暴强的SI4432 BUG,暴强的厂家回复
 楼主| 发表于 2011-2-25 21:43 | 显示全部楼层 |阅读模式
技术支持请求:
How can I stop "Low duty cycle mode"
When I started low duty cycle mode, It works correct, and now I want to stop it i.e. return to "idle" mode, I res Reg7(Operating & Function Control 1)'s enwt bit & Reg8 (Operating & Function Control 2)'s enldm bit to "0", but it not works!
My question is:
If I do this during "on" period of LDCM mode, i.e. SI4432 receive period, the chip will stay in receive state (can by judged from 18.5mA operation current and SPDT's control signal), but can't goto another state by control reg07's txon, rxon, xton bits.
If I do this during "sleep" period of LDCM mode, it will stay in idle mode and the mode switch by control txon, rxon & xton is correct.
I want to know if there is some operation I've miss during stop LDCM function, please tell me or send me the example code.
Thank you!
厂家第一次响应:
Hi
We are investigating it.
厂家第二次响应:
Hi,
  Please enable the wake-up timer interrupt, disable the low duty cycle when the interrupt happen. When the interrupt happen, poll register 0x02 until  cps[1:0] != 01b, now disable LCDM.
看完我泪奔了!!!
发表于 2012-6-13 13:09 | 显示全部楼层
在电子技术领域,不懂英文,怎能成为高手!
发表于 2012-6-13 10:51 | 显示全部楼层
原来 NE5532 是也是英语达人啊?
发表于 2011-6-22 11:39 | 显示全部楼层
我觉得一点问题都没有哦。。。
你反映的只是你使用上的建议。。。。。。。
你就等SI4432-2吧
发表于 2011-6-21 09:48 | 显示全部楼层
21# NE5532
把自动接收关闭,然后再改变模式,就可以立即退出
发表于 2011-6-20 17:11 | 显示全部楼层
乔布斯也会说: “The apple is designed like that...”:)
发表于 2011-6-20 12:50 | 显示全部楼层
把老帖子顶上来炒回锅肉了,有没有谁有办法能够绕过这个BUG达到“立即退出”LDCM模式的??
NE5532 发表于 2011-4-29 21:39
NE5532
为啥舍近求远,不用AT的RF芯片?
 楼主| 发表于 2011-4-29 21:39 | 显示全部楼层
 楼主| 发表于 2011-3-1 20:28 | 显示全部楼层
通信效果还是可以的,2.4k GFSK NRZ -116dbm,11dbm可以到1600米,还不是最终效果。
发表于 2011-3-1 16:09 | 显示全部楼层
不知道SI4432通信距离和效果怎么样?
发表于 2011-3-1 15:37 | 显示全部楼层
关注4432,关注SI000
发表于 2011-2-28 22:46 | 显示全部楼层
全英文/强悍
 楼主| 发表于 2011-2-28 21:17 | 显示全部楼层
围观...........
什么时候SI4432变chipcon的了.......
sinanjj 发表于 2011-2-28 15:52
没有说4432啊,业内知道CC1100和1020系列,Chipcon的老牌产品,确实比4432做得认真些。
发表于 2011-2-28 15:52 | 显示全部楼层
怀念CHIPCON啊,这么好的公司,咋就被TI给弓虽女干了呢……
NE5532 发表于 2011-2-26 09:26
围观...........
发表于 2011-2-28 13:22 | 显示全部楼层
哈哈.
 楼主| 发表于 2011-2-28 13:04 | 显示全部楼层
厂家最新回复:看了后无语了,SiLab跟STC有一拼了!
“The chip is designed like that.”
发表于 2011-2-27 17:38 | 显示全部楼层
被逼上梁山了……:D
 楼主| 发表于 2011-2-27 11:21 | 显示全部楼层
不知道,我现在准备用纠集**——硬件复位 来退出
 楼主| 发表于 2011-2-27 11:20 | 显示全部楼层
不知道,我现在准备用纠集大¥%法——硬件复位 来退出
发表于 2011-2-27 08:45 | 显示全部楼层
非休眠模式,开唤醒中断,会有什么后果??
发表于 2011-2-26 15:32 | 显示全部楼层
到秒级别的话,再想办法吧。
个人签名:††††看NE5532教学视频,炼就工程技术研发功力†††††††††† 《跟我学DC-DC电源管理技术》【从只会写软件成长为软硬兼施】 《印刷电路板设计进阶》【12年一线设计经验大放送】 《印刷电路板设计基础》【新手别怕,老工程师带你入门!】
159
快速回复 返回顶部 返回列表
