[应用相关] 关于OLED iic驱动
4405|41
 楼主| hanzhen654 发表于 2018-9-16 23:22 | 显示全部楼层
status_t I2C_MasterTransferBlocking(I2C_Type *base, i2c_master_transfer_t *xfer)
    assert(xfer);
    i2c_direction_t direction = xfer->direction;
    status_t result = kStatus_Success;
    /* Clear all status before transfer. */
    I2C_MasterClearStatusFlags(base, kClearFlags);
    /* Wait until ready to complete. */
    while (!(base->S & kI2C_TransferCompleteFlag))
    /* Change to send write address when it's a read operation with command. */
    if ((xfer->subaddressSize > 0) && (xfer->direction == kI2C_Read))
        direction = kI2C_Write;
    /* If repeated start is requested, send repeated start. */
    if (xfer->flags & kI2C_TransferRepeatedStartFlag)
        result = I2C_MasterRepeatedStart(base, xfer->slaveAddress, direction);
    else /* For normal transfer, send start. */
        result = I2C_MasterStart(base, xfer->slaveAddress, direction);
    /* Return if error. */
    if (result)
        return result;
    /* Send subaddress. */
    if (xfer->subaddressSize)
        do
            /* Wait until data transfer complete. */
            while (!(base->S & kI2C_IntPendingFlag))
            /* Clear interrupt pending flag. */
            base->S = kI2C_IntPendingFlag;
            /* Check if there's transfer error. */
            result = I2C_CheckAndClearError(base, base->S);
            if (result)
                if (result == kStatus_I2C_Nak)
                    I2C_MasterStop(base);
                return result;
            xfer->subaddressSize--;
            base->D = ((xfer->subaddress) >> (8 * xfer->subaddressSize));
        } while ((xfer->subaddressSize > 0) && (result == kStatus_Success));
        if (xfer->direction == kI2C_Read)
            /* Clear pending flag. */
            if (result)
                return result;
            /* Send repeated start and slave address. */
            result = I2C_MasterRepeatedStart(base, xfer->slaveAddress, kI2C_Read);
            if (result)
                return result;
    /* Wait until address + command transfer complete. */
    if (result)
        return result;
    /* Transmit data. */
    if ((xfer->direction == kI2C_Write) && (xfer->dataSize > 0))
        /* Send Data. */
        result = I2C_MasterWriteBlocking(base, xfer->data, xfer->dataSize);
        if (((result == kStatus_Success) && (!(xfer->flags & kI2C_TransferNoStopFlag))) || (result == kStatus_I2C_Nak))
            /* Clear the IICIF flag. */
            /* Send stop. */
            result = I2C_MasterStop(base);
    /* Receive Data. */
    if ((xfer->direction == kI2C_Read) && (xfer->dataSize > 0))
        result = I2C_MasterReadBlocking(base, xfer->data, xfer->dataSize);
    return result;
status_t I2C_MasterTransferNonBlocking(I2C_Type *base, i2c_master_handle_t *handle, i2c_master_transfer_t *xfer)
    assert(handle);
    assert(xfer);
    /* Check if the I2C bus is idle - if not return busy status. */
    if (handle->state != kIdleState)
        result = kStatus_I2C_Busy;
    else
        /* Start up the master transfer state machine. */
        result = I2C_InitTransferStateMachine(base, handle, xfer);
        if (result == kStatus_Success)
            /* Enable the I2C interrupts. */
            I2C_EnableInterrupts(base, kI2C_GlobalInterruptEnable);
    return result;
 楼主| hanzhen654 发表于 2018-9-16 23:23 | 显示全部楼层
void I2C_MasterTransferAbort(I2C_Type *base, i2c_master_handle_t *handle)
    assert(handle);
    /* Disable interrupt. */
    I2C_DisableInterrupts(base, kI2C_GlobalInterruptEnable);
    /* Reset the state to idle. */
    handle->state = kIdleState;
 楼主| hanzhen654 发表于 2018-9-16 23:24 | 显示全部楼层
status_t I2C_MasterTransferGetCount(I2C_Type *base, i2c_master_handle_t *handle, size_t *count)
    assert(handle);
    if (!count)
        return kStatus_InvalidArgument;
    *count = handle->transferSize - handle->transfer.dataSize;
    return kStatus_Success;
void I2C_MasterTransferHandleIRQ(I2C_Type *base, void *i2cHandle)
    assert(i2cHandle);
    i2c_master_handle_t *handle = (i2c_master_handle_t *)i2cHandle;
    bool isDone;
    /* Clear the interrupt flag. */
    /* Check transfer complete flag. */
    result = I2C_MasterTransferRunStateMachine(base, handle, &isDone);
    if (isDone || result)
        /* Send stop command if transfer done or received Nak. */
        if ((!(handle->transfer.flags & kI2C_TransferNoStopFlag)) || (result == kStatus_I2C_Nak))
            /* Ensure stop command is a need. */
            if ((base->C1 & I2C_C1_MST_MASK))
                if (I2C_MasterStop(base) != kStatus_Success)
                    result = kStatus_I2C_Timeout;
        /* Restore handle to idle state. */
        /* Call the callback function after the function has completed. */
        if (handle->completionCallback)
            handle->completionCallback(base, handle, result, handle->userData);
void I2C_SlaveInit(I2C_Type *base, const i2c_slave_config_t *slaveConfig)
