PSoC Designer下面Documentation里的好东西
12061|2
 楼主| Go_PSoC 发表于 2011-5-18 15:50 | 显示全部楼层 |阅读模式
PSoC Designer下面Documentation里面有很多好东西,可能有些新接触psoc的朋友还没有看到,里面有TRM,datasheet,用户模块datasheet,应用笔记,各种设计指南的等等,好多设计所需的东西都可以找到。
 楼主| Go_PSoC 发表于 2011-5-18 15:56 | 显示全部楼层
This document is a catalog of some the important documentation available with PSoC Designer.
User Guides
PSoC Designer IDE (Integrated Development Environment) Guide
Updated and completely rewritten for PSoC Designer 5. Some last minute changes to the interface are not reflected.
PSoC Designer Assembly Language Guide
The PSoC Designer Assembly Language Guide documents the assembly language instruction set for the M8C microcontroller. Any details about the assembler itself are specific to ImageCraft.
PSoC Designer C Language Compiler User Guide
Details the ImageCraft C Compiler
PSoC Designer Libraries Guide
PSoC Designer math libraries in both C and assembly that you can use in your projects.
PSoC Mixed-Signal Array Technical Reference Manual
Technical Reference for the CY8C29x66, CY8C27x43, CY8C24x94, CY8C24x23, CY8C24x23A, CY8C22x13, CY8C21x34, CY8C21x23, CY7C64215, CY7C603xx, and CYWUSB6953 families of chips. For technical reference manuals for other Cypress devices, visit http://www.cypress.com.
PSoC® CY8C20x34, CY8C20x24 Technical Rerence Manual
Technical Reference for the CY8C20x34 and CY8C20x24 families of chips.
PSoC® CY8C24533 Technical Reference Manual
Technical Reference for the CY8C24533.
WirelessUSB™ LP and PRoC™ LP Technical Reference Manual
Technical Reference for the CYRF6936, CYRF69213, and CYRF69103 families of chips.
PSoC Designer ICE (In Circuit Emulator) User Guide
Use this guide to install and troubleshoot connection problems with the ICE Cube and ICE-4000 In- Circuit Emulator (ICE). Both PSoC ICE units provide significant debugging functionality that with full two-way communication between the ICE and your computer.
PSoC Express CapSense Guide
How to create your first CapSense project in PSoC Designer using the CY3213-CapSense board.
EZ Color High Brightness LED Guide
How to create your first EZ Color project in PSoC Designer using the CY3261A-RGB EZ-Color Evaluation Kit.
HI-Tech Migration Guide
If you formerly used the ImageCraft PSoC C compiler and you wish to switch to the HI-TECH C® PRO compiler, this manual details changes you may need to make and discusses the basic differences between the two compilers.
 楼主| Go_PSoC 发表于 2011-5-18 15:57 | 显示全部楼层
上面是里面内容的一部分
