请问at91sam9260自带ADC转换的问题....
5193|2
 楼主| Lx_mcu 发表于 2011-3-14 20:19 | 显示全部楼层 |阅读模式
我在linux上修改了一下sam9260的adc驱动,单个通道转换正常,如果把4个通道都使能,定时2秒触发一次,通道0 1 2正常, 通道3要10多秒才产生一次中断;
各位大侠帮忙看看,问题在哪里,谢谢!
下面是代码:
* driver/char/at91_adc.c
* Copyright (C) 2007 Embedall Technology Co., Ltd.
* Analog-to-digital Converter(ADC) Driver.
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
#include <linux/types.h>
#include <linux/init.h>
#include <linux/kernel.h>
#include <linux/module.h>
#include <linux/version.h>
#include <linux/spinlock.h>
#include <linux/interrupt.h>
#include <linux/platform_device.h>
#include <linux/cdev.h>
#include <linux/fs.h>
#include <linux/ioctl.h>
#include <linux/poll.h>
//#include <linux/class.h>
#include <mach/at91_adc.h>
#include <mach/hardware.h>
#include <mach/gpio.h>
#include <mach/at91_tc.h>
#include <mach/at91_pmc.h>
#include "adc.h"
#define DRV_NAME "at91_adc"
#define DEV_NAME "adc"
#define adc_readl(adc,reg) (__raw_readl((adc)->membase + (reg)))
#define adc_writel(adc,reg,v) (__raw_writel((v), (adc)->membase + (reg)))
#define tc_readl(adc,reg) (__raw_readl((adc)->tcxbase + (reg)))
#define tc_writel(adc,reg,v) (__raw_writel((v), (adc)->tcxbase + (reg)))
#define ADC_MAX_CHANNEL 4
#define BUF_SIZE 8
#define buf_cnt(channel) (((channel)->head - (channel)->tail) & ((BUF_SIZE)-1))
#define buf_space(channel) (((channel)->tail-((channel)->head+1))&(BUF_SIZE-1))
struct adc;
struct adc_channel
struct cdev cdev;
struct device *dev;
struct class_device *class_dev;
int id;
int buf[BUF_SIZE];
int head;
int tail;
struct fasync_struct *fasync;
struct adc *adc;
struct adc
dev_t devt;
struct class *class;
void __iomem *membase;
void __iomem *tcbbase;
void __iomem *tcxbase;
unsigned int irq;
struct adc_mode mode;
spinlock_t lock;
struct adc_channel *channel[ADC_MAX_CHANNEL];
static struct adc *adc;
static int buf_in(struct adc_channel *channel, int v)
channel->buf[channel->head] = v;
channel->head = (channel->head + 1) & (BUF_SIZE - 1);
return v;
static int adc_init_tc(struct adc *adc)
unsigned int dummy = 0;
spin_lock(&adc->lock);
if (adc->mode.trigger != ADC_TRIGGER_TIMER)
  at91_sys_write(AT91_PMC_PCDR, 1 << AT91SAM9260_ID_TC2);
  spin_unlock(&adc->lock);
  return 0;
tc_writel(adc, AT91_TC_CCR, AT91_TC_CLKDIS);
dummy |= (AT91_TC_TIMER_CLOCK5 | AT91_TC_CPCTRG | AT91_TC_WAVE |
AT91_TC_WAVESEL_UP_AUTO | AT91_TC_ACPA_SET |
AT91_TC_ACPC_CLEAR );
tc_writel(adc, AT91_TC_CMR, dummy);
if (adc->mode.trigger_time)
  dummy = (adc->mode.trigger_time*1000000)/(1000000000/32768);
  if (dummy > 0xffff) dummy = 0xffff;
  tc_writel(adc, AT91_TC_RC, dummy);
  tc_writel(adc, AT91_TC_RA, dummy * 3 / 5);
else
  tc_writel(adc, AT91_TC_RC, 32768);
  tc_writel(adc, AT91_TC_RA, 32768 * 3 / 5);
at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_TC2);
