Systick做延时,LED不闪烁,高手来解
2409|5
 楼主| hw5226349 发表于 2011-8-13 16:53 | 显示全部楼层 |阅读模式
#include<stm32f10x_lib.h>
void RCC_Configuration(void);
void NVIC_Configuration(void);
void Delay(vu32 nTime);
static vu32 TimingDelay;
ErrorStatus HSEStartUpStatus;
int main(void)
   #ifdef DEBUG
   debug();
   #endif
   RCC_Configuration();
   GPIO_InitStructure.GPIO_Pin=GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10; //将PF6~9设置为50M推挽输出
   GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
   GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
   GPIO_Init(GPIOF,&GPIO_InitStructure);
   GPIO_Write(GPIOF,GPIO_Pin_6|GPIO_Pin_8);  //置1:D1.D2,其他为零
     NVIC_Configuration();
   SysTick_SetReload(9000);  //定时1ms
   SysTick_ITConfig(ENABLE);
   while(1)
      GPIO_Write(GPIOF,(u16)~GPIO_ReadOutputData(GPIOF));
      GPIO_ResetBits(GPIOF,GPIO_Pin_10);   //D1D3与D2D4闪烁,D5点亮
   Delay(1000);//延时500MS
      GPIO_SetBits(GPIOF,GPIO_Pin_10);   //D1D3与D2D4闪烁,D5熄灭
      Delay(1000);
/*SysTick做延时*/
void Delay(u32 nTime)
   SysTick_CounterCmd(SysTick_Counter_Enable); //使能Systick计数器
   TimingDelay=nTime;
   while(TimingDelay!=0);
   SysTick_CounterCmd(SysTick_Counter_Disable);  //禁用计数器
   SysTick_CounterCmd(SysTick_Counter_Clear);    //清空计数器
   RCC_DeInit();
   RCC_HSEConfig(RCC_HSE_ON);   //启动HSE
   HSEStartUpStatus=RCC_WaitForHSEStartUp(); //等待HSE启动
   if(HSEStartUpStatus==SUCCESS)
         /* Enable Prefetch Buffer */
      FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
         /* Flash 2 wait state */
      FLASH_SetLatency(FLASH_Latency_2);
   RCC_HCLKConfig(RCC_SYSCLK_Div1);  //HCLK=系统时钟
   RCC_PCLK2Config(RCC_HCLK_Div1);   //APB2=HCLK
   RCC_PCLK1Config(RCC_HCLK_Div2); //APB1=HCLK/2
   RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_9);   //设置72M为系统时钟
   RCC_PLLCmd(ENABLE);  //使能PLL
   while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY)==RESET){}  //等待PLL准备就绪
   RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);   //将PLL作为SYSCLK
   while(RCC_GetSYSCLKSource()!=0x08){}    //等待PLL成为SYSCLK
   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOF, ENABLE); //使能PF时钟
* Function Name  : NVIC_Configuration
* Description    : Configures Vector Table base location.
* Input          : None
* Output         : None
* Return         : None
   #ifdef  VECT_TAB_RAM
      /* Set the Vector Table base location at 0x20000000 */
     NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
   #else  /* VECT_TAB_FLASH  */
      /* Set the Vector Table base location at 0x08000000 */
     NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
   #endif
/*可变的时间延时衰减率*/
void TimingDelay_Decrement(void)
  if(TimingDelay!=0x00)
     TimingDelay--;
  #ifdef  DEBUG
* Function Name  : assert_failed
* Description    : Reports the name of the source file and the source line number
*                  where the assert_param error has occurred.
* Input          : - file: pointer to the source file name
*                  - line: assert_param error line source number
* Output         : None
* Return         : None
void assert_failed(u8* file, u32 line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
建立工程时+ stm32f10x_lib.c
  + stm32f10x_gpio.c
  + stm32f10x_rcc.c
  + stm32f10x_nvic.c
  + stm32f10x_flash.c
  + stm32f10x_systick.c
这些文件
jiaxinhui 发表于 2011-8-15 17:42 | 显示全部楼层
sjnh 发表于 2011-8-16 07:43 | 显示全部楼层
没有配置中断,TimingDelay_Decrement从来没有执行,怎么实现掩饰
程序一直在while(TimingDelay!=0);处执行
lxj19901115 发表于 2011-8-18 21:09 | 显示全部楼层
貌似问题出现在那个全局变量上面,TimingDelay当然,三楼的说法也是对的,没有设置中断
abin0415 发表于 2012-3-31 17:52 | 显示全部楼层
LZ的群满了,加上不。:(请问lz用的哪个版本的库
abin0415 发表于 2012-3-31 17:57 | 显示全部楼层
不好意思,发错地方了
