[FPGA] FPGA PCIe高性能加速平台 FPGA阵列 SRIO RapidIO 集成CPCIe/VPX系统
38833|174
 楼主| 为FPGA献身 发表于 2018-10-19 11:01 | 显示全部楼层
drentsi 发表于 2018-10-16 20:57
KU060的
1.1 On-Chip Components
官网的KU040  VCCINT 才30A电流
drentsi 发表于 2018-10-19 11:05 | 显示全部楼层
跟设计有关,按开发板的设计能分分钟烧冒烟
 楼主| 为FPGA献身 发表于 2018-10-19 11:46 | 显示全部楼层
哥,芯片的实际功耗摆在面前的。按照你那个软件编译的参数。芯片功耗都100多W了。实际功耗没得那么高。
 楼主| 为FPGA献身 发表于 2018-10-19 11:49 | 显示全部楼层
对比K325的 功耗  你就知道了。
 楼主| 为FPGA献身 发表于 2018-10-19 11:51 | 显示全部楼层
反正我的板子电流可以扩大一倍。这个都不是问题
drentsi 发表于 2018-10-19 12:56 | 显示全部楼层
再来看一个,K325T的,92%的资源,驱动到了400MHz,功耗55瓦
| Device           : xc7k325tffg676-2
| Design State     : routed
| Grade            : commercial
| Process          : typical
| Characterization : Production
Power Report
Table of Contents
1. Summary
1.2 Power Supply Summary
1.3 Confidence Level
2. Settings
2.1 Environment
2.2 Clock Constraints
3. Detailed Reports
3.1 By Hierarchy
1. Summary
| Total On-Chip Power (W)  | 55.085 (Junction temp exceeded!) |
| Design Power Budget (W)  | Unspecified*                     |
| Power Budget Margin (W)  | NA                               |
| Dynamic (W)              | 51.596                           |
| Device Static (W)        | 3.489                            |
| Effective TJA (C/W)      | 1.9                              |
| Max Ambient (C)          | 0.0                              |
| Junction Temperature (C) | 125.0                            |
| Confidence Level         | Medium                           |
| Setting File             | ---                              |
| Simulation Activity File | ---                              |
| Design Nets Matched      | NA                               |
* Specify Design Power Budget using, set_operating_conditions -design_power_budget <value in Watts>
| On-Chip        | Power (W) | Used     | Available | Utilization (%) |
| Clocks         |     3.248 |        6 |       --- |             --- |
| Slice Logic    |    25.861 |   604661 |       --- |             --- |
|   LUT as Logic |    24.596 |   188762 |    203800 |           92.62 |
|   Register     |     1.264 |   289171 |    407600 |           70.94 |
|   CARRY4       |    <0.001 |       81 |     50950 |            0.16 |
|   F7/F8 Muxes  |    <0.001 |      131 |    203800 |            0.06 |
|   Others       |     0.000 |      205 |       --- |             --- |
| Signals        |    22.383 |   318125 |       --- |             --- |
| PLL            |     0.104 |        1 |        10 |           10.00 |
| I/O            |    <0.001 |        4 |       400 |            1.00 |
| Static Power   |     3.489 |          |           |                 |
| Total          |    55.085 |          |           |                 |
| Source    | Voltage (V) | Total (A) | Dynamic (A) | Static (A) |
| Vccint    |       1.000 |    54.512 |      51.494 |      3.018 |
| Vccaux    |       1.800 |     0.251 |       0.057 |      0.194 |
| Vcco33    |       3.300 |     0.000 |       0.000 |      0.000 |
| Vcco25    |       2.500 |     0.000 |       0.000 |      0.000 |
FPGA0FLASH 发表于 2018-10-19 17:14 | 显示全部楼层
技术大牛
 楼主| 为FPGA献身 发表于 2018-10-19 20:23 | 显示全部楼层
| Des ...
好的。明白你的意思了。可以加大VCCINT  电流
 楼主| 为FPGA献身 发表于 2018-10-26 22:03 | 显示全部楼层
板子回来了,即将和大家见面了。
zhangmangui 发表于 2018-10-29 21:45 | 显示全部楼层
板子回来了,即将和大家见面了。 ...
期待   看看什么样
weekylee87 发表于 2018-10-30 18:17 来自手机 | 显示全部楼层
有钱淫,俺都是单位经费才敢做,我也做FPGA的,不过一直用的xilinX的,PCIE驱动和软件都做过,不过是32位系统的,有兴趣可以交流下QQ.574154681
 楼主| 为FPGA献身 发表于 2018-11-4 10:47 | 显示全部楼层
有钱淫,俺都是单位经费才敢做,我也做FPGA的,不过一直用的xilinX的,PCIE驱动和软件都做过,不过是32位系 ...
加不了。你要验证
 楼主| 为FPGA献身 发表于 2018-11-4 10:59 | 显示全部楼层
K7 420T已经出炉,测试完成后。继续前行 XCKU系列
zhangmangui 发表于 2018-11-5 19:05 | 显示全部楼层
我最近做了ZUP    欢迎交流
 楼主| 为FPGA献身 发表于 2018-11-5 20:35 | 显示全部楼层
我最近做了ZUP    欢迎交流
ZUP我也要做。只是一步一步慢慢来。你用的ZUP哪款芯片?
zhangmangui 发表于 2018-11-6 22:51 | 显示全部楼层
我用的11EG     一起交流啊    你做的偏硬件吗
zhangmangui 发表于 2018-11-6 22:52 | 显示全部楼层
你们用在什么上    你在北京吗   能否一起搞点事  呵呵呵
 楼主| 为FPGA献身 发表于 2018-11-7 12:19 | 显示全部楼层
我在成都  QQ  906606596
zhangmangui 发表于 2018-11-7 22:02 | 显示全部楼层
我在成都  QQ  906606596
已添加    qq
这个帖子大家都在搞xilinx啊,少见,讨论了10多页,我创建了一个qq群方便大家一起讨论。交流技术经验和xilinx设计时候的一些坑。避免成本的浪费。qq群:377628058 发表于 2018-11-23 14:36
