[MCU] 24C02的问题
1758|14
 楼主| 谢谢谢林达 发表于 2017-11-12 10:59 | 显示全部楼层 |阅读模式
ic, iic, TE, AD, ADDR
// Example of IIC communication between 9S12XEP100 and EEPROM FM24C256
// BUSCLK = 8MHz
// SCL    = 91kHz
// I2C1 is used for commnication
#include <hidef.h>      /* common defines and macros */
#include "derivative.h"      /* derivative-specific definitions */
#define MaxLen     128 //
#define  slaveread  0xA1
#define  slavewrite 0xA0
unsigned char RD_data;
byte WrData[8];
byte RdData[8];
byte RdBuf;
word length;
unsigned char x;
typedef union
  word EE_Address;
  struct
    byte Address_H;
    byte Address_L;
  }Bytes;
}tAddr;
tAddr ADDR;
#define Address ADDR.EE_Address
#define Addr_L ADDR.Bytes.Address_L
#define Addr_H ADDR.Bytes.Address_H
//******  Init routines  *******************
void IIC0_init(void)
        IIC0_IBFD = 0x4C;
        IIC0_IBAD = 0x00;
        IIC0_IBCR = 0x80;
        //IIC0_IBSR_IBAL = 1;
void IIC_write_nbytes(word addr, byte len)
  byte i;
Address = addr; // load address;
IIC0_IBCR_TXAK = 0; ;
IIC0_IBCR |= 0x30; // RX/TX = 1; MS/SL = 1; TXAK = 0;
// And generate START condition;
//-------start of transmit first byte to IIC bus-----
IIC0_IBDR = slavewrite; // Address the slave and set up for master transmit;
while (!IIC0_IBSR_IBIF); // wait until IBIF;
IIC0_IBSR_IBIF=1; // clear the interrupt event flag;
while(IIC0_IBSR_RXAK); // check for RXAK;
//-----Slave ACK occurred------------
IIC0_IBDR = Addr_H; // Send high byte of the word address;
IIC0_IBDR = Addr_L; // Send low byte of the word address;
for(i=0;i<len;i++)
  IIC0_IBDR = WrData[i];//data;
IIC0_IBCR_MS_SL = 0; // generate STOP condition;
void IIC_read_nbytes(word addr,byte len)
byte dummy;
byte i;
Address = addr;
length=len;
if(length>=MaxLen)
  length=MaxLen;
IIC0_IBCR_TXAK = 0; // TXAK = 0;
IIC0_IBDR = Addr_H; // Send high byte of word address;
IIC0_IBDR = Addr_L; // Send low byte of word address;
IIC0_IBCR_RSTA = 1; // set up repeated start;
IIC0_IBDR = slaveread; // (slave_address) | (RW = 1);
while (IIC0_IBSR_RXAK); // check for RXAK;
IIC0_IBCR_TX_RX = 0; // set up to receive;
dummy=IIC0_IBDR;//RD_data = IIC0_IBDR; // dummy read;
for(i=0;i<length;i++)
  if(i==7){
    while(!IIC0_IBSR_IBIF);
    IIC0_IBSR_IBIF = 1;
    RdData[7]=IIC0_IBDR;
  else{
  IIC0_IBSR_IBIF=1;
  RdData[i]=IIC0_IBDR;
IIC0_IBCR_TXAK = 1; // acknowledge disable;
IIC0_IBCR_MS_SL = 0; // generate stop signal;
RD_data = IIC0_IBDR; // read right data;
//******  main routines  *******************
void main(void)
  unsigned int i;
  unsigned int j,k;
  //---- IIC -----
  IIC0_init();
  WrData[0]=1;
  WrData[1]=0;
  WrData[2]=0;
  WrData[3]=8;
  WrData[4]=6;
  WrData[5]=1;
  WrData[6]=1;
  WrData[7]=255;
  //---- main cycle ---
  //LedPad22Dir=1;
  //LedCpu=1;
   do{
   IIC_write_nbytes(0x0064,8);
   for(j=0;j<0x1000;j++);
     IIC_read_nbytes(0x0064,8);
  for(j=0;j<50000;j++);
  //LedCpu=~LedCpu;
while(1);
  i+=8;
这是我用的程序,二楼写问题
 楼主| 谢谢谢林达 发表于 2017-11-12 11:06 | 显示全部楼层
问题就是,程序跑得不是很理想,程序就走到这就走不动了。一直等待一个ACK信号。这是怎么回事呢。但是有时候能跑通!
gxs64 发表于 2017-11-12 12:34 | 显示全部楼层
注意io口方向
 楼主| 谢谢谢林达 发表于 2017-11-12 14:41 | 显示全部楼层
我用的芯片有IIC通信寄存器。飞思卡尔s12系列的
gxs64 发表于 2017-11-12 16:52 | 显示全部楼层
如果是软件IIC,一定有方向问题。
 楼主| 谢谢谢林达 发表于 2017-11-12 18:02 | 显示全部楼层
如果是软件IIC,一定有方向问题。
寄存器中有一位是设置主从的,出现这种情况的话,主从这一位不能有效置位,也就是说他是从,不能设置为主。不知道咋回事,。。。
linqing171 发表于 2017-11-12 20:21 | 显示全部楼层
莫非仲裁失败? 上拉电阻太大了?
 楼主| 谢谢谢林达 发表于 2017-11-13 09:31 | 显示全部楼层
莫非仲裁失败? 上拉电阻太大了?
不知道啊老哥,IIC通信是不是需要先读后写还是先写后读呢?如果我随机读取数据,会出现数据丢失的问题。这有事怎么回事呢?程序我看了三四遍,,感觉没啥大毛病啊
 楼主| 谢谢谢林达 发表于 2017-11-13 09:35 | 显示全部楼层
莫非仲裁失败? 上拉电阻太大了?
就比如我在0x0102地址写了个1,0,0,8,6,11,255八个字节,但是我读出来是这样的,是怎么回事呢?
linqing171 发表于 2017-11-13 14:14 | 显示全部楼层
24C02没有那么多地址。
如果从0地址一次只能写4个字节,那么从0x02地址开始一次就只能写4-2=2个;从3地址开始只能写4-3=1个;从4地址开始又能一次写4个了。
 楼主| 谢谢谢林达 发表于 2017-11-14 16:51 | 显示全部楼层
24C02没有那么多地址。
如果从0地址一次只能写4个字节,那么从0x02地址开始一次就只能写4-2=2个;从3地址开 ...
我试的可以写八个啊,老哥。
ningling_21 发表于 2017-11-15 14:23 | 显示全部楼层
我试的可以写八个啊,老哥。
24C02有多少字节的存储空间?
 楼主| 谢谢谢林达 发表于 2017-11-15 16:06 | 显示全部楼层
24C02有多少字节的存储空间?
2K,2048bit,也就是256个字节,地址从0x00-0xff
ningling_21 发表于 2017-11-15 16:08 | 显示全部楼层
空间只有256字节,怎么会有0x0102这个地址呢?
 楼主| 谢谢谢林达 发表于 2017-11-19 08:33 | 显示全部楼层
,我也找到这个问题了,!嘿嘿
