【Beaglebone学习笔记】驱动和硬件性能的测试
630|2
 楼主| Plantt 发表于 2017-9-27 10:41 | 显示全部楼层 |阅读模式
驱动和硬件性能的测试
拿到板子第一步串口驱动的安装:
在板子带的sd中有驱动文件,但是安装的时候出现了问题,由于不支持中文,安装不了。
大家可以在下面的网站进行驱动的下载,选择自己的系统版本就可以直接下载驱动了。
第二步对各硬件功能进行一个简单的测试:
启动信息如下:
U-Boot SPL 2011.09-00010-g81c8c79 (Feb 13 2012 - 14:48:03)
Texas Instruments Revision detection unimplemented
No AC power, disabling frequency switch
OMAP SD/MMC: 0
reading u-boot.img
reading u-boot.img
U-Boot 2011.09-00010-g81c8c79 (Feb 13 2012 - 14:48:03)
I2C:   ready
DRAM:  256 MiB
No daughter card present
NAND:  HW ECC Hamming Code selected
No NAND device found!!!
0 MiB
MMC:   OMAP SD/MMC: 0
*** Warning - readenv() failed, using default environment
Net:   cpsw
Hit any key to stop autoboot:  0
SD/MMC found on device 0
reading uEnv.txt
33 bytes read
Loaded environment from uEnv.txt
Importing environment from mmc ...
reading uImage
3137440 bytes read
## Booting kernel from Legacy Image at 80007fc0 ...
   Image Name:   Angstrom/3.2/beaglebone
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3137376 Bytes = 3 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
   XIP Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[    0.068264] _omap_mux_get_by_name: Could not find signal uart1_cts.uart1_cts
[    0.068285] omap_hwmod_mux_init: Could not allocate device mux entry
[    0.068437] _omap_mux_get_by_name: Could not find signal uart2_cts.uart2_cts
[    0.068455] omap_hwmod_mux_init: Could not allocate device mux entry
[    0.068613] _omap_mux_get_by_name: Could not find signal uart3_cts_rctx.uart3_cts_rctx
[    0.068632] omap_hwmod_mux_init: Could not allocate device mux entry
[    0.106323] cpuidle-am33xx cpuidle-am33xx.0: failed to register driver
[    0.261078] _omap_mux_get_by_name: Could not find signal leds-gpio
[    0.651886] omap2_set_init_voltage: unable to get clk dpll1_ck
[    0.658070] omap2_set_init_voltage: unable to set vdd_mpu_iva
[    0.664086] omap2_set_init_voltage: unable to get clk l3_ick
[    0.670023] omap2_set_init_voltage: unable to set vdd_core
systemd-fsck[55]: Angstrom-Cloud9-: clean, 28977/874496 files, 748340/3494137 blocks
[    4.555134]
[    4.555144] CPSW phy found : id is : 0x7c0f1
[    4.562024] PHY 0:01 not found
.---O---.
|       |                  .-.           o o
|       |     | __  |  ---'| '--.|  .-'|     |     |
The Angstrom Distribution beaglebone ttyO0
Angstrom v2012.01-core - Kernel 3.2.5+
beaglebone login:
第三步测试,网络接口的测试:
查看网卡信息:
~# ifconfig
eth0      Link encap:Ethernet  HWaddr 00:18:31:8A:F1:85
          inet addr:192.168.2.103  Bcast:192.168.2.255  Mask:255.255.255.0
          inet6 addr: fe80::218:31ff:fe8a:f185/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:17 errors:0 dropped:0 overruns:0 frame:0
          TX packets:37 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:5152 (5.0 KiB)  TX bytes:8118 (7.9 KiB)
          Interrupt:40
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:2 errors:0 dropped:0 overruns:0 frame:0
          TX packets:2 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:229 (229.0 B)  TX bytes:229 (229.0 B)
64 bytes from 119.75.217.56: icmp_req=1 ttl=53 time=2.59 ms
64 bytes from 119.75.217.56: icmp_req=2 ttl=53 time=2.56 ms
64 bytes from 119.75.217.56: icmp_req=3 ttl=53 time=2.44 ms
64 bytes from 119.75.217.56: icmp_req=4 ttl=53 time=3.15 ms
第四步的测试:led的测试
点亮和熄灭usr1
~# echo 1 > /sys/class/leds/beaglebone::usr1/brightness
~# echo 0 > /sys/class/leds/beaglebone::usr1/brightness
同样安装上面的方法可以点亮usr2、usr3,usr0已经被用做linux系统心跳指示灯,但也是可以控制的
dspmana 发表于 2017-9-27 21:47 | 显示全部楼层
可以看看这个版块很多的beaglebone的开发板。
dspmana 发表于 2017-9-27 21:48 | 显示全部楼层
硬件性能和软件性能都有的。
