[技术问答] UNC220串口2问题
1045|2
 楼主| wangcf20006 发表于 2017-10-21 11:06 | 显示全部楼层 |阅读模式
* @file     main.c
* @version  V2.00
* $Revision: 7 $
* $Date: 14/11/27 2:37p $
* @brief    Transmit and receive data from PC terminal through RS232 interface.
* @note
* Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NUC200Series.h"
#define PLL_CLOCK           50000000
#define RXBUFSIZE 1024
//#define UART_WRITE(uart, u8Data)    ((uart)->THR = (u8Data))
/* Global variables        */
uint8_t g_u8RecData[RXBUFSIZE]  = {0};
volatile uint32_t g_u32comRbytes = 0;
volatile uint32_t g_u32comRhead  = 0;
volatile uint32_t g_u32comRtail  = 0;
volatile int32_t g_bWait         = TRUE;
/* Define functions prototype        */
int32_t main(void);
void UART_TEST_HANDLE(void);
void UART_FunctionTest(void);
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC 22.1184MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external XTAL 12MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for external XTAL clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    CLK_EnableModuleClock(UART1_MODULE);
    CLK_EnableModuleClock(UART2_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    CLK_SetModuleClock(UART1_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    CLK_SetModuleClock(UART2_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    /* Init I/O Multi-function        */
    /* Set GPB multi-function pins for UART0 RXD and TXD */
    SYS->GPB_MFP &= ~(SYS_GPB_MFP_PB0_Msk | SYS_GPB_MFP_PB1_Msk);
    SYS->GPB_MFP |= SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD;
    /* Set GPB multi-function pins for UART1 RXD and TXD */
    SYS->GPB_MFP &= ~(SYS_GPB_MFP_PB4_Msk | SYS_GPB_MFP_PB5_Msk);
    SYS->GPB_MFP |= SYS_GPB_MFP_PB4_UART1_RXD | SYS_GPB_MFP_PB5_UART1_TXD;
   /* Set GPB multi-function pins for UART2 RXD and TXD */
    SYS->GPB_MFP &= ~(SYS_GPD_MFP_PD14_Msk | SYS_GPD_MFP_PD15_Msk);
    SYS->GPB_MFP |= SYS_GPD_MFP_PD14_UART2_RXD | SYS_GPD_MFP_PD15_UART2_TXD;
void UART0_Init()
    /* Init UART        */
    /* Reset UART0 */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
void UART1_Init()
    /* Init UART        */
    /* Reset UART0 */
    SYS_ResetModule(UART1_RST);
    UART_Open(UART1, 115200);
void UART2_Init()
    /* Init UART        */
    /* Reset UART0 */
    SYS_ResetModule(UART2_RST);
    UART_Open(UART2, 115200);
/* UART Test Sample        */
/* Test Item        */
/* It sends the received data to HyperTerminal.                                                            */
/* MAIN function        */
int main(void)
           int8_t i = 0;
           int16_t del = 0;
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf and testing */
    UART0_Init();
    UART1_Init();
    UART2_Init();
    /* SAMPLE CODE        */
    printf("\n\nCPU @ %dHz\n", SystemCoreClock);
    printf("\n\nUART Sample Program\n");
    for(i=0;i<16;i++)
       UART_WRITE(UART1,i);
    /* UART sample function */
  //  UART_FunctionTest();
    while(1)
                        UART_WRITE(UART2,i);
                        i++;
                        del = 60000;
                        while(del--);
串口0 与串口1 是正常的,串口2怎么试都不行,请问是什么问题?
heisexingqisi 发表于 2017-10-21 20:38 | 显示全部楼层
好多人这么说,可能串口2的配置跟1和0是不同的。
稳稳の幸福 发表于 2017-10-22 21:03 | 显示全部楼层
貌似好多芯片大家都会有最后一个口不会用
