我的是xp系统,设置的一个共享目录,配置如下:# ----------------------- Standalone Server Options ------------------------
# security = the mode Samba runs in. This can be set to user, share
# (deprecated), or server (deprecated).
# passdb backend = the backend used to store user information in. New
# installations should use either tdbsam or ldapsam. No additional configuration
# is required for tdbsam. The "smbpasswd" utility is available for backwards
# compatibility.
security = share
passdb backend = tdbsam
____________________________________________________________
#============================ Share Definitions ==============================
[share]
comment = root Directories
path = /home/share
browseable = yes
writable = yes
valid users = smb
配置完后 我重启了samba服务器,也追加了用户smb,但是密码也设了,访问时可以看到共享目录:
但是点击是就是要密码,
所有可能的密码我都试过了,还是没用,怎么办啊??求大侠指教!!!!! |
