[STM8] STM8S IO口操作宏(使用内联函数模板)
3283|0
 楼主| CC2530 发表于 2011-3-19 20:55 | 显示全部楼层 |阅读模式
//IO口宏定义
STM8S_GPIO_ASSIGN(LED_0,D,1);  //LED_0:PD1,用模板定义所有LED_0操作内联函数
STM8S_GPIO_ASSIGN(LED_1,D,2);  //LED_1:PD2,用模板定义所有LED_1操作内联函数
STM8S_GPIO_ASSIGN(LED_2,D,3);  //LED_2:PD3,用模板定义所有LED_2操作内联函数
STM8S_GPIOS_ASSIGN(LED,D,1,3); //LED:PD1-PD3,用模板定义所有LED操作内联函数
    //LED单独设置
    GPIO_LED_0_MakeOutputPushPullSlow(1);
    //LED_0设置为OutputPushPullSlow,初始输出1
    GPIO_LED_1_MakeOutputPushPullSlow(1);
    //LED_1设置为OutputPushPullSlow,初始输出1
    GPIO_LED_2_MakeOutputPushPullSlow(0);
    //LED_2设置为OutputPushPullSlow,初始输出0
    GPIO_LED_0_Set();
    //LED_0输出1
    GPIO_LED_0_Clr();
    //LED_0输出0
    GPIO_LED_0_Toggle();
    //LED_0翻转
    //LED整体设置
    GPIOS_LED_MakeOutputPushPullSlow(3);
    //LED整体设置为OutputPushPullSlow,
    //初始输出3,即LED_0初始输出1,即LED_1初始输出1,即LED_2初始输出0
    GPIOS_LED_Out(5);
    //LED整体输出5;即LED_0初始输出1,即LED_1初始输出0,即LED_2初始输出1
    GPIOS_LED_Out(2);
    //LED整体输出2;即LED_0初始输出0,即LED_1初始输出1,即LED_2初始输出0
    GPIOS_LED_Toggle();
    //LED整体翻转
//C语言编译汇编代码
//   12     //LED单独设置
//   13     GPIO_LED_0_MakeOutputPushPullSlow(1);
        BSET      L:0x500f, #0x1
        BRES      L:0x5011, #0x1
        BRES      L:0x5012, #0x1
        BRES      L:0x5013, #0x1
//   14     //LED_0设置为OutputPushPullSlow,初始输出1
//   15
//   16     GPIO_LED_1_MakeOutputPushPullSlow(1);
        BSET      L:0x500f, #0x2
        BRES      L:0x5011, #0x2
        BRES      L:0x5012, #0x2
        BRES      L:0x5013, #0x2
//   17     //LED_1设置为OutputPushPullSlow,初始输出1
//   18
//   19     GPIO_LED_2_MakeOutputPushPullSlow(0);
        BRES      L:0x500f, #0x3
        BRES      L:0x5011, #0x3
        BRES      L:0x5012, #0x3
        BRES      L:0x5013, #0x3
//   20     //LED_2设置为OutputPushPullSlow,初始输出0
//   21
//   22     GPIO_LED_0_Set();
        BSET      L:0x500f, #0x1
//   23     //LED_0输出1
//   24
//   25     GPIO_LED_0_Clr();
        BRES      L:0x500f, #0x1
//   26     //LED_0输出0
//   27
//   28     GPIO_LED_0_Toggle();
        LD        A, #0x2
        XOR       A, L:0x500f
        LD        L:0x500f, A
//   29     //LED_0翻转
//   30
//   31
//   32     //LED整体设置
//   33     GPIOS_LED_MakeOutputPushPullSlow(3);
        BRES      L:0x500f, #0x3
        LD        A, #0x6
        OR        A, L:0x500f
        LD        L:0x500f, A
        LD        A, #0xf1
        AND       A, L:0x5011
        LD        L:0x5011, A
        LD        A, #0xf1
        AND       A, L:0x5012
        LD        L:0x5012, A
        LD        A, #0xf1
        AND       A, L:0x5013
        LD        L:0x5013, A
//   34     //LED整体设置为OutputPushPullSlow,
//   35     //初始输出3,即LED_0初始输出1,即LED_1初始输出1,即LED_2初始输出0
//   36
//   37     GPIOS_LED_Out(5);
        BRES      L:0x500f, #0x2
        LD        A, #0xa
        OR        A, L:0x500f
        LD        L:0x500f, A
//   38     //LED整体输出5;即LED_0初始输出1,即LED_1初始输出0,即LED_2初始输出1
//   39
//   40     GPIOS_LED_Out(2);
        LD        A, #0xf5
        AND       A, L:0x500f
        LD        L:0x500f, A
        BSET      L:0x500f, #0x2
//   41     //LED整体输出2;即LED_0初始输出0,即LED_1初始输出1,即LED_2初始输出0
//   42
//   43     GPIOS_LED_Toggle();
        LD        A, #0xe
        XOR       A, L:0x500f
        LD        L:0x500f, A
//   44     //LED整体翻转
io.rar
168.68 KB, 下载次数: 47
