[技术求助] 请推荐2节1.2V镍氢电池转3.3V的DCDC芯片
2514|29
jiahy 发表于 2018-9-5 16:53 | 显示全部楼层
THS4275的Pin8是关断引脚
shimx 发表于 2018-9-5 16:58 | 显示全部楼层
低电平可以控制芯片关断。
zhanghqi 发表于 2018-9-5 17:03 | 显示全部楼层
哦,这样啊
huangchui 发表于 2018-9-5 17:06 | 显示全部楼层
是的,2,3楼正解
laidaihua 发表于 2018-9-5 17:08 | 显示全部楼层
TI这种升压芯片还是很多的。。
shimx 发表于 2018-9-5 17:11 | 显示全部楼层
还是不能编译,我用wave仿真程序编译,Timer的高低位能否这样赋值?
shimx 发表于 2018-9-5 17:14 | 显示全部楼层
不计算有没有简洁的赋值语句
spark周 发表于 2018-9-5 17:18 | 显示全部楼层
这个应该不能叫 关断, 因为手册称为 Power Down
Power-Down Reference Pin Operation
In addition to the power-down pin, the THS4275 also features a reference pin (REF) which allows the user to control the enable or disable power-down voltage levels applied to the PD pin. Operation of the reference pin as it relates to the power-down pin is described below.
In most split-supply applications, the reference pin is connected to ground. In some cases, the user may want to connect it to the negative or positive supply rail. In either case, the user needs to be aware of the voltage level thresholds that apply to the power-down pin. Table 2 and Table 3 show examples and illustrate the relationship between the reference voltage and the power-down thresholds.
liliang9554 发表于 2018-9-5 17:30 | 显示全部楼层
这个没怎用过,不过一般都是通过特定管脚进行控制的。
zhanghqi 发表于 2018-9-5 17:33 | 显示全部楼层
结贴了,多谢大家讨论这么多哈,呵呵
