[STM32L0] STM32L05 iiC只能进一次中断问题
2296|2
 楼主| mochou 发表于 2017-11-3 08:31 | 显示全部楼层 |阅读模式
各位,我用STM32L05X官方寄存器版例程I2C初始化和中断函数,只能进一次I2C中断,大家帮看看哪里配置不对。
  * Brief   This function configures I2C1, slave.
  * Param   None
  * Retval  None
void Configure_I2C1_Slave(void)
  /* Configure RCC for I2C1 */
  /* (1) Enable the peripheral clock I2C1 */
  /* (2) Use APBCLK for I2C CLK */
  RCC->APB1ENR |= RCC_APB1ENR_I2C1EN; /* (1) */
  RCC->CCIPR &= ~RCC_CCIPR_I2C1SEL; /* (2) */
  /* Configure I2C1, slave */
  /* (3) Timing register value is computed with the AN4235 xls file,
         fast Mode @400kHz with I2CCLK = 16MHz, rise time = 100ns,
         fall time = 10ns */
  /* (4) Periph enable, address match interrupt enable, receive interrupt enable */
  /* (5) 7-bit address = 0x5A */
  /* (6) Enable own address 1 */
  I2C1->TIMINGR = (unsigned int)0x00300619; /* (3) */
  I2C1->CR1 = I2C_CR1_PE | I2C_CR1_RXIE | I2C_CR1_ADDRIE; /* (4) */
  I2C1->OAR1 |= (unsigned int)(I2C1_OWN_ADDRESS << 1); /* (5) */
  I2C1->OAR1 |= I2C_OAR1_OA1EN; /* (6) */
  /* Configure IT */
  /* (7) Set priority for I2C1_IRQn */
  /* (8) Enable I2C1_IRQn */
  NVIC_SetPriority(I2C1_IRQn, 0); /* (7) */
  NVIC_EnableIRQ(I2C1_IRQn); /* (8) */
  * Brief   This function handles I2C1 interrupt request.
  * Param   None
  * Retval  None
void I2C1_IRQHandler(void)
  unsigned int I2C_InterruptStatus = I2C1->ISR; /* Get interrupt status */
  if((I2C_InterruptStatus & I2C_ISR_ADDR) == I2C_ISR_ADDR)
    I2C1->ICR |= I2C_ICR_ADDRCF; /* Address match event */
  else if((I2C_InterruptStatus & I2C_ISR_RXNE) == I2C_ISR_RXNE)
    /* Read receive register, will clear RXNE flag */
     CLearLinkErrorCnt();
     if(iicRecDataFlag == FALSE)
       iicRecBuf[iicRecBufIndex] =  I2C1->RXDR;
       iicRecBufIndex++;
       if(iicRecBufIndex == IICWINFOLEN)
         iicRecDataFlag = TRUE;
         iicRecBufIndex = 0;
  else
    error = ERROR_I2C; /* Report an error */
    NVIC_DisableIRQ(I2C1_IRQn); /* Disable I2C1_IRQn */
mmuuss586 发表于 2017-11-3 09:07 | 显示全部楼层
IIC中断没用过,帮不了你;
 楼主| mochou 发表于 2017-11-4 15:33 | 显示全部楼层
没人帮看下吗
