FPGA设计重利用方法
2233|7
 楼主| AutoESL 发表于 2011-5-27 11:46 | 显示全部楼层 |阅读模式
Table of Contents
1.1 System-on-a-Reprogrammable Chip ....................................................................3
1.2 Why Use an FPGA?.............................................................................................4
1.2.1 ASIC vs. FPGA Design Flows .....................................................................4
1.3 A Common Design Reuse Strategy ......................................................................6
1.4 Definitions & Acronyms ......................................................................................7
2.1 System Synthesis and Timing Issues ....................................................................8
2.1.1 Synchronous vs. Asynchronous Design Style ...............................................8
2.1.3 System Clocking and Clock Distribution......................................................9
2.2 Memory and Memory Interface..........................................................................12
2.2.1 On-Chip Memory..........................................................................................12
2.2.2 Interfacing to Large Memory Blocks ..........................................................13
2.3 External Operability (I/O Standards) ..................................................................14
3.1 Abundance of Registers .....................................................................................16
3.1.1 Duplicating Registers .................................................................................16
3.1.2 Partitioning at Register Boundary...............................................................18
3.1.3 One-Hot State Machines.............................................................................18
3.1.4 Pipelining...................................................................................................18
3.2 Case and IF-Then-Else.......................................................................................20
3.3 Critical Path Optimization..................................................................................23
3.4 Tristate vs. Mux Buses.......................................................................................24
3.5 Arithmetic Functions..........................................................................................24
4.1 HDL Simulation and Testbench .........................................................................26
4.2 Static Timing .....................................................................................................26
4.3 Formal Verification............................................................................................27
1 Introduction......................................................................................... 3
2 System Level Reuse Issues for FPGAs ...............................................
21IC之星 发表于 2011-5-27 14:56 | 显示全部楼层
下了
谢谢AutoESL
老大的幸福 发表于 2011-5-27 20:58 | 显示全部楼层
谢谢了
奔腾2.0 发表于 2011-5-27 21:48 | 显示全部楼层
下了,谢楼主
午后苦丁茶 发表于 2011-5-27 23:07 | 显示全部楼层
不错,值得看一看。
快乐出发 发表于 2011-5-27 23:47 | 显示全部楼层
谢谢。
 楼主| AutoESL 发表于 2011-5-28 10:00 | 显示全部楼层
5# 午后苦丁茶
谢谢
hjjnet 发表于 2011-5-28 19:03 | 显示全部楼层
谢谢,拜读一下
个人签名:天使宝贝 博客IT人生 From C/C++/SystemC to Xilinx FPGA
