AVR在代码中写熔丝位的问题(求高手指点迷津)
1281|7
 楼主| 山东电子小菜鸟 发表于 2017-9-16 19:02 | 显示全部楼层 |阅读模式
1、如下图,用Rrpgisp软件 load FUSE,没有一点问题,但是对于烧写新的芯片,每次都要编写,确实麻烦。
2、想把熔丝位的设置固化在代码中,看门狗、eerpm有相应的
控制寄存器没有问题,但是像掉电检查、功耗选择等没有相应的寄存器,有没有人知道该如何把这些熔丝位的设置写在代码中呢?(像PIC那样,__CONFIG(---)就可以搞定)。
3、AVR STUDIO头文件中也有相应的定义如下:应该是可以实现的 但是不知道该怎么操作?求相关人员指点。
/* Fuses */
#define FUSE_MEMORY_SIZE 3
/* Low Fuse Byte */
#define FUSE_CKSEL0 (unsigned char)~_BV(0)  /* Select Clock Source */
#define FUSE_CKSEL1 (unsigned char)~_BV(1)  /* Select Clock Source */
#define FUSE_CKSEL2 (unsigned char)~_BV(2)  /* Select Clock Source */
#define FUSE_CKSEL3 (unsigned char)~_BV(3)  /* Select Clock Source */
#define FUSE_SUT0   (unsigned char)~_BV(4)  /* Select start-up time */
#define FUSE_SUT1   (unsigned char)~_BV(5)  /* Select start-up time */
#define FUSE_CKOUT  (unsigned char)~_BV(6)  /* Clock output */
#define FUSE_CKDIV8 (unsigned char)~_BV(7) /* Divide clock by 8 */
#define LFUSE_DEFAULT (FUSE_CKSEL0 & FUSE_CKSEL2 & FUSE_CKSEL3 & FUSE_SUT0 & FUSE_CKDIV8)
/* High Fuse Byte */
#define FUSE_BODLEVEL0 (unsigned char)~_BV(0)  /* Brown-out Detector trigger level */
#define FUSE_BODLEVEL1 (unsigned char)~_BV(1)  /* Brown-out Detector trigger level */
#define FUSE_BODLEVEL2 (unsigned char)~_BV(2)  /* Brown-out Detector trigger level */
#define FUSE_EESAVE    (unsigned char)~_BV(3)  /* EEPROM memory is preserved through chip erase */
#define FUSE_WDTON     (unsigned char)~_BV(4)  /* Watchdog Timer Always On */
#define FUSE_SPIEN     (unsigned char)~_BV(5)  /* Enable Serial programming and Data Downloading */
#define FUSE_DWEN      (unsigned char)~_BV(6)  /* debugWIRE Enable */
#define FUSE_RSTDISBL  (unsigned char)~_BV(7)  /* External reset disable */
#define HFUSE_DEFAULT (FUSE_SPIEN)
/* Extended Fuse Byte */
#define FUSE_BOOTRST (unsigned char)~_BV(0)
#define FUSE_BOOTSZ0 (unsigned char)~_BV(1)
#define FUSE_BOOTSZ1 (unsigned char)~_BV(2)
#define EFUSE_DEFAULT (FUSE_BOOTSZ0 & FUSE_BOOTSZ1)
4、如下图、手册中的方法是跟操作FLASH一样,只是命令不同,但这个方法着实麻烦,既然官方库中有如3中的代码,
应该可以有简单的方法实现吧??
5、这么老的片子,应该被很多人 玩透了,求指点
 楼主| 山东电子小菜鸟 发表于 2017-9-16 19:49 | 显示全部楼层
顶起来
henglin 发表于 2017-9-16 22:11 | 显示全部楼层
我知道程序中读取熔丝位
 楼主| 山东电子小菜鸟 发表于 2017-9-17 16:57 | 显示全部楼层
我知道程序中读取熔丝位
怎么操作
henglin 发表于 2017-9-18 10:24 | 显示全部楼层
你仔细看看这个,我有用到这个,检查熔丝位置
这个对于反盗版 是有好处的
宇容创行 发表于 2017-9-18 10:29 | 显示全部楼层
不用折腾了,这个不支持,软件只能在iap中改
 楼主| 山东电子小菜鸟 发表于 2017-9-18 11:46 | 显示全部楼层
这个对于反盗版 是有好处的
谢谢
个人签名:qq:641208111;技术交流群:377640799 大学电子竞赛预热赛开赛啦~千元大奖等你来拿火热进行中!!点击参加活动 欢迎加个人QQ:641208111一起交流合作
140
