[开源硬件] 【21ic第二届设计大赛】+ 网络双屏桌面显示器
8058|25
han0097 发表于 2018-7-28 20:55 | 显示全部楼层
厉害厉害!
 楼主| springvirus 发表于 2018-7-29 09:57 | 显示全部楼层
控制NUC505相对简单,只是通过串口发送指令,协议可以灵活制定,数据部分包括今天明天类型字节,天气情况类型字节,最高温,最低温
使用相关软件制作WAV音频文件,存储到TF卡的目录下,路径随意,只要和程序里的获取文件目录保持一致就可以了,NUC505收到指令并解析后,播放对应的音频文件
类型字节和温度数据范围,制定协议供给主从MCU使用,至此,一个相对完整的作品就完成了
视频如下
 楼主| springvirus 发表于 2018-7-29 10:16 | 显示全部楼层
本次制作涉及到农行屏的驱动,以及字库的下载和存储,以下帖子有详细介绍,以供参考
M453使用自带RTC并驱动农行金e顺变身桌面小时钟
https://bbs.21ic.com/icview-2525114-1-1.html
M453通过上位机下载GBK字库到AT45DB321成功
https://bbs.21ic.com/icview-2522292-1-1.html
 楼主| springvirus 发表于 2018-7-29 10:24 | 显示全部楼层
解析天气的函数内容如下
void parse_2days_weather(void)
//parse and display
        unsigned int i = 0, k = 0;
        unsigned char dis_buf[20] = {0};
        S_RTC_TIME_DATA_T time;
        unsigned int len, offset;
        unsigned char whichday_flag = 0;
        unsigned char utf[64] = {0};
        unsigned char gbk[64] = {0};
        unsigned char sdata[4] = {0};
        unsigned char temp = 0;
        CleanLCD();
        CleanLCD_2();
        for(i=0;i<uart1_recv_offset;i++)
                if(uart1_recv_buf[i] == 'n' &&
                        uart1_recv_buf[i+1] == 'a' &&
                        uart1_recv_buf[i+2] == 'm' &&
                        uart1_recv_buf[i+3] == 'e')
                        len = 0;
                        offset = 0;
                        memset(utf, 0x00, sizeof(utf));
                        memset(gbk, 0x00, sizeof(gbk));
                        while(uart1_recv_buf[i+7+offset] != '"')
                                utf[offset] = uart1_recv_buf[i+7+offset];
                                offset++;
                                if(offset >= sizeof(utf))
                                        break;
                        SwitchToGbk(utf, offset, gbk, NULL);
                        memset(city_gbk, 0x00, sizeof(city_gbk));
                        memcpy(city_gbk, gbk, sizeof(gbk));
                        DisplayCity(gbk);
                //english letter's UTF8 is the same as ASCII
                //由于有
                //"last_update"
                //的关键字,所以这里用
                //"date"
                //来过滤
                if(uart1_recv_buf[i] == '"' &&
                        uart1_recv_buf[i+1] == 'd' &&
                        uart1_recv_buf[i+2] == 'a' &&
                        uart1_recv_buf[i+3] == 't' &&
                        uart1_recv_buf[i+4] == 'e' &&
                        uart1_recv_buf[i+5] == '"')
                        time.u32Year = (uart1_recv_buf[i+8]-0x30)*1000 +
                                (uart1_recv_buf[i+9]-0x30)*100 +
                                (uart1_recv_buf[i+10]-0x30)*10 +
                                (uart1_recv_buf[i+11]-0x30)*1;
                        time.u32Month = (uart1_recv_buf[i+13]-0x30)*10 +
                                (uart1_recv_buf[i+14]-0x30)*1;
                        time.u32Day = (uart1_recv_buf[i+16]-0x30)*10 +
                                (uart1_recv_buf[i+17]-0x30)*1;
                        trace("time.year = %d, month = %d, day = %d \r\n",
                                time.u32Year, time.u32Month, time.u32Day);
                        DisplayDate(time);
                        if((i >= 150) && (i <= 250))
                                whichday_flag = Today;
                                //today
                        else
                                whichday_flag = Tomorrow;
                                //tomorrow
                if(uart1_recv_buf[i] == 't' &&
                        uart1_recv_buf[i+1] == 'e' &&
                        uart1_recv_buf[i+2] == 'x' &&
                        uart1_recv_buf[i+4] == '_' &&
                        uart1_recv_buf[i+5] == 'd' &&
                        uart1_recv_buf[i+6] == 'a' &&
                        uart1_recv_buf[i+7] == 'y')
                        len = 0;
                        offset = 0;
                        while(uart1_recv_buf[i+11+offset] != '"')
                                utf[offset] = uart1_recv_buf[i+11+offset];
                                offset++;
                                        break;
                        DisplayDayWeather(gbk);
                        if(gbk[0] == Qing_0 && gbk[1] == Qing_1)
