2812 定时器程序
814|0
qwe890asd|  楼主 | 2017-10-13 10:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
2812 定时器程序
#include "DSP28_Device.h"unsigned int Send_Flag;
unsigned int i;
void DelayNmSec(int N)
unsigned int j;
while(N--)
for(j=0;j<65535;j++);
interrupt void T1PINT_ISR(void)
strg[0]=105;
length=5;
length--;
Tx=(unsigned char*)strg;
if(length>0) SciaRegs.SCITXBUF=*Tx++;
else
length=0;
EvaRegs.EVAIMRA.bit.T1PINT=1;//中断允许
EvaRegs.EVAIFRA.bit.T1PINT=1;//清除中断标志
PieCtrl.PIEACK.bit.ACK2=1;//向cpu申请中断
interrupt void T2PINT_ISR(void)
strg[0]=104;
length=5;
length--;
else
length=0;
EvaRegs.EVAIMRB.bit.T2PINT=1;//中断允许
EvaRegs.EVAIFRB.bit.T2PINT=1;//清除中断标志
PieCtrl.PIEACK.bit.ACK3=1;//向cpu申请中断
void main(void)
/*初始化系统*/
InitSysCtrl();
/*关中断*/
DINT;
IER = 0x0000;
IFR = 0x0000;
/*初始化PIE中断*/
InitPieCtrl();
/*初始化PIE中断矢量表*/
InitPieVectTable();
/*初始化SCIA寄存器*/
InitSci();
for(i = 0; i < 8; i++)
Sci_VarRx = 0;
Sci_VarTx = 0;
i=0;
Rx=Sci_VarRx;
Tx=Sci_VarTx;
Send_Flag = 0;
rx_length=0;
add=0;
length=9;
EvaRegs.GPTCONA.all=0;
EvaRegs.T1PR = 65535; //
EvaRegs.T1CNT = 0x0000; // 定时器1计数器
EvaRegs.T1CON.all = 0x1440;//1 分频,使能定时器操作,连续增模式
// 初始化定时器2
EvaRegs.T2PR =65535; // 定时器2的周期为20k
EvaRegs.T2CNT =0x0000; // Timer2 counter
EvaRegs.T2CON.all =0x1440;//16分频,使能定时器操作,连续增模式
EvaRegs.EVAIMRB.bit.T2PINT = 1;//定时器2周期中断允许
EvaRegs.EVAIFRB.bit.T2PINT = 1;//清除标志
/*设置中断服务程序入口地址*/
EALLOW; // This is needed to write to EALLOW protected registers
PieVectTable.TXAINT = &SCITXINTA_ISR;
PieVectTable.RXAINT = &SCIRXINTA_ISR;
PieVectTable.T1PINT = &T1PINT_ISR;
PieVectTable.T2PINT = &T2PINT_ISR;
EDIS; // This is needed to disable write to EALLOW protected registers
PieCtrl.PIEIER2.bit.INTx4=1;//T1pint中断
PieCtrl.PIEIER3.bit.INTx1=1;//T2pint中断
/*开中断*/
IER |= M_INT9;
IER |= M_INT2; // t1pint enable
IER |= M_INT3; // t2pint enable
EINT; // Enable lobal interrupt INTM
ERTM; // Enable Global realtime interrupt DBGM
while(1)
/* DelayNmSec(10);
strg[1]='b';
strg[2]='c';
length=5;
length--;
else
length=0;
strg[1]='x';
strg[2]='y';*/
// No more.
