 代码如下:
 我的目的是检测ICP1信号。这是一个测试的程序。#include <avr/io.h>
#include <avr/interrupt.h>
#define F_CPU 8000000UL
#include <util/delay.h>
unsigned short icp1_tmr1;
unsigned short icp1_tmr2;
unsigned short icp1_cnt;
unsigned char icp1_ok;
inline void gpio_init(void)
        DDRA = 0x0f;//LED gpio
        DDRC = 0x00;
        PORTC =0x01;//接key1的PC0口输入,上拉有效
        DDRD = 0x00;
        PORTD =0x10;//接红外一体接收头的引脚为输入,上拉有效
        SFIOR = 0x00;//全局上拉使能。默认使能
inline int chk_key1(void)
        if( !(PINC & 0x01))
                _delay_ms(20);
                if( !(PINC &0x01))
                        return 1;
        return 0;
inline void icp1_init(void)
        icp1_cnt = 0;
ISR(TIMER1_CAPT_vect)
        if(icp1_cnt > 0)
                TIMSK &= ~_BV(TICIE1); //使能T/C1输入捕捉中断。没定是否需要T/C1溢出中断
PORTA = 0x02;//LED灯测试
_delay_ms(1000);
        else if(icp1_cnt == 0)
PORTA = ~PORTA;//LED灯测试
                icp1_tmr1 = ICR1;
        icp1_cnt++;
int main(void)
        gpio_init();
        TCCR1B = 0x01;//icp1下降沿输入触发捕捉,1分频 . T/C1正常计数方式
        sei();
        while(1)
                if(chk_key1())
                        icp1_init();
        TIMSK |= _BV(TICIE1); //使能T/C1输入捕捉中断。没定是否需要T/C1溢出中断
        return 0;
下载atmega128a板子上测试发现,一直运行:
 PORTA = ~PORTA;
 icp1_tmr1 = ICR1;
 而从来都没icp1_cnt > 0的情况。
 为何下次捕捉中断时,icp1_cnt还是0呢? 请指教
 环境:
 avr-gcc (GCC) 4.3.2
 Copyright (C) 2008 Free Software Foundation, Inc.
 This is free software; see the source for copying conditions.  There is NO
 warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
