一个对采样值分段处理的算法
1784|0
 楼主| joyme 发表于 2011-6-28 14:11 | 显示全部楼层 |阅读模式
做AVR电源,两级升压,一级降压,采样输入电压后根据采样点落在不通的范围控制进入不通的状态,用一般的比较还要考虑当前状态的方式太繁琐而且程序量也不小容易出错,故作出以下算法,判断即IO口控制一起完成,感觉不错,希望二姨家高手们批评指正:
typedef struct
   word   entry_high;
   word   entry_low;
   word   leave_high;
   word   leave_low;
   IOControl  io_val;
} volt_threshold;
#define  LINE_ABNOR_LOW  0
#define  LINE_LOWEST   1
#define  LINE_LOW   2
#define  LINE_NORMAL   3
#define  LINE_HIGH   4
#define  LINE_ABNOR_HIGH  5
volt_threshold Status_Array[]=
{VOLT_160V,VOLT_160V,VOLT_170V,VOLT_170V,0x0},
{VOLT_180V,VOLT_170V,VOLT_190V,VOLT_160V,0x0d},
{VOLT_210V,VOLT_190V,VOLT_220V,VOLT_180V,0x0f},
{VOLT_230V,VOLT_220V,VOLT_240V,VOLT_210V,0x01},
{VOLT_240V,VOLT_240V,VOLT_250V,VOLT_230V,0x0b},
{VOLT_250V,VOLT_250V,VOLT_240V,VOLT_240V,0x0},
static  byte  SysStatus = LINE_NORMAL;
void Main_Process(void)
   byte curState = SysStatus;
  while(1)
     if(linePeakV > Status_Array[SysStatus].leave_high)
          if(SysStatus == LINE_ABNOR_HIGH)
                break;
           SysStatus++;
           continue ;
     if(linePeakV < Status_Array[SysStatus].leave_low)
           if(SysStatus == LINE_ABNOR_LOW)
               break;
           SysStatus--;
           continue ;
      break;
   if(curState != SysStatus)
         PTAD_PTAD1 = Status_Array[SysStatus].io_val.Relay1;
         PTAD_PTAD2 = Status_Array[SysStatus].io_val.Relay2;
         PTAD_PTAD3 = Status_Array[SysStatus].io_val.Relay3;
        PTAD_PTAD4 = Status_Array[SysStatus].io_val.LEDYellow;