                                sdata[0] = Qing;
                                display1616_2(6, 0, icon_sunny);
                        else if(gbk[0] == Yin_0 && gbk[1] == Yin_1)
                                sdata[0] = Yin;
                                display1616_2(6, 0, icon_cloudy);
                        else if(gbk[0] == Duo_0 && gbk[1] == Duo_1)
                                sdata[0] = DuoYun;
                        else if(gbk[0] == Xiao_0 && gbk[1] == Xiao_1 &&
                                gbk[2] == Yu_0 && gbk[3] == Yu_1)
                                sdata[0] = XiaoYu;
                                display1616_2(6, 0, icon_rainy);
                        else if(gbk[0] == Zhong_0 && gbk[1] == Zhong_1 &&
                                sdata[0] = ZhongYu;
                        else if(gbk[0] == Da_0 && gbk[1] == Da_1 &&
                                sdata[0] = DaYu;
                                display1616_2(6, 0, icon_heavyrainy);
                        else if(gbk[0] == Bao_0 && gbk[1] == Bao_1 &&
                                sdata[0] = BaoYu;
                                gbk[2] == Bao_0 && gbk[3] == Bao_1 &&
                                gbk[4] == Yu_0 && gbk[5] == Yu_1)
                                sdata[0] = DaBaoYu;
                        else if(gbk[0] == Te_0 && gbk[1] == Te_1 &&
                                gbk[2] == Da_0 && gbk[3] == Da_1 &&
                                gbk[4] == Bao_0 && gbk[5] == Bao_1 &&
                                gbk[6] == Yu_0 && gbk[7] == Yu_1)
                                sdata[0] = TeDaBaoYu;
                        else if(gbk[0] == Zhen_0 && gbk[1] == Zhen_1 &&
                                sdata[0] = ZhenYu;
                        else if(gbk[0] == Lei_0 && gbk[1] == Lei_1 &&
                                gbk[2] == Zhen_0 && gbk[3] == Zhen_1 &&
                                sdata[0] = LeiZhenYu;
                                display1616_2(6, 0, icon_leizhen_rainy);
                        else if(gbk[0] == Bing_0 && gbk[1] == Bing_1 &&
                                gbk[2] == Bao_0 && gbk[3] == Bao_1)
                                sdata[0] = BingBao;
                        else if(gbk[0] == Mai_0 && gbk[1] == Mai_1)
                                sdata[0] = Mai;
                        else
                                sdata[0] = 0x00;
                        uart1_recv_buf[i+5] == 'n' &&
                        uart1_recv_buf[i+6] == 'i' &&
                        uart1_recv_buf[i+7] == 'g' &&
                        uart1_recv_buf[i+8] == 'h' &&
                        uart1_recv_buf[i+9] == 't')
                        len = 0;
                        offset = 0;
                        while(uart1_recv_buf[i+13+offset] != '"')
                                utf[offset] = uart1_recv_buf[i+13+offset];
                                offset++;
                                        break;
                        DisplayNightWeather(gbk);
                                sdata[1] = Qing;
                                display1616_2(6, 4*16, icon_sunny);
                                sdata[1] = Yin;
                                display1616_2(6, 4*16, icon_cloudy);
                                sdata[1] = DuoYun;
                                sdata[1] = XiaoYu;
                                display1616_2(6, 4*16, icon_rainy);
                                sdata[1] = ZhongYu;
                                sdata[1] = DaYu;
                                display1616_2(6, 4*16, icon_heavyrainy);
                                sdata[1] = BaoYu;
                                sdata[1] = DaBaoYu;
                                sdata[1] = TeDaBaoYu;
                                sdata[1] = ZhenYu;
                                sdata[1] = LeiZhenYu;
                                sdata[1] = BingBao;
                                sdata[1] = Mai;
                        else
                                sdata[0] = 0x00;
                if(uart1_recv_buf[i] == 'h' &&
                        uart1_recv_buf[i+1] == 'i' &&
                        uart1_recv_buf[i+2] == 'g' &&
                        uart1_recv_buf[i+3] == 'h')
                        memset(dis_buf, 0x00, sizeof(dis_buf));
