[STM32F1] STM32F103VCT6 的SPI1和74HC595通信,并控制数码管显示
3559|2
 楼主| kn1986 发表于 2018-4-4 14:54 | 显示全部楼层 |阅读模式
看相关教程的过程中,自己搭DEMO过程中遇到些问题点,分享出来,给后来者以借鉴…
常用的SPI通讯方式是标准四线制,如下图电路示意图所示:
STM32和74HC595的接线方式为:
SPI1_MOSI引脚(PA7)-----74HC595(pin14 SI)相连接
SPI1_MISO引脚(PA6)不接
SPI1_SCK引脚(PA5)-----74HC595(pin11 SCK)相连接
SPI1_NSS引脚(PA4)----74HC595(pin13 ncs)相连接  选择模式为:SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; 并在初始化中打开SPI_NSS脚输出功能:SPI_SSOutputCmd(SPI1, ENABLE);这样SPI1_NSS引脚就可以像操作普通IO口一样,输出低电平来选择74HC595芯片。
软件方面,由于程序比较多,就把GPIO配置、SPI配置、和SPI数据发送等相关程序列出来。
void GPIO_Configuration(void)
        // PA0-595_nCS(输出)  PA1-RCK(输出) PA5-SPI1_SCK(输出)        PA6-SPI1-MISO(输入)        PA7-SPI1_MOSI(输出)
        GPIO_InitTypeDef GPIO_InitStructure;                //声明一个结构体变量
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1;        //选择PA0 PA1
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//管脚频率为50M
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//输出模式推挽输出
        GPIO_Init(GPIOA, &GPIO_InitStructure);                                        //按照以上结构体参数值初始化GPIOE寄存器
        //SmgA1--PC8(输出)
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9;        //选择PC8
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//输出模式为推挽输出
        GPIO_Init(GPIOC, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;        //选择PB15
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;        //选择PE8
        GPIO_Init(GPIOE, &GPIO_InitStructure);
        //SPI所用管脚的初始化
        GPIO_InitStructure.GPIO_Pin= GPIO_Pin_5|GPIO_Pin_7;        //选择PA.5,PA.7
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;                        //管脚频率为50MHZ
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;        //模式为复用推挽输出 (SPI1)
        GPIO_Init(GPIOA, &GPIO_InitStructure);                           //初始化GPIOA寄存器
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;                                        //选择PA6
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//输入模式为浮空输入
        GPIO_InitStructure.GPIO_Pin= GPIO_Pin_4;        //选择PA.4
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;        //推挽输出模式 (SPI1)
void SPI_Configuration(void)
                /* SPI1 configuration */
                        SPI_InitTypeDef  SPI_InitStructure;
                        SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
                        SPI_InitStructure.SPI_Mode = SPI_Mode_Master;                //主机模式
                        SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; //8位数据
                        SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;//SPI_CPOL_High=模式3,时钟空闲为高 //SPI_CPOL_Low=模式0,时钟空闲为低
                        SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;//SPI_CPHA_2Edge;//SPI_CPHA_1Edge, SPI_CPHA_2Edge;
                        SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;//SPI_NSS_Soft;//SPI_NSS_Hard
                        SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;//SPI_BaudRatePrescaler_2=18M;//SPI_BaudRatePrescaler_4=9MHz
                        SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_LSB;//数据从高位开始发送
                        SPI_InitStructure.SPI_CRCPolynomial = 7;
                        SPI_Init(SPI1, &SPI_InitStructure);
                                /*Enable SPI1.NSS as a GPIO*/
                        /* Enable SPI1  */
                        SPI_Cmd(SPI1, ENABLE);
GPIO_ResetBits(GPIOA, GPIO_Pin_4);
//--------数码管的控制--------------
while(1)
//                 i=3;
//                 for(;i<10;)
                        for(i=0;i<10;i++)
                 SPI_I2S_SendData(SPI1,tab);
//                 i++;
                while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
                GPIO_ResetBits(GPIOA, GPIO_Pin_1);
                Delay(10);
                GPIO_SetBits(GPIOA, GPIO_Pin_1);
                Delay(10);
                Delay(1000);
74HC595与数码管连接
74HC595与数码管连接
74HC595与数码管连接
74HC595与数码管连接
STM32F103VCT6的SPI口
STM32F103VCT6的SPI口
能运行成功??  发表于 2018-6-10 00:47
mmuuss586 发表于 2018-4-4 15:12 | 显示全部楼层
感谢楼主分享;