tc_writel(adc, AT91_TC_CCR, AT91_TC_CLKEN | AT91_TC_SWTRG);
return 0;
static int adc_hw_init(struct adc *adc)
adc_writel(adc, AT91_ADC_CR, AT91_ADC_SWRST); //软件复位
adc_writel(adc, AT91_ADC_IER, AT91_ADC_DRDY); //enables the corresponding interrput ,Data ready interrupt enable
at91_sys_write(AT91_PMC_PCER, 1 << adc->irq); //clock enable
return 0;
static int adc_fasync(int fd, struct file *file, int mode)
struct adc_channel *channel = file->private_data;
return fasync_helper(fd, file, mode, &channel->fasync);
static int adc_open(struct inode *inode, struct file *file)
struct adc *adc;
struct adc_channel *channel;
channel = container_of(inode->i_cdev, struct adc_channel, cdev);
file->private_data = channel;
adc = channel->adc;
spin_lock(&adc->lock); //获取自旋锁
at91_set_multi_drive(PIN_BASE + 0x40 + channel->id, 1);
adc_writel(adc, AT91_ADC_IER, (1 << channel->id));
adc_writel(adc, AT91_ADC_CHER, (1 << channel->id));
return nonseekable_open(inode, file);
static int adc_release(struct inode *inode, struct file *file)
struct adc *adc;
adc = channel->adc;
// adc_fasync(-1, file, 0);
adc_writel(adc, AT91_ADC_IDR, 1 << channel->id);
adc_writel(adc, AT91_ADC_CHDR, 1 << channel->id);
return 0;
static ssize_t adc_read(struct file *file, char __user *buf, size_t count, loff_t *f_pos)
return 0;
static ssize_t adc_write(struct file *file, const char __user *buf, size_t count, loff_t *f_pos)
return 0;
/* static void adc_sigio(struct adc_channel *channel) */
/* if (channel->fasync) */
/* kill_fasync(&channel->fasync, SIGIO, POLL_IN); */
static int adc_ioctl(struct inode *inode, struct file *file, unsigned int cmd, unsigned long arg)
struct adc *adc;
struct adc_mode *mode;
int ret = 0;
void __user *argp = (void __user *)arg;
int __user *p = argp;
adc = channel->adc;
mode = &adc->mode;
switch (cmd)
  case ADCCTL_RESET:
   return 0;
  case ADCCTL_START:
   adc_writel(adc, AT91_ADC_CR, AT91_ADC_START);
   return 0;
  case ADCCTL_SETMODE:
   ret = copy_from_user(mode, argp, sizeof(struct adc_mode));
   if (mode->trigger == ADC_TRIGGER_TIMER)
    dummy |= AT91_ADC_TRGEN | AT91_ADC_TRGSEL_TC2;
   else if (mode->trigger == ADC_TRIGGER_EXT)
    dummy |= AT91_ADC_TRGEN | AT91_ADC_TRGSEL_EXTERNAL;
   if (mode->resolution & ADC_M_8BIT)
    dummy |= AT91_ADC_LOWRES;
   if (mode->sleep_mode)
    dummy |= AT91_ADC_SLEEP;
   if (mode->adc_clock)
    dummy |= AT91_ADC_PRESCAL_(mode->adc_clock);
   if (mode->startup_time)
    dummy |= AT91_ADC_STARTUP_(mode->startup_time);
   if (mode->sample_time)
    dummy |= AT91_ADC_SHTIM_(mode->sample_time);
   adc_init_tc(adc);
   adc_writel(adc, AT91_ADC_MR, dummy);
   return 0;
  case ADCCTL_GETMODE:
   ret = copy_to_user(argp, mode, sizeof(struct adc_mode));
   return 0;
  case ADCCTL_GETDATA:
  ret = buf_cnt(channel);
   if (ret > 0)
    if (!put_user(channel->buf[channel->tail], p))
