12864写时序求助
3044|0
 楼主| ldj003 发表于 2011-7-19 20:15 | 显示全部楼层 |阅读模式
求 指令和数据的程序。   望高手指教下我写的:
#include<reg52.h>
#define uchar unsigned char
#define uint unsigned int
sbit rs=P2^4;
sbit rw=P2^5;
sbit ea=P2^2;
sbit psb=P2^1;
void write_com(uint com);
void write_data(uint dat);
void delay(uchar z)
uchar x,y;
for(x=z;x>0;x--)
  for(y=110;y>0;y--);
void init ()
psb=1;
rw=0;
write_com(0x01);
write_com(0x0f);
ea=0;
rs=0;
rs=1;
P0=com;
ea=1;
delay(1);
ea=0;
ea=0;
rs=1;
rs=0;
P0=dat;
ea=1;
delay(1);
ea=0;
void main ()
init();
/*请教下 怎么调试出光标来。我的源程序是按照只写不读,所以RW一直拉低。。还有我看了源程序 貌似P2.6口不是始能端?
在时序图中,EA端不是要拉高才能读到数据吗?为什么源程序是拉低?为什么他要设置2个形参?
开发板附的源程序是这么样的:
#include"reg52.h"
#define WINDOW_XADDR_START 0x0050 // Horizontal Start Address Set
#define WINDOW_XADDR_END 0x0051 // Horizontal End Address Set
#define WINDOW_YADDR_START 0x0052 // Vertical Start Address Set
#define WINDOW_YADDR_END 0x0053 // Vertical End Address Set
#define GRAM_XADDR      0x0020 // GRAM Horizontal Address Set
#define GRAM_YADDR      0x0021 // GRAM Vertical Address Set
#define GRAMWR        0x0022 // memory write
sbit CS=P2^2;  //片选
sbit RES=P2^1;  //复位
sbit RS=P2^4;  //数据/命令选择
sbit RW=P2^5;
                    //数据口使用P0
void main (void);
void ILI9325_Initial(void);
void show_colour_bar (void);
void Write_Cmd_Data(unsigned char x, unsigned int y);
void Write_Cmd(unsigned char DH,unsigned char DL);
void Write_Data(unsigned char DH,unsigned char DL);
void delayms(unsigned int tt);
void show_photo(void);
void Show_RGB (unsigned int x0,unsigned int x1,unsigned int y0,unsigned int y1,unsigned int Color);
unsigned char code pic[];
void  Write_Data_U16(unsigned int y);
static void LCD_SetPos(unsigned int x0,unsigned int x1,unsigned int y0,unsigned int y1);
void ClearScreen(unsigned int bColor);
void LCD_PutChar8x16(unsigned short x, unsigned short y, char c, unsigned int fColor, unsigned int bColor);
void LCD_PutChar(unsigned short x, unsigned short y, char c, unsigned int fColor, unsigned int bColor);
void LCD_PutString(unsigned short x, unsigned short y, char *s, unsigned int fColor, unsigned int bColor);
void LCD_PutChar8x8(unsigned short x, unsigned short y, char c, unsigned int fColor, unsigned int bColor);
void PutGB1616(unsigned short x, unsigned short  y, unsigned char c[2], unsigned int fColor,unsigned int bColor);
void  main(void)
CS=1;
delayms(5);
RES=0;
delayms(5);
RES=1;
delayms(5);
ILI9325_Initial();
while(1)
/*Show_RGB(0x0000);
Show_RGB(0xffff);
Show_RGB(0xf800);
Show_RGB(0x07e0);
Show_RGB(0x001f);
   // LCD_SetPos(48,68,29,69);
ClearScreen(0xf800);
//Show_RGB (0,240,0,320,0xf800);
/*Show_RGB (0,120,0,160,0x001f);
Show_RGB (0,120,161,320,0xffff);
Show_RGB (121,240,161,320,0x07e0);
Show_RGB (121,240,0,160,0x0000);
