初学者正学无字库点阵lcd12864,下面是我的代码,高手帮忙
2552|1
 楼主| lin1210 发表于 2011-4-3 15:28 | 显示全部楼层 |阅读模式
/******************** (C) COPYRIGHT 2008 STMicroelectronics ********************
* File Name          : main.c
* Author             : MCD Application Team
* Version            : V2.0.3
* Date               : 09/22/2008
* Description        : Main program body
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_lib.h"
#define uint unsigned int
#define uchar unsigned char
#define RSH  GPIO_SetBits(GPIOA,GPIO_Pin_0)
#define RSL  GPIO_ResetBits(GPIOA,GPIO_Pin_0)
#define RWH  GPIO_SetBits(GPIOA,GPIO_Pin_1)
#define RWL  GPIO_ResetBits(GPIOA,GPIO_Pin_1)
#define ENH  GPIO_SetBits(GPIOA,GPIO_Pin_2)
#define ENL  GPIO_ResetBits(GPIOA,GPIO_Pin_2)
#define CS1H  GPIO_SetBits(GPIOA,GPIO_Pin_3)
#define CS1L  GPIO_ResetBits(GPIOA,GPIO_Pin_3)
#define CS2H  GPIO_SetBits(GPIOA,GPIO_Pin_4)
#define CS2L  GPIO_ResetBits(GPIOA,GPIO_Pin_4)
void RCC_Configuration(void);
void NVIC_Configuration(void);
void GPIO_Configuration(void);
void Delay();
uchar  table[][16]=
    ///--  文字:  爱
    //--  宋体12;
    0x00,0x40,0xB2,0x96,0x9A,0x92,0xF6,0x9A,0x93,0x91,0x99,0x97,0x91,0x90,0x30,0x00,
    0x40,0x20,0xA0,0x90,0x4C,0x47,0x2A,0x2A,0x12,0x1A,0x26,0x22,0x40,0xC0,0x40,0x00,
void Write_cmd_left(uchar cmd)
  RSL;
  RWL;
  CS1H;
  GPIO_Write(GPIOF,cmd);
  ENL;
  Delay(300);
  ENH;
  Delay(300);
  ENL;
  Delay(300);
  CS1L;
void Write_cmd_right(uchar cmd)
  RSL;
  RWL;
  CS2H;
  ENL;
  Delay(300);
  ENH;
  Delay(300);
  ENL;
  Delay(300);
  CS2L;
void Write_data_left(uchar data)
  RSH;
  RWL;
  CS1H;
  GPIO_Write(GPIOF,data);
  ENL;
  Delay(300);
  ENH;
  Delay(300);
  ENL;
  Delay(300);
  CS1L;
void Write_data_right(uchar data)
  RSH;
  RWL;
  CS2H;
  ENL;
  Delay(300);
  ENH;
  Delay(300);
  ENL;
  Delay(300);
  CS1L;
void led_disp(uchar*p,uchar lr)
  uchar i,ch;
  if(lr=='L')
    for(i=0;i<8;i++)
      ch=*p;
      p++;
      Write_data_left(ch);
  if(lr=='R')
    for(i=0;i<8;i++)
      ch=*p;
      p++;
      Write_data_right(ch);
void clear()
uchar i,j,disp_page;
for(i=0;i<8;i++)
disp_page=0xb8+i;
Write_cmd_left(disp_page);
Write_cmd_left(0x40);
for(j=0;j<64;j++)
Write_data_left(0x00);
for(i=0;i<8;i++)
disp_page=0xb8+i;
Write_cmd_right(disp_page);
Write_cmd_right(0x40);
for(j=0;j<64;j++)
Write_data_right(0x00);
void init()
  Write_cmd_left(0x3e);
  Write_cmd_right(0x3e);
  Write_cmd_left(0x3f);
  Write_cmd_right(0x3f);
  Write_cmd_left(0xc0);
  Write_cmd_right(0xc0);
int main(void)
  /* Infinite loop */
     RCC_Configuration();
     NVIC_Configuration();
     GPIO_Configuration();
     clear();
     Delay(300);
     init();
     Delay(300);
  while (1)
       Write_cmd_left(0xb8);
        for(uchar i=0;i<4;i++)
  led_disp(table[i],'L');
*Function   Name      :RCC_Configuration.
*Descriprion          :configures the different system clocks.
*Input                :None
*Output               :None
*Return               :None
  ErrorStatus HSEStartUpStatus;
  /*RCC system reset(for debug purpose)*/
  RCC_DeInit();//将外设RCC寄存器重设为缺省值
  /*Enable HSE   打开外部时钟*/
  RCC_HSEConfig(RCC_HSE_ON);
  /*Wait till HSE is read */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();//等待HSE起振
  if(HSEStartUpStatus==SUCCESS)//起振成功
    /*Enable PrefetchBuffer 打开flash的预存储功能*/
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /*FLASH 2 Wait state*/
    FLASH_SetLatency(FLASH_Latency_2);//设置代码延时值
    /*HCLK=syclk*/
    RCC_HCLKConfig(RCC_SYSCLK_Div1);//设置AHB时钟等于系统时钟
    /*PCLK2=HCLK*/
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /*RCLK1=HCLK*/
    RCC_PCLK1Config(RCC_HCLK_Div2);
    /*PLLCLK=8MHZ*9=72MHZ*/
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_9);
    /*Enable PLL*/
    RCC_PLLCmd(ENABLE);
    /*Wait till PLL is ready*/
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY)==RESET)
    /*Select PLL as system clock source*/
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /*Wait till pll used as system clock source*/
    while(RCC_GetSYSCLKSource() !=0x08)
   /*打开相应的外部时钟:GPIOF*/
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOF, ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
  else
*Function   Name      :NVIC_Configuration.
*Descriprion          :configures Vector Table base location.
*Input                :None
*Output               :None
*Return               :None
    #ifdef VECT_TAB_RAM
  /*Set the vector table base location at 0x20000000*/
  NVIC_SetVectorTable(NVIC_VectTab_RAM,0X0);
    #else
    NVIC_SetVectorTable(NVIC_VectTab_FLASH,0x0);
    #endif
  GPIO_InitStructure.GPIO_Pin=GPIO_Pin_All;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                                 //设置GPIO的工作状态
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;                               //设置GPIO的速度
  GPIO_Init(GPIOF, &GPIO_InitStructure);
  GPIO_Init(GPIOA, &GPIO_InitStructure);
                        延时函数
void Delay(vu32 nCount)
  for(; nCount != 0; nCount--);
baishuiyang 发表于 2014-4-20 21:41 | 显示全部楼层
