跪求大家 帮忙 新手上路 谢谢!
2201|1
 楼主| mike20080404 发表于 2011-8-3 21:27 | 显示全部楼层 |阅读模式
ge, TI, ni, se, os
#include <C8051F060.h>                 // SFR declarations
#include <stdio.h>
sfr16 RCAP2    = 0xCA;                 // Timer2 capture/reload
sfr16 TMR2     = 0xCC;                 // Timer2
#define BAUDRATE     56000            // Baud rate of UART in bps
#define SYSCLK       22118400L
sbit Trig = P3^0;
sbit Echo = P3^1;
void OSCILLATOR_Init (void);
void PORT_Init_UART0 (void);
void UART0_Init (void);
void PORT_Init (void);
void Delay(void);
void Timer0_Init(void);
void Count(void);
float s = 0;  //超声波的距离
//  主函数开始:关闭开门狗,系统时钟初始化,UART端口初始化,UART初始化,定时器0初始化,I/O端口的初始化 以及 超声波功能实现
void main (void)
   SFRPAGE = CONFIG_PAGE;
   WDTCN = 0xDE;                       // Disable watchdog timer
   WDTCN = 0xAD;
   OSCILLATOR_Init ();                 // Initialize oscillator
   PORT_Init_UART0 ();                 // Initialize crossbar and GPIO
   UART0_Init ();                      // Initialize UART0
   Timer0_Init();
   PORT_Init();
//while (1)
// 超声波测距开始
//   Trig = 1;
//      Delay ();      //至少10uS
//   Trig = 0;
//   while(!Echo);       //等待模块输出高电平
//    TCON = 0x10;                       //启动计时器0
//   while(Echo);       //等待模块输出低电平
//   TCON &=~0x10;       //停止计时器,开始计算距离
//   Count();
//   PORT_Init_UART0 ();
   printf("\ns=%f",s);  //串口输出所计算的距离
   Delay();
   int i;                              // Software timer
   char SFRPAGE_SAVE = SFRPAGE;        // Save Current SFR page
   SFRPAGE = CONFIG_PAGE;              // Set SFR page
   OSCICN = 0x80;                      // Set internal oscillator to run
                                       // at its slowest frequency
   CLKSEL = 0x00;                      // Select the internal osc. as
                                       // the SYSCLK source
   // Initialize external crystal oscillator to use 22.1184 MHz crystal
   OSCXCN = 0x67;                      // Enable external crystal osc.
   for (i=0; i < 256; i++);            // Wait at least 1ms
   while (!(OSCXCN & 0x80));           // Wait for crystal osc to settle
   CLKSEL = 0x01;                      // Select external crystal as SYSCLK
                                       // source
   SFRPAGE = SFRPAGE_SAVE;             // Restore SFRPAGE
    P3MDOUT=0x00;
    P3  |=  0x03;      //配置P3.0 和 P3.1口为数字输入
    P3MDOUT=0x01;   //配置P3.0口为推挽输出
   XBR0     = 0x04;                    // Enable UART0  将TX0和RX0引脚分别分配到P0.0和P0.1
   XBR1     = 0x00;                    //内部资源不连接到端口1
   XBR2     = 0x40;                    // Enable crossbar and weak pull-up
   P0MDOUT |= 0x01;                    // Set TX pin to push-pull
   P1MDOUT |= 0x40;                    // Set P1.6(LED) to push-pull
   SFRPAGE = SFRPAGE_SAVE;             // Restore SFR page
   char SFRPAGE_SAVE;
   SFRPAGE_SAVE = SFRPAGE;             // Preserve SFRPAGE
   SFRPAGE = TMR2_PAGE;
   TMR2CN = 0x00;                      // Timer in 16-bit auto-reload up timer
                                       // mode
   TMR2CF = 0x08;                      // SYSCLK is time base; no output;
                                       // up count only
   RCAP2 = - ((long) SYSCLK/BAUDRATE/16);
   TMR2 = RCAP2;
   TR2= 1;                             // Start Timer2
   SFRPAGE = UART0_PAGE;
   SCON0 = 0x50;                       // 8-bit variable baud rate;
                                       // 9th bit ignored; RX enabled
                                       // clear all flags
   SSTA0 = 0x15;                       // Clear all flags; enable baud rate
                                       // doubler (not relevant for these
                                       // timers);
                                       // Use Timer2 as RX and TX baud rate
                                       // source;
   TI0 = 1;                            // Indicate TX0 ready
//延时函数,具体延长多长时间,待定,至少10us
void Delay (void)
int x;
for(x = 0; x<100; x++);
//定时器0的初始化
   SFRPAGE = TIMER01_PAGE;             // Set SFR page
   TH0 = 0x00;
   TL0 = 0x00;                       //将定时器0设置为16位,计算时间时访问TH0和TL0这两个寄存器
   TMOD = 0x01;                        // Timer0 in 16-bit mode
   CKCON = 0x02;                       // Timer0 uses a 1:48 prescaler
   ET0=0;                                // 将中断源关闭
//计算超声波所测量距离
float count(void)
unsigned int time =0;
time = 256*TH0+TL0;
// printf("\n%u",time);
TH0  = 0x00;
TL0  = 0x00;
s    = time*0.068;  //time0系统时钟 单位CM
return s;
这个是利用C8051f60控制一个超声波模块的程序,但是我调了很久,都不能成功,请大家帮忙  谢谢!PS:单片机给超声波模块的Trig口一个高电平,计算Echo口相应的持续时间,就能计算出距离~
NE5532 发表于 2011-8-3 21:43 | 显示全部楼层
