用C8051F580做串口通信,SBUF接收的数据一直是0X00,希望各位大神帮忙看下程序
1544|6
 楼主| zhm0620 发表于 2017-12-6 11:21 | 显示全部楼层 |阅读模式
VOID uart1_init()
           UINT8 SFRPAGE_save = SFRPAGE;
           SFRPAGE = ACTIVE2_PAGE;
        SCON1 = 0x10;                      // SCON1: 8-bit variable bit rate
                                       //        level of STOP bit is ignored
                                       //        RX enabled
                                       //        ninth bits are zeros
                                       //        clear RI1 and TI1 bits
        P3 &= 0xDF;
   if (SYSCLK / BAUDRATE / 2 / 256 < 1)
      TH1 = -(SYSCLK / BAUDRATE / 2);
      CKCON &= ~0x0B;                  // T1M = 1; SCA1:0 = 11
      CKCON |=  0x08;
   else if (SYSCLK / BAUDRATE / 2 / 256 < 4)
      TH1 = -(SYSCLK / BAUDRATE / 2 / 4);
      CKCON &= ~0x0B;                  // T1M = 0; SCA1:0 = 01
      CKCON |=  0x01;
   else if (SYSCLK / BAUDRATE / 2 / 256 < 12)
      TH1 = -(SYSCLK / BAUDRATE / 2 / 12);
      CKCON &= ~0x0B;                  // T1M = 0; SCA1:0 = 00
   else
      TH1 = -(SYSCLK / BAUDRATE / 2 / 48);
      CKCON &= ~0x0B;                  // T1M = 0; SCA1:0 = 10
      CKCON |=  0x02;
   TL1 = TH1;                          // Init Timer1
   TMOD &= ~0xF0;                      // TMOD: timer 1 in 8-bit autoreload
   TMOD |=  0x20;
   TR1 = 1;                            // START Timer1
//   TI1 = 1;                            // Indicate TX1 ready (SCON1)
//        EA = 1;
   EIE2 |= 0x08;
        SFRPAGE = SFRPAGE_save;
INTERRUPT(UART1_ISR, INTERRUPT_UART1)
//        EIE2 &= 0x00;
        if((SCON1 & 0x01)==0x01)   //如果接收中断标志RI1=1
//                SCON1  &= ~0x01;  /*清接收标志位*/
                P3 &= 0xDF;                          //P3.5=0,低--接收
                S_Uart1_Buffer[S_Uart1_Rx] = SBUF1&0xff;
                if( S_Uart1_Buffer[0] == 0x01)
                        S_Uart1_Rx = S_Uart1_Rx+1;
                else
                        S_Uart1_Rx = 0;
                if(S_Uart1_Rx == 8)
                        S_Uart1_Sta = 1; //
        SCON1  &= ~0x01;
//        SCON1  &= ~0x02;
//        EIE2 |= 0x08;                 /*清发送标志位*/
VOID c8051_port_init(VOID)
           SFRPAGE = CONFIG_PAGE;
        P0MDIN    = 0xF2;
    P1MDIN    = 0xF9;
    P2MDIN    = 0xFC;
    P0MDOUT   = 0xF2;
    P1MDOUT   = 0xC9;
    P2MDOUT   = 0xF8;
    P3MDOUT   = 0xDF;
    P0SKIP    = 0xFF;
    P1SKIP    = 0xFF;
    P2SKIP    = 0xF3;
    XBR2      = 0x42;
menfiss 发表于 2017-12-6 11:58 来自手机 | 显示全部楼层
这货有看门狗,默认打开。新手容易犯的错误是没关闭看门狗,所以一直重启
ningling_21 发表于 2017-12-6 14:16 | 显示全部楼层
注意交叉开关的配置
 楼主| zhm0620 发表于 2017-12-6 14:43 | 显示全部楼层
这货有看门狗,默认打开。新手容易犯的错误是没关闭看门狗,所以一直重启 ...
嗯嗯,关闭了
 楼主| zhm0620 发表于 2017-12-6 14:44 | 显示全部楼层
注意交叉开关的配置
P0MDIN    = 0xF2;
    P1MDIN    = 0xF9;
    P2MDIN    = 0xFC;
    P0MDOUT   = 0xF2;
    P1MDOUT   = 0xC9;
    P2MDOUT   = 0xF8;
    P3MDOUT   = 0xDF;
    P0SKIP    = 0xFF;
    P1SKIP    = 0xFF;
    P2SKIP    = 0xF3;
    XBR2      = 0x42;
我这样配置对吗?
ningling_21 发表于 2017-12-6 14:49 | 显示全部楼层
P0MDIN    = 0xF2;
    P1MDIN    = 0xF9;
    P2MDIN    = 0xFC;
我没有这芯片的资料,可以对照资料检查一下程序
menfiss 发表于 2017-12-7 21:19 | 显示全部楼层
交叉开关和端口配置好像有问题,P0SKIP    = 0xFF;把串口都跳过去了,应该不行。
silicon有个配置工具你没用过吧?
