[技术问答]
哪位大侠有新唐M051串口1的程序示范例子
1696|5
yexinyuan1212|  楼主 | 2017-12-21 17:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
小弟刚刚开始学习新唐M051系列芯片,希望各位大哥多多支持,先谢谢大家了。
xinxianshi| | 2017-12-22 09:41 | 只看该作者
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* $Revision: 10 $
* $Date: 15/05/22 2:52p $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Transmit and receive data with auto flow control.
*           This sample code needs to work with UART_Autoflow_Master.
* @note
* Copyright (C) 2011 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M051Series.h"
#define PLL_CLOCK           50000000
#define RXBUFSIZE 1024
/* Global variables        */
uint8_t g_u8SendData[12] = {0};
uint8_t g_u8RecData[RXBUFSIZE]  = {0};
volatile int32_t g_i32pointer = 0;
/* Define functions prototype        */
extern char GetChar(void);
int32_t main(void);
void AutoFlow_FunctionRxTest(void);
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC 22.1184MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external XTAL 12MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for external XTAL clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    CLK_EnableModuleClock(UART1_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    CLK_SetModuleClock(UART1_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD and TXD */
    SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
    SYS->P3_MFP |= (SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0);
    /* Set P1 multi-function pins for UART1 RXD and TXD */
    SYS->P1_MFP &= ~(SYS_MFP_P12_Msk | SYS_MFP_P13_Msk);
    SYS->P1_MFP |= (SYS_MFP_P12_RXD1 | SYS_MFP_P13_TXD1);
    /* Set P0 multi-function pins for UART1 RTS */
    SYS->P0_MFP = SYS->P0_MFP & (~SYS_MFP_P01_Msk) | SYS_MFP_P01_RTS1;
void UART0_Init()
    /* Init UART        */
    /* Reset UART0 */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
void UART1_Init()
    /* Init UART        */
    /* Reset UART1 */
    SYS_ResetModule(UART1_RST);
    /* Configure UART1 and set UART1 Baudrate */
    UART_Open(UART1, 115200);
/* MAIN function        */
int main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    /* Init UART1 for testing */
    UART1_Init();
    /* SAMPLE CODE        */
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
    printf("\n\nUART Sample Program\n");
    /* UART auto flow sample slave function */
    AutoFlow_FunctionRxTest();
    while(1);
/* ISR to handle UART Channel 1 interrupt event                                                            */
void UART1_IRQHandler(void)
    volatile uint32_t u32IntSts = UART1->ISR;;
    /* Rx Ready or Time-out INT */
    if(UART_GET_INT_FLAG(UART1, UART_ISR_RDA_INT_Msk) ||  UART_GET_INT_FLAG(UART1, UART_ISR_TOUT_INT_Msk))
        /* Handle received data */
        g_u8RecData[g_i32pointer] = UART_READ(UART1);
        g_i32pointer++;
/*  AutoFlow Function Test (Slave)        */
void AutoFlow_FunctionRxTest()
    uint32_t u32i;
    printf("\n");
    printf("+-----------------------------------------------------------+\n");
    printf("|     Pin Configure                                         |\n");
    printf("|    _______                                    _______     |\n");
    printf("|   |       |                                  |       |    |\n");
    printf("|   |Master |---TXD1(P1.3) <====> RXD1(P1.2)---| Slave |    |\n");
    printf("|   |       |---CTS1(P0.0) <====> RTS1(P0.1)---|       |    |\n");
    printf("|   |_______|                                  |_______|    |\n");
    printf("|                                                           |\n");
    printf("\n");
    printf("|       AutoFlow Function Test (Slave)                      |\n");
    printf("|  Description :                                            |\n");
    printf("|    The sample code needs two boards. One is Master and    |\n");
    printf("|    the other is slave. Master will send 1k bytes data     |\n");
    printf("|    to slave.Slave will check if received data is correct  |\n");
    printf("|    after getting 1k bytes data.                           |\n");
    printf("|    Press any key to start...                              |\n");
    GetChar();
    /* Enable RTS and CTS autoflow control */
    UART_EnableFlowCtrl(UART1);
    /* Set RTS Trigger Level as 8 bytes */
    UART1->FCR &= ~UART_FCR_RTS_TRI_LEV_Msk;
    UART1->FCR |= UART_FCR_RTS_TRI_LEV_8BYTES;
    /* Enable RDA\RLS\RTO Interrupt  */
    UART_ENABLE_INT(UART1, (UART_IER_RDA_IEN_Msk | UART_IER_RLS_IEN_Msk | UART_IER_RTO_IEN_Msk));
    /* Set RX Trigger Level as 8 bytes */
    UART1->FCR &= ~UART_FCR_RFITL_Msk;
    UART1->FCR |= UART_FCR_RFITL_8BYTES;
    /* Set Timeout time 0x3E bit-time and time-out counter enable */
    UART_SetTimeoutCnt(UART1, 0x3E);
    /* Enable UART1 IRQ */
    NVIC_EnableIRQ(UART1_IRQn);
    printf("\n Starting to receive data...\n");
    /* Wait for receive 1k bytes data */
    while(g_i32pointer < RXBUFSIZE);
    /* Compare Data */
    for(u32i = 0; u32i < RXBUFSIZE; u32i++)
        if(g_u8RecData[u32i] != (u32i & 0xFF))
            printf("Compare Data Failed\n");
            while(1);
    printf("\n Receive OK & Check OK\n");
    /* Disable UART1 IRQ */
    NVIC_DisableIRQ(UART1_IRQn);
    /* Disable RDA\RLS\RTO Interrupt */
    UART_DISABLE_INT(UART1, (UART_IER_RDA_IEN_Msk | UART_IER_RLS_IEN_Msk | UART_IER_RTO_IEN_Msk));
去下载官方的BSP开发包,在新唐这个芯片下面有个软件,你点进去找到BSP。
天灵灵地灵灵| | 2017-12-22 22:27 | 只看该作者
* $Revision: 9 $
*           This sample code needs to work with UART_Autoflow_Slave.
* @note
#include <stdio.h>
int32_t main(void);
void AutoFlow_FunctionTxTest(void);
void SYS_Init(void)
    /* Set P0 multi-function pins for UART1 CTS */
    SYS->P0_MFP = SYS->P0_MFP & (~SYS_MFP_P00_Msk) | SYS_MFP_P00_CTS1;
void UART0_Init()
    /* Init UART        */
    /* Reset UART0 */
void UART1_Init()
    /* Init UART        */
    /* Reset UART1 */
/* MAIN function        */
int main(void)
    SYS_UnlockReg();
    SYS_Init();
    SYS_LockReg();
    UART0_Init();
    UART1_Init();
    /* SAMPLE CODE        */
    /* UART auto flow sample master function */
    AutoFlow_FunctionTxTest();
    while(1);
/*  AutoFlow Function Tx Test        */
void AutoFlow_FunctionTxTest()
    uint32_t u32i;
    printf("\n");
    printf("|                                                           |\n");
    printf("\n");
    printf("|       AutoFlow Function Test (Master)                     |\n");
    GetChar();
    /* Send 1k bytes data */
        /* Send 1 byte data */
        UART_WRITE(UART1, u32i & 0xFF);
        /* Wait if Tx FIFO is full */
        while(UART_IS_TX_FULL(UART1));
    printf("\n Transmit Done\n");
xinxianshi| | 2017-12-26 19:37 | 只看该作者
楼主有开发板没,应该去官网下载开发用的手册和驱动库BSP,板级支持包。
学海无涯007| | 2018-1-5 15:12 | 只看该作者
学习了的,官网开发包里比较详细。