// show_colour_bar();
LCD_PutString(40,40,"www.baidu.com",0x0000,0xffff);
LCD_PutString(40,60,"I LOVE MY JOB ",0x0000,0xf800);
LCD_PutString(10,80,"上海浩豚电子科技有限公司",0x0000,0xf800);
LCD_PutString(40,100,"专业技术支持论坛",0x07e0,0xf800);
LCD_PutString(40,120,"专业开发板工控板",0x001f,0xf800);
LCD_PutString(40,140,"1234567890",0x001f,0xf800);
LCD_PutString(0,160,"abcdefghijklmnopqistuvwxyz",0x001f,0xf800);
LCD_PutString(0,180,"`,./<>';:[]{}\|?)(-=+*&^%$",0x001f,0xf800);
// show_photo();
  while(1);
unsigned int i,j;
LCD_SetPos(0,240,0,320);//320x240
for (i=0;i<320;i++)
    for (j=0;j<240;j++)
        Write_Data_U16(bColor);
#include "8X16.h"
unsigned int i,j;
LCD_SetPos(x,x+8-1,y,y+16-1);
for(i=0; i<16;i++) {
  unsigned char m=Font8x16[c*16+i];
  for(j=0;j<8;j++) {
   if((m&0x80)==0x80) {
    Write_Data_U16(fColor);
   else {
   m<<=1;
void LCD_PutChar(unsigned short x, unsigned short y, char c, unsigned int fColor, unsigned int bColor) {
  LCD_PutChar8x16( x, y, c, fColor, bColor );
#include "GB1616.h" //16*16汉字字模
void PutGB1616(unsigned short x, unsigned short  y, unsigned char c[2], unsigned int fColor,unsigned int bColor){
unsigned int i,j,k;
LCD_SetPos(x,  x+16-1,y, y+16-1);
for (k=0;k<64;k++) { //64标示自建汉字库中的个数,循环查询内码
   if ((codeGB_16[k].Index[0]==c[0])&&(codeGB_16[k].Index[1]==c[1])){
     for(i=0;i<32;i++) {
    unsigned short m=codeGB_16[k].Msk;
    for(j=0;j<8;j++) {
   else {
   m<<=1;
void LCD_PutString(unsigned short x, unsigned short y, unsigned char *s, unsigned int fColor, unsigned int bColor) {
  unsigned char l=0;
while(*s) {
  if( *s < 0x80)
   LCD_PutChar(x+l*8,y,*s,fColor,bColor);
   s++;l++;
  else
   PutGB1616(x+l*8,y,(unsigned char*)s,fColor,bColor);
   s+=2;l+=2;
//==================== 显示R G B 顔色 ====================//
unsigned int i,j;
//address_set();
LCD_SetPos(x0,x1,y0,y1);
for (i=y0;i<=y1;i++)
    for (j=x0;j<=x1;j++)
        Write_Data_U16(Color);
//====================== 显示彩条 ======================//
int V,H;
for(H=0;H<240;H++)
  for(V=0;V<40;V++)
  Write_Data(0xf8,0x00);
for(H=0;H<240;H++)
  for(V=40;V<80;V++)
  Write_Data(0x07,0xe0);
for(H=0;H<240;H++)
  for(V=80;V<120;V++)
  Write_Data(0x00,0x1f);
for(H=0;H<240;H++)
  for(V=120;V<160;V++)
  Write_Data(0xff,0xe0);
for(H=0;H<240;H++)
  for(V=160;V<200;V++)
  Write_Data(0xf8,0x1f);
for(H=0;H<240;H++)
  for(V=200;V<240;V++)
  Write_Data(0x07,0xff);
for(H=0;H<240;H++)
  for(V=240;V<280;V++)
  Write_Data(0xff,0xff);
for(H=0;H<240;H++)
  for(V=280;V<320;V++)
  Write_Data(0x00,0x00);
unsigned char j;
unsigned int i;
unsigned long s=0;
for (i=0;i<75;i++)
for (j=0;j<240;j++)
for (i=0;i<170;i++)
for (j=0;j<55;j++)
  for (j=0;j<130;j++)
  Write_Data(pic[s++],pic[s++]);
  for (j=0;j<55;j++)
    for (i=0;i<75;i++)
