[应用相关] 发一个关于 CANOPEN 的例程。CiA401 德国CiA网站下载
3306|7
 楼主| 東南博士 发表于 2018-9-3 09:20 | 显示全部楼层 |阅读模式
* Main.c
*  Created on: 15.01.2014
*      Author: oe
*      emtas GmbH
/* header of standard C - libraries
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <getopt.h>
/* header of project specific types
#include <gen_define.h>
#include <co_canopen.h>
#include <co_401.h>
#include <usr_401.h>
#include <stm32f4_discovery.h>
#include <stm32f4xx_gpio.h>
#include <stm32f4xx_rcc.h>
#include <stm32f4xx_usart.h>
/* list of external used functions, if not in headers
void SystemInit(void);
void SystemCoreClockUpdate(void);
int codrvHardwareInit(void);
/* list of local defined functions
static RET_T nmtInd(BOOL_T  execute, CO_NMT_STATE_T newState);
static void hbState(UNSIGNED8   nodeId, CO_ERRCTRL_T state,
        CO_NMT_STATE_T  nmtState);
static RET_T sdoServerReadInd(BOOL_T execute, UNSIGNED8 sdoNr, UNSIGNED16 index,
        UNSIGNED8   subIndex);
static RET_T sdoServerCheckWriteInd(BOOL_T execute, UNSIGNED8 node,
        UNSIGNED16 index, UNSIGNED8 subIndex, const UNSIGNED8 *pData);
static RET_T sdoServerWriteInd(BOOL_T execute, UNSIGNED8 sdoNr,
        UNSIGNED16 index, UNSIGNED8 subIndex);
static void pdoInd(UNSIGNED16);
static void pdoRecEvent(UNSIGNED16);
static void canInd(CO_CAN_STATE_T);
static void commInd(CO_COMM_STATE_EVENT_T);
static void ledGreenInd(BOOL_T);
static void ledRedInd(BOOL_T);
static void evaTimeOver(void *pData);
void InitUSART2(int speed);
/* global variables
/* local defined variables
static CO_TIMER_T        evaTimer;   /**< local timer used as one-shot timer */
static int speed = 125;                 /**< CAN speed used in Kbit/s */
int main(void)
        /* Generic Board initialization */
        SystemInit();
        SystemCoreClockUpdate();
        /* initialize on-board LEDs */
        STM_EVAL_LEDInit(LED3);        /* orange                                        */
        STM_EVAL_LEDInit(LED4); /* green, used by CANopen        */
        STM_EVAL_LEDInit(LED5); /* red                                                */
        STM_EVAL_LEDInit(LED6);        /* blue                                                */
        /* initialize USART2/USB for printf() debug messages */
        InitUSART2(115200); /* use a high speed, because TX polling */
        printf("\n\n************** START ***************\n\n");
        printf("Slave CiA 401 example, compiled %s\n", __DATE__);
        /* init customer CAN hardware */
        codrvHardwareInit();
        /* additional hardware initialization */
        p401HardwareInit();
        printf("CAN init with %d Kbit/s\n", speed);
        if (codrvCanInit(speed) != RET_OK)  {
                exit(1);
        if (coCanOpenStackInit(NULL) != RET_OK)  {
            printf("error init library\n");
            exit(1);
        if (codrvTimerSetup(CO_TIMER_INTERVAL) != RET_OK)  {
            exit(2);
    /* register event functions */
    if (coEventRegister_NMT(nmtInd) != RET_OK)  {
        exit(3);
    if (coEventRegister_ERRCTRL(hbState) != RET_OK)  {
        exit(4);
    if (coEventRegister_SDO_SERVER_READ(sdoServerReadInd) != RET_OK)  {
        exit(5);
    if (coEventRegister_SDO_SERVER_CHECK_WRITE(sdoServerCheckWriteInd) != RET_OK)  {
        exit(6);
    if (coEventRegister_SDO_SERVER_WRITE(sdoServerWriteInd) != RET_OK)  {
        exit(7);
    if (coEventRegister_PDO(pdoInd) != RET_OK)  {
        exit(8);
    if (coEventRegister_PDO_REC_EVENT(pdoRecEvent) != RET_OK)  {
        exit(9);
    if (coEventRegister_LED_GREEN(ledGreenInd) != RET_OK)  {
        exit(10);
    if (coEventRegister_LED_RED(ledRedInd) != RET_OK)  {
        exit(11);
    if (coEventRegister_CAN_STATE(canInd) != RET_OK)  {
        exit(12);
    if (coEventRegister_COMM_EVENT(commInd) != RET_OK)  {
        exit(13);
    /* --- 401 specific ------------------------------------------------*/
    /* profile 401 HW acess registration */
    if (co401Init() != RET_OK)  {
        // printf("error init 401 profile handler\n");
        exit(14);
    if (coEventRegister_401(
                byte_in_piInd,      /* digital in  HW API function   */
                byte_out_printfInd,     /* digital out HW API function   */
                analog_in_piInd,    /* the analog in HW API function */
                analog_out_printfInd    /* analog out HW API function    */
                ) != RET_OK)  {
        printf("Registration of 401 HW access functions failed\n");
        exit(15);
        /* set up a timer to signal that the evaluation period is over soon.
