请问一下这句啥意思?FROM MSP430
2990|2
 楼主| sioca 发表于 2011-4-14 17:12 | 显示全部楼层 |阅读模式
“This means the
low-power modes may be affected by the choice for the WDT+ clock”
附上CONTEXT:
The WDT+ module provides a fail-safe clocking feature assuring the clock to
the WDT+ cannot be disabled while in watchdog mode. This means the
low-power modes may be affected by the choice for the WDT+ clock. For
example, if ACLK is the WDT+ clock source, LPM4 will not be available,
because the WDT+ will prevent ACLK from being disabled. Also, if ACLK or
SMCLK fail while sourcing the WDT+, the WDT+ clock source is automatically
switched to MCLK. In this case, if MCLK is sourced from a crystal, and the
crystal has failed, the fail-safe feature will activate the DCO and use it as the
source for MCLK.
CIOneTwo 发表于 2011-4-18 10:45 | 显示全部楼层
字面意思是WDT+时钟的选择可能会影响低功耗模式
老鱼探戈 发表于 2011-5-1 16:52 | 显示全部楼层
楼上正解
