怎么用红牛开发板的TFT屏显示灰度图?
3601|3
 楼主| 赵小木2012 发表于 2011-5-26 10:46 | 显示全部楼层 |阅读模式
怎么用红牛开发板的TFT屏显示灰度图?我写了个程序 但是处理后显示的图片乱麻麻的,不是灰度图捏。请大家帮我看一下,感激~~~
/* Includes ------------------------------------------------------------------*/
#include "lcd.h"
#include "stm32f10x_lib.h"
#include "platform_config.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
static vu32 TimingDelay = 0;
ErrorStatus HSEStartUpStatus;
extern unsigned char Image_Table[];
unsigned char Gray_Table[82944];
//unsigned char Gray_Table[27648];
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void InterruptConfig(void);
void NVIC_Configuration(void);
void Delay(vu32 nCount);
void Decrement_TimingDelay(void);
void SysTick_Config(void);
/* Private functions ---------------------------------------------------------*/
* Function Name  : main
* Description    : Main program.
* Input          : None
* Output         : None
* Return         : None
int main(void)
u32 i;
#ifdef DEBUG
  debug();
#endif
  /* System Clocks Configuration */
  RCC_Configuration();
   /* Interrupt Configuration */
  InterruptConfig();
  /* Configure the systick */
  SysTick_Config();
  /* Initialize the LCD */
  STM3210E_LCD_Init();
  /* Clear the LCD */
  LCD_Clear(Black);
  LCD_SetDisplayWindow(00, 00, 239, 319);
  LCD_WriteBMP(48, 64, 144, 192, Image_Table);
  for(i=0;i<100000;i++);
BMPtoGray(Image_Table,Gray_Table);
  LCD_Clear(Black);
  LCD_WriteBMP(48, 64, 144, 192, Gray_Table);
  void BMPtoGray(u8 *bitmap,u8 *graymap)
  u32 i;
for(i=0;i<27648;i++)
  *graymap=(*bitmap*30+*(bitmap+1)*59+*(bitmap+2)*11)/100;
  *(graymap+1)= *(graymap+2)=*graymap;
  graymap+=3;
  bitmap+=3;
 楼主| 赵小木2012 发表于 2011-5-27 16:01 | 显示全部楼层
没人回复。。。难道这个问题非主流了?
fastolf 发表于 2011-5-28 10:06 | 显示全部楼层
还真没整过红牛开发板,火牛到时玩过......
beandy 发表于 2013-1-7 21:12 | 显示全部楼层
TFT屏显示灰度图  这才是重点吧  lz找到解决的方法了吗