     channel->tail = (channel->tail + 1) & (BUF_SIZE -1);
    return 0;
   return -EFAULT;
  case ADCCTL_GETCNT:
   return put_user(buf_cnt(channel), p);
  case ADCCTL_GETSTATUS:
   return put_user(adc_readl(adc, AT91_ADC_SR), p);
  default:
   return -EINVAL;
return -EINVAL;
static struct file_operations adc_fops = {
.owner = THIS_MODULE,
.read = adc_read,
.write = adc_write,
.open = adc_open,
.release = adc_release,
.ioctl = adc_ioctl,
.fasync = adc_fasync,
static irqreturn_t adc_interrupt(int irq, void *dev_id)
struct adc *adc = dev_id;
int ivar;
unsigned int status;
status = adc_readl(adc, AT91_ADC_SR) & adc_readl(adc, AT91_ADC_IMR);
while (status)
  printk(KERN_INFO "at91_adc: interrupt status reg 0x%08x\n", status);
  if (status & AT91_ADC_EOC(0))
   channel = adc->channel[0];
   ivar = buf_in(channel, adc_readl(adc, AT91_ADC_CHR(0)));
   printk(KERN_INFO "the channel 0 data is %d\n", ivar);
   // adc_sigio(channel);
  if (status & AT91_ADC_EOC(1))
   channel = adc->channel[1];
   ivar = buf_in(channel, adc_readl(adc, AT91_ADC_CHR(1)));
   printk(KERN_INFO "the channel 1 data is %d\n", ivar);
  if (status & AT91_ADC_EOC(2))
   channel = adc->channel[2];
   ivar = buf_in(channel, adc_readl(adc, AT91_ADC_CHR(2)));
   printk(KERN_INFO "the channel 2 data is %d\n", ivar);
  if (status & AT91_ADC_EOC(3))
   channel = adc->channel[3];
   ivar = buf_in(channel, adc_readl(adc, AT91_ADC_CHR(3)));
   printk(KERN_INFO "the channel 3 data is %d\n", ivar);
  if (status & AT91_ADC_DRDY)
   adc_readl(adc, AT91_ADC_LCDR);
return IRQ_HANDLED;
static int __init adc_probe(struct platform_device *pdev)
int ret;
channel = kmalloc(sizeof(struct adc_channel), GFP_KERNEL);
if (!channel)
  printk(KERN_ERR "at91_adc: failed to kmalloc channel %d\n", pdev->id);
  return -ENOMEM;
// channel->fasync = kmalloc(sizeof(struct fasync_struct), GFP_KERNEL);
// if (!channel->fasync) return -ENOMEM;
channel->id = pdev->id;
channel->dev = &pdev->dev;
channel->adc = adc;
channel->head = 0;
channel->tail = 0;
cdev_init(&channel->cdev, &adc_fops);
channel->cdev.owner = THIS_MODULE;
ret = cdev_add(&channel->cdev, MKDEV(MAJOR(adc->devt), pdev->id), 1);
if (ret)
  printk(KERN_ERR "at91_adc: failed to add channel %d device\n", pdev->id);
  kfree(channel);
  return ret;
channel->class_dev = device_create(adc->class, NULL,  MKDEV(MAJOR(adc->devt),
pdev->id),
channel->dev,
DEV_NAME"%d", pdev->id);
if (IS_ERR(channel->class_dev))
  cdev_del(&channel->cdev);
  kfree(channel);
  return PTR_ERR(channel->class_dev);
adc->channel[pdev->id] = channel;
platform_set_drvdata(pdev, channel);
printk(KERN_INFO "at91_adc.%d: register at /dev/adc%d (%d:%d)\n",
pdev->id, pdev->id, MAJOR(adc->devt), pdev->id);
return 0;
static int __exit adc_remove(struct platform_device *pdev)