for (j=0;j<240;j++)
void  Write_Cmd_Data (unsigned char x,unsigned int y)
unsigned char m,n;
m=y>>8;
n=y;
Write_Cmd(0x00,x);
Write_Data(m,n);
unsigned char m,n;
m=y>>8;
n=y;
Write_Data(m,n);
//====================== 写命令 ==========================//
CS=0;
RS=0;
P0=DH;
RW=0;
RW=1;
P0=DL;
RW=0;
RW=1;
CS=1;
//===================== 写数据 ===========================//
CS=0;
RS=1;
P0=DH;
RW=0;
    RW=1;
P0=DL;
RW=0;
RW=1;
CS=1;
void delayms(unsigned int count)
    int i,j;
    for(i=0;i<count;i++)
      for(j=0;j<260;j++);
//===================== 初始化代码 =======================//
delayms(50);
Write_Cmd_Data(0x0001,0x0100);
Write_Cmd_Data(0x0002,0x0700);
Write_Cmd_Data(0x0003,0x1030);
Write_Cmd_Data(0x0004,0x0000);
Write_Cmd_Data(0x0008,0x0207);
Write_Cmd_Data(0x0009,0x0000);
Write_Cmd_Data(0x000A,0x0000);
Write_Cmd_Data(0x000C,0x0000);
Write_Cmd_Data(0x000D,0x0000);
Write_Cmd_Data(0x000F,0x0000);
//power on sequence VGHVGL
Write_Cmd_Data(0x0010,0x0000);
Write_Cmd_Data(0x0011,0x0007);
Write_Cmd_Data(0x0012,0x0000);
Write_Cmd_Data(0x0013,0x0000);
//vgh
Write_Cmd_Data(0x0010,0x1290);
Write_Cmd_Data(0x0011,0x0227);
//delayms(100);
//vregiout
Write_Cmd_Data(0x0012,0x001d); //0x001b
//delayms(100);
//vom amplitude
Write_Cmd_Data(0x0013,0x1500);
//delayms(100);
//vom H
Write_Cmd_Data(0x0029,0x0018);
Write_Cmd_Data(0x002B,0x000D);
//gamma
Write_Cmd_Data(0x0030,0x0004);
Write_Cmd_Data(0x0031,0x0307);
Write_Cmd_Data(0x0032,0x0002);// 0006
Write_Cmd_Data(0x0035,0x0206);
Write_Cmd_Data(0x0036,0x0408);
Write_Cmd_Data(0x0037,0x0507);
Write_Cmd_Data(0x0038,0x0204);//0200
Write_Cmd_Data(0x0039,0x0707);
Write_Cmd_Data(0x003C,0x0405);// 0504
Write_Cmd_Data(0x003D,0x0F02);
//ram
Write_Cmd_Data(0x0050,0x0000);
Write_Cmd_Data(0x0051,0x00EF);
Write_Cmd_Data(0x0052,0x0000);
Write_Cmd_Data(0x0053,0x013F);
Write_Cmd_Data(0x0060,0xA700);
Write_Cmd_Data(0x0061,0x0001);
Write_Cmd_Data(0x006A,0x0000);
Write_Cmd_Data(0x0080,0x0000);
Write_Cmd_Data(0x0081,0x0000);
Write_Cmd_Data(0x0082,0x0000);
Write_Cmd_Data(0x0083,0x0000);
Write_Cmd_Data(0x0084,0x0000);
Write_Cmd_Data(0x0085,0x0000);
Write_Cmd_Data(0x0090,0x0010);
Write_Cmd_Data(0x0092,0x0600);
Write_Cmd_Data(0x0093,0x0003);
Write_Cmd_Data(0x0095,0x0110);
Write_Cmd_Data(0x0097,0x0000);
Write_Cmd_Data(0x0098,0x0000);
Write_Cmd_Data(0x0007,0x0133);
// Write_Cmd_Data(0x0022);//
函数名称:LCD_DefineDispWindow
功    能:定义显示窗体
参    数:x0:  窗体中X坐标中较小者
  x1:  窗体中X坐标中较大者
  y0:  窗体中Y坐标中较小者
  y1:  窗体中Y坐标中较大者
返 回 值:无
  Write_Cmd_Data(WINDOW_XADDR_START,x0);
  Write_Cmd_Data(WINDOW_XADDR_END,x1);
  Write_Cmd_Data(WINDOW_YADDR_START,y0);
  Write_Cmd_Data(WINDOW_YADDR_END,y1);
  Write_Cmd_Data(GRAM_XADDR,x0);
  Write_Cmd_Data(GRAM_YADDR,y0);
  Write_Cmd (0x00,0x22);//LCD_WriteCMD(GRAMWR);