                        //start
                        if(uart1_recv_buf[i+6] == '"')
                                //temperature first bit
                                dis_buf[0] = uart1_recv_buf[i+7];
                                if(uart1_recv_buf[i+8] == '"')
                                        //end
                                else
                                        //temperature second bit
                                        dis_buf[1] = uart1_recv_buf[i+8];
                        DisplayHighTemp(dis_buf);
                        if(dis_buf[0] != 0x00)
                                temp = dis_buf[0] - 0x30;
                                if(dis_buf[1] != 0x00)
                                        temp = (temp * 10) + (dis_buf[1] - 0x30);
                        sdata[2] = temp;
                if(uart1_recv_buf[i] == 'l' &&
                        uart1_recv_buf[i+1] == 'o' &&
                        uart1_recv_buf[i+2] == 'w')
                        //start
                        if(uart1_recv_buf[i+5] == '"')
                                dis_buf[0] = uart1_recv_buf[i+6];
                                if(uart1_recv_buf[i+7] == '"')
                                        //end
                                else
                                        dis_buf[1] = uart1_recv_buf[i+7];
                        DisplayLowTemp(dis_buf);
                        sdata[3] = temp;
                //由于含有
                //"wind_direction_degree"的关键字,所以将其过滤掉
                        uart1_recv_buf[i+1] == 'w' &&
                        uart1_recv_buf[i+2] == 'i' &&
                        uart1_recv_buf[i+3] == 'n' &&
                        uart1_recv_buf[i+4] == 'd' &&
                        uart1_recv_buf[i+5] == '_' &&
                        uart1_recv_buf[i+6] == 'd' &&
                        uart1_recv_buf[i+7] == 'i' &&
                        uart1_recv_buf[i+8] == 'r' &&
                        uart1_recv_buf[i+9] == 'e' &&
                        uart1_recv_buf[i+10] == 'c' &&
                        uart1_recv_buf[i+11] == 't' &&
                        uart1_recv_buf[i+12] == 'i' &&
                        uart1_recv_buf[i+13] == 'o' &&
                        uart1_recv_buf[i+14] == 'n' &&
                        uart1_recv_buf[i+15] == '"')
                        len = 0;
                        offset = 0;
                        while(uart1_recv_buf[i+18+offset] != '"')
                                utf[offset] = uart1_recv_buf[i+18+offset];
                                offset++;
                                        break;
                        DisplayWindDirection(gbk);
                if(uart1_recv_buf[i] == 'w' &&
                        uart1_recv_buf[i+2] == 'n' &&
                        uart1_recv_buf[i+3] == 'd' &&
                        uart1_recv_buf[i+5] == 's' &&
                        uart1_recv_buf[i+6] == 'p' &&
                        uart1_recv_buf[i+7] == 'e' &&
                        uart1_recv_buf[i+8] == 'e' &&
                        uart1_recv_buf[i+9] == 'd')
                        //start
                        if(uart1_recv_buf[i+12] == '"')
                                //speed first bit
                                dis_buf[0] = uart1_recv_buf[i+13];
                                if(uart1_recv_buf[i+14] == '"')
                                        //end
                                else
                                        //speed second bit
                                        dis_buf[1] = uart1_recv_buf[i+14];
                        DisplayWindSpeed(dis_buf);
                        if(whichday_flag == Today)
                                nuc505_send_cmd(Today, sdata);
                                for(k = 0; k < 200; k++)
                                        delay_test(1000*25);
                                CleanLCD();
                                CleanLCD_2();
                                //切换到明天时,报文中没有城市名了,所以这里使用全局的city_gbk
                                DisplayCity(city_gbk);
                        else if(whichday_flag == Tomorrow)
                                nuc505_send_cmd(Tomorrow, sdata);
 楼主| springvirus 发表于 2018-8-2 15:15 | 显示全部楼层
过来逛逛,哈哈
