);
//SetColumn0(k);
  if(screenbz==0)
    if(j>=64)
     SelectScreen(1);
     SetColumn1(0);
     SetLine1(i);
      // if(j==128)
      //  SelectScreen(2);
      //  SetColumn2(0);
      //  SetLine2(i);
      //   p1++;
       p1++;
    //if(j<64)
    else
     p1++;
   SelectScreen(0);
   SetLine0(i+1);
   SetColumn0(k);
  if(screenbz==1)
是数据还继续往里面写
     SelectScreen(2);
     SetColumn2(0);
     SetLine2(i);
      p1++;
    //if(j<128)
    else
     p1++;
   SelectScreen(1);
   SetLine1(i+1);
   SetColumn1(k);
  if(screenbz==2)
    p1++;
   SelectScreen(2);
   SetLine2(i+1);
   SetColumn2(k);
void ShowCharLittle(uchar lin,uchar column,uchar linechar,uchar columnchar,const uchar *p,uchar num)
const uchar *p1;
p1=p + 6 * num;
k=column;
screenbz=0;
if(k>192) {return;}
if(k<64)
  screenbz=0;
  SetColumn0(k);
if(k>63&&k<128)
  k=k-64;
  SetColumn1(k);
  screenbz=1;
else
  k=k-128;
  SetColumn2(k);
  screenbz=2;
SetLine0(lin);
SetLine1(lin);
SetLine2(lin);
//SetColumn0(k);
  if(screenbz==0)
    if(j==64)
     SelectScreen(1);
     SetColumn1(0);
     SetLine1(i);
      if(j==128)
       SelectScreen(2);
       SetColumn2(0);
       SetLine2(i);
        p1++;
      p1++;
    p1++;
   SelectScreen(1);
   SetLine0(i+1);
   SetColumn0(k);
  if(screenbz==1)
    if(j==128)
      SelectScreen(2);
      SetColumn2(0);
      SetLine2(i);
       p1++;
    p1++;
   SelectScreen(1);
   SetLine1(i+1);
   SetColumn1(k);
  if(screenbz==2)
    p1++;
   SelectScreen(2);
   SetLine2(i+1);
   SetColumn1(k);
maoyanketi| | 2011-2-24 19:57 | 只看该作者
通过什么方式驱动的了?SPI的?