struct adc_channel *channel = platform_get_drvdata(pdev);
device_destroy(adc->class, MKDEV(MAJOR(adc->devt), pdev->id));//delete device node under /dev
kfree(channel);
return 0;
static struct platform_driver adc_driver = {
.probe = adc_probe,
.remove = __exit_p(adc_remove),
.driver =
  .name = DRV_NAME,
void  adc_dev_release(struct device * dev)
static struct platform_device adc_channel_device[ADC_MAX_CHANNEL];
static int __init adc_add_channel_device(void)
int i = 0;
for (i=0; i<ADC_MAX_CHANNEL; i++)
  adc_channel_device[i].name = DRV_NAME;
  adc_channel_device[i].id = i;
  adc_channel_device[i].dev.release = adc_dev_release;
  platform_device_register(&adc_channel_device[i]);
return 0;
static int __init adc_del_channel_device(void)
int i = 0;
  //adc_channel_device[i].dev.platform_data = NULL;
  platform_device_unregister(&adc_channel_device[i]);
return 0;
static int __init adc_init(void)
int ret = 0;
adc = kmalloc(sizeof(struct adc), GFP_KERNEL);
if (!adc)
  return -ENOMEM;
//申请分配指定的IO内存资源;
if (!request_mem_region(AT91SAM9260_BASE_ADC, SZ_16K, DRV_NAME))
  kfree(adc);
  return -EBUSY;
adc->membase = ioremap(AT91SAM9260_BASE_ADC, SZ_16K);
if (adc->membase == NULL)
  goto adc_release_mem;
if (!request_mem_region(AT91SAM9260_BASE_TC0, SZ_16K, DRV_NAME))
  goto adc_iounmap;
adc->tcbbase = ioremap(AT91SAM9260_BASE_TC0, SZ_16K);
if (adc->tcbbase == NULL)
  goto adc_release_mem_tc;
adc->irq = AT91SAM9260_ID_ADC;
adc->tcxbase = adc->tcbbase + 0x80;
spin_lock_init(&adc->lock);
adc->class = class_create(THIS_MODULE, DEV_NAME);
if (IS_ERR(adc->class))
  printk(KERN_ERR "at91_adc: faile to create device class\n");
  goto adc_iounmap_tc;
ret = alloc_chrdev_region(&adc->devt, 0, ADC_MAX_CHANNEL, DEV_NAME);
if (ret < 0)
  printk(KERN_ERR"%s: failed to allocate dev region\n", __FILE__);
  goto adc_destroy_class;
if (request_irq(adc->irq, adc_interrupt, IRQF_SHARED, DRV_NAME, adc))
  printk(KERN_ERR"%s: request irq failed\n", __FILE__);
  goto adc_del_channel;
adc_hw_init(adc); //ADC init ,复位,中断使能,时钟使能
platform_driver_register(&adc_driver);
printk(KERN_INFO "Analog-to-Digital Converter (irq %d)\n", adc->irq);
adc_add_channel_device();
return 0;
adc_del_channel:
unregister_chrdev_region(adc->devt, ADC_MAX_CHANNEL);
adc_destroy_class:
class_destroy(adc->class);
adc_iounmap_tc:
iounmap(adc->tcbbase);
adc_release_mem_tc:
release_mem_region(AT91SAM9260_BASE_TC0, SZ_16K);
adc_iounmap:
iounmap(adc->membase);
adc_release_mem:
release_mem_region(AT91SAM9260_BASE_ADC, SZ_16K);
kfree(adc);
return ret;
static void __exit adc_exit(void)
platform_driver_unregister(&adc_driver);
free_irq(adc->irq, adc);
kfree(adc);
adc_del_channel_device();
module_init(adc_init);
module_exit(adc_exit);
l0p0c 发表于 2011-3-15 22:00 | 显示全部楼层
如此之长啊……
盈安信科技 发表于 2011-3-16 21:49 | 显示全部楼层
看代码我就晕了,