         * The battery example is build        using an CANopen stack library
         * which only works for a specified period of time. If this duration
         * is over, CANopen simply stops working */
        if(coTimerStart(&evaTimer, 60*60*1000000ul, evaTimeOver, NULL, CO_TIMER_ATTR_ROUNDUP) != RET_OK) {
                exit(16);
    printf("Enable CAN and go into application loop\n\r\n");
    codrvCanEnable();
        while (1)  {
                coCommTask();
                co401Task();
/* Evaluation period is over, switch blue LED on */
        (void)pData; /* not used */
    printf("\nBe prepared, application will stop working soon\n");
        STM_EVAL_LEDOn(LED6);
The following are definitions of communication indication functions.
The application can use these functions to process communication events
application specific. This example, implementing the CiA 401 profile,
is only using the indications to display it using simple printf()
messages.
RET_T nmtInd(
    BOOL_T  execute,
        printf("USR: nmtInd: New Nmt state %d - execute %d\n", newState, execute);
        return(RET_OK);
void pdoInd(
    UNSIGNED16  pdoNr
        printf("USR: pdoInd: pdo %d received\n", pdoNr);
void pdoRecEvent(
    UNSIGNED16  pdoNr
        printf("USR: pdoRecEvent: pdo %d time out\n", pdoNr);
void hbState(
    UNSIGNED8   nodeId,
    CO_ERRCTRL_T state,
        printf("USR: hbInd: HB Event %d node %d nmtState: %d\n", state, nodeId, nmtState);
        return;
    BOOL_T      execute,
    UNSIGNED8   sdoNr,
    UNSIGNED16  index,
    UNSIGNED8   subIndex
        // printf("USR: sdo server read ind: exec: %d, sdoNr %d, index %x:%d\n",
        //  execute, sdoNr, index, subIndex);
        return(RET_OK);
    BOOL_T      execute,
    UNSIGNED8   sdoNr,
    UNSIGNED16  index,
    UNSIGNED8   subIndex,
        // printf("USR: sdo server check write ind: exec: %d, sdoNr %d, index %x:%d\n",
        return(RET_OK);
    BOOL_T      execute,
    UNSIGNED8   sdoNr,
    UNSIGNED16  index,
    UNSIGNED8   subIndex
        // printf("USR: sdo server write ind: exec: %d, sdoNr %d, index %x:%d\n",
        return(RET_OK);
static void canInd(
CO_CAN_STATE_T  canState
        switch (canState)  {
                case CO_CAN_STATE_BUS_OFF:
                        printf("USR: CAN: Bus Off\n\n");
                        break;
                case CO_CAN_STATE_BUS_ON:
                        printf("USR: CAN: Bus On\n\n");
                        break;
                case CO_CAN_STATE_PASSIVE:
                        printf("USR: CAN: Passiv\n\n");
                        break;
                case CO_CAN_STATE_UNCHANGED:
                        printf("USR: CAN: unchanged\n");
                        break;
                default:
                        break;
    CO_COMM_STATE_EVENT_T   commEvent
switch (commEvent)  {
    case CO_COMM_STATE_EVENT_BUS_OFF:
        // printf("COMM-Event Bus Off\n");
        break;
    case CO_COMM_STATE_EVENT_BUS_OFF_RECOVERY:
        break;
    case CO_COMM_STATE_EVENT_BUS_ON:
        // printf("COMM-Event Bus On\n");
        break;
    case CO_COMM_STATE_EVENT_PASSIVE:
        // printf("COMM-Event Bus Passive\n");
        break;
    case CO_COMM_STATE_EVENT_ACTIVE:
        // printf("COMM-Event Bus Active\n");
        break;
    case CO_COMM_STATE_EVENT_CAN_OVERRUN:
        // printf("COMM-Event CAN Overrun\n");
        break;
    case CO_COMM_STATE_EVENT_REC_QUEUE_FULL:
        // printf("COMM-Event Rec Queue Full\n");
        break;
    case CO_COMM_STATE_EVENT_REC_QUEUE_OVERFLOW:
        // printf("COMM-Event Rec Queue Overflow\n");
        break;
    case CO_COMM_STATE_EVENT_TR_QUEUE_FULL:
        // printf("COMM-Event Tr Queue Full\n");
        break;
    case CO_COMM_STATE_EVENT_TR_QUEUE_OVERFLOW:
        // printf("COMM-Event Tr Queue Empty\n");
