串口 中断错误
1963|0
 楼主| su27meng 发表于 2011-7-29 12:55 | 显示全部楼层 |阅读模式
程序刚开始运行是正常的,当程序运行到一定时间后(大约15分钟后),我就发现程序一直在响应中断,主程序一点也不执行,单步执行下,发现上图所示情况,执行到if判断语句后,直接跳到函数结尾,并不读取数据,请各位大侠帮我,急!!!!(NVIC中的中断优先级如何配置)
PutStrtoBuf( &receive,1 );//将收到的字符存入缓存区
下面是串口配置函数:
void USART1_Configuration(void)
GPIO_InitTypeDef
GPIO_InitStructure;
USART_InitTypeDef
USART_InitStructure;
USART_ClockInitTypeDef
USART_ClockInitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
// Configure USART1 Tx (PA.09) as alternate function push-pull
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
// Configure USART1 Rx (PA.10) as input floating //
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
// Configure the USART1 synchronous paramters //
USART_ClockInit(USART1, &USART_ClockInitStructure);
USART_InitStructure.USART_BaudRate = 38400;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Tx | USART_Mode_Rx ;
USART_Init(USART1, &USART_InitStructure);
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//
使能USART接收中断
USART_Cmd(USART1, ENABLE);
NVIC配置:
void
NVIC_Configuration(void)
NVIC_InitTypeDef NVIC_InitStructure;
#ifdef
VECT_TAB_RAM
/* Set the Vector Table base location at 0x20000000 */
NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else
/* VECT_TAB_FLASH
/* Set the Vector Table base location at 0x08000000 */
NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
配置中断嵌套优先级
//NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
使能RTC中断
NVIC_InitStructure.NVIC_IRQChannel = RTC_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
使能USART中断
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQChannel;//
通道设置为串口1中断
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; //
中断占先等级0
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //
中断响应优先级0
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //
打开中断
NVIC_Init(&NVIC_InitStructure); //
初始化
使能TIM4中断
NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 4;
使能TIM3中断
NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
使能USART中断
NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQChannel;//
通道设置为串口1中断
中断占先等级0
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2; //
中断响应优先级0
打开中断
初始化