        break;
    case CO_COMM_STATE_EVENT_TR_QUEUE_EMPTY:
        break;
    default:
        break;
/* LED indication functions, control on-board LEDs */
                BOOL_T        on
#if 1
        if(on) {
                STM_EVAL_LEDOn(LED4);
        } else {
                STM_EVAL_LEDOff(LED4);
#endif
                BOOL_T        on
#if 1
        if (on) {
        } else {
#endif
USART_InitTypeDef USART_InitStructure;
        speed = speed;
        /* Enable clocks */
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
        /* Configure UART2_Tx pin PA2 */
        GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_2;
        GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AF;
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
        GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_UP;
        GPIO_Init (GPIOA, &GPIO_InitStructure);
        /* Connect USART2 pins to AF2 */
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource2, GPIO_AF_USART2);
        /* Configure UART2_Rx pin PA3 */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource3, GPIO_AF_USART2);
        USART_StructInit(&USART_InitStructure);
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;
        USART_InitStructure.USART_StopBits = USART_StopBits_1;
        USART_InitStructure.USART_Parity = USART_Parity_No ;
        USART_InitStructure.USART_BaudRate = speed;
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
        USART_InitStructure.USART_Mode = (USART_Mode_Tx | USART_Mode_Rx);
        USART_Init(USART2, &USART_InitStructure);
        /* enable USART2 */
        USART_Cmd(USART2, ENABLE);
/* exit() is implemented to switch on the error LED
* and stay in a while() loop
* proto type is in stdlib.h
void exit(int exitcode)
        printf("Run time error %d", exitcode);
        while(1);
/* vim: set ts=4 sw=4 spelllang=en : */
 楼主| 東南博士 发表于 2018-9-3 09:22 | 显示全部楼层
* CANopen Stack definitions for 401 - generated by CANopen DeviceDesigner 1.1.7
* Mon Sep 30 11:14:28 2013
/* protect against multiple inclusion of the file */
#ifndef GEN_DEFINE_H
#define GEN_DEFINE_H 1
/* Definition of CANopen NodeID */
#define CO_NODE_ID        32
/* Definition of numbers of CANopen services */
#define CO_SDO_SERVER_CNT        1u
#define CO_PDO_TRANSMIT_CNT        2u
#define CO_PDO_RECEIVE_CNT        6u
#define CO_MAX_MAP_ENTRIES        4u
#define CO_PDO_DYN_MAP_ENTRIES        8u
#define CO_SYNC_SUPPORTED        1u
#define CO_EMCY_PRODUCER        1u
/* Definition of number of call-back functions for each service*/
#define CO_EVENT_SDO_SERVER_READ        2u
#define CO_EVENT_SDO_SERVER_WRITE        2u
#define CO_EVENT_SDO_SERVER_CHECK_WRITE        1u
#define CO_EVENT_PDO        2u
#define CO_EVENT_NMT        2u
#define CO_EVENT_ERRCTRL        1u
#define CO_EVENT_LED        1u
#define CO_EVENT_CAN        2u
#define CO_EVENT_EMCY        1u
/* number of used COB objects */
#define CO_COB_CNT        14u
/* Definition of CAN queue sizes */
#define CO_CONFIG_REC_BUFFER_CNT        5u
#define CO_CONFIG_TRANS_BUFFER_CNT        5u
/* application-specific defines as defined in CANopen DeviceDesigner */
#define CO_PROFILE_401 1
#define  CO_TIMER_INTERVAL       10000L
#define CO_RTR_NOT_SUPPORTED
/* end of application-specific defines */
/* do not modify comments starting with 'user-specific section:' */
/* user-specific section: start */
// #define DEBUG_SEND_TESTMESSAGE
/* user-specific section: end */
#endif /* GEN_DEFINE_H */
晓伍 发表于 2018-9-3 09:38 | 显示全部楼层
非常感谢楼主分享
磨砂 发表于 2018-9-3 09:43 | 显示全部楼层
外设还需要加什么芯片
 楼主| 東南博士 发表于 2018-9-3 09:48 | 显示全部楼层
不过 好像 CANOPEN 似乎很晦涩难懂   看了很久 才感觉刚刚理解了一点点
木木guainv 发表于 2018-9-4 11:08 | 显示全部楼层
有应用成功的吗
Diyer2015 发表于 2018-9-4 14:34 | 显示全部楼层
感觉 没有经过 熟练工程师的培训 没有上过培训课 似乎很难!
yyyyy1231312 发表于 2021-10-27 16:11 | 显示全部楼层
#include <co_canopen.h> CANopen的
请问这个头文件有没有,感谢。vx17852021353