    assert(slaveConfig);
    uint8_t tmpReg;
    CLOCK_EnableClock(s_i2cClocks[I2C_GetInstance(base)]);
    /* Configure addressing mode. */
    switch (slaveConfig->addressingMode)
        case kI2C_Address7bit:
            base->A1 = ((uint32_t)(slaveConfig->slaveAddress)) << 1U;
            break;
        case kI2C_RangeMatch:
            assert(slaveConfig->slaveAddress < slaveConfig->upperAddress);
            base->RA = ((uint32_t)(slaveConfig->upperAddress)) << 1U;
            base->C2 |= I2C_C2_RMEN_MASK;
            break;
        default:
            break;
    /* Configure low power wake up feature. */
    tmpReg = base->C1;
    tmpReg &= ~I2C_C1_WUEN_MASK;
    base->C1 = tmpReg | I2C_C1_WUEN(slaveConfig->enableWakeUp) | I2C_C1_IICEN(slaveConfig->enableSlave);
    /* Configure general call & baud rate control & high drive feature. */
    tmpReg = base->C2;
    tmpReg &= ~(I2C_C2_SBRC_MASK | I2C_C2_GCAEN_MASK);
    tmpReg |= I2C_C2_SBRC(slaveConfig->enableBaudRateCtl) | I2C_C2_GCAEN(slaveConfig->enableGeneralCall);
#if defined(FSL_FEATURE_I2C_HAS_HIGH_DRIVE_SELECTION) && FSL_FEATURE_I2C_HAS_HIGH_DRIVE_SELECTION
    tmpReg &= ~I2C_C2_HDRS_MASK;
    tmpReg |= I2C_C2_HDRS(slaveConfig->enableHighDrive);
#endif
    base->C2 = tmpReg;
 楼主| hanzhen654 发表于 2018-9-16 23:25 | 显示全部楼层
void I2C_SlaveDeinit(I2C_Type *base)
    /* Disable I2C module. */
    I2C_Enable(base, false);
    /* Disable I2C clock. */
    CLOCK_DisableClock(s_i2cClocks[I2C_GetInstance(base)]);
void I2C_SlaveGetDefaultConfig(i2c_slave_config_t *slaveConfig)
    /* By default slave is addressed with 7-bit address. */
    slaveConfig->addressingMode = kI2C_Address7bit;
    /* General call mode is disabled by default. */
    slaveConfig->enableGeneralCall = false;
    /* Slave address match waking up MCU from low power mode is disabled. */
    slaveConfig->enableWakeUp = false;
    /* Default pin high drive is disabled. */
    slaveConfig->enableHighDrive = false;
#endif
    /* Independent slave mode baud rate at maximum frequency is disabled. */
    slaveConfig->enableBaudRateCtl = false;
    /* Enable the I2C peripheral. */
    slaveConfig->enableSlave = true;
 楼主| hanzhen654 发表于 2018-9-16 23:26 | 显示全部楼层
status_t I2C_SlaveWriteBlocking(I2C_Type *base, const uint8_t *txBuff, size_t txSize)
    return I2C_MasterWriteBlocking(base, txBuff, txSize);
void I2C_SlaveReadBlocking(I2C_Type *base, uint8_t *rxBuff, size_t rxSize)
    /* Wait until the data register is ready for receive. */
    /* Setup the I2C peripheral to receive data. */
    base->C1 &= ~(I2C_C1_TX_MASK);
    while (rxSize--)
        /* Read from the data register. */
        *rxBuff++ = base->D;
void I2C_SlaveTransferCreateHandle(I2C_Type *base,
                                   i2c_slave_handle_t *handle,
                                   i2c_slave_transfer_callback_t callback,
                                   void *userData)
    assert(handle);
    uint32_t instance = I2C_GetInstance(base);
    /* Zero handle. */
    memset(handle, 0, sizeof(*handle));
    /* Set callback and userData. */
    handle->callback = callback;
    handle->userData = userData;
    /* Save the context in global variables to support the double weak mechanism. */
    s_i2cHandle[instance] = handle;
    /* Save slave interrupt handler. */
    s_i2cSlaveIsr = I2C_SlaveTransferHandleIRQ;
    /* Enable NVIC interrupt. */
    EnableIRQ(s_i2cIrqs[instance]);
 楼主| hanzhen654 发表于 2018-9-16 23:27 | 显示全部楼层
status_t I2C_SlaveTransferNonBlocking(I2C_Type *base, i2c_slave_handle_t *handle, uint32_t eventMask)
    assert(handle);
    if (handle->isBusy)
        return kStatus_I2C_Busy;
    else
        /* Disable LPI2C IRQ sources while we configure stuff. */
        I2C_DisableInterrupts(base, kIrqFlags);
        /* Clear transfer in handle. */
        memset(&handle->transfer, 0, sizeof(handle->transfer));
        /* Record that we're busy. */
        handle->isBusy = true;
        /* Set up event mask. tx and rx are always enabled. */
        handle->eventMask = eventMask | kI2C_SlaveTransmitEvent | kI2C_SlaveReceiveEvent;
        /* Clear all flags. */
        I2C_SlaveClearStatusFlags(base, kClearFlags);
        /* Enable I2C internal IRQ sources. NVIC IRQ was enabled in CreateHandle() */
        I2C_EnableInterrupts(base, kIrqFlags);
void I2C_SlaveTransferAbort(I2C_Type *base, i2c_slave_handle_t *handle)
    assert(handle);
    if (handle->isBusy)
        /* Disable interrupts. */
        /* Reset transfer info. */
        handle->isBusy = false;
 楼主| hanzhen654 发表于 2018-9-17 09:18 | 显示全部楼层
status_t I2C_SlaveTransferGetCount(I2C_Type *base, i2c_slave_handle_t *handle, size_t *count)
    assert(handle);
    if (!count)
    /* Catch when there is not an active transfer. */
    if (!handle->isBusy)
        *count = 0;
        return kStatus_NoTransferInProgress;
    /* For an active transfer, just return the count from the handle. */
    *count = handle->transfer.transferredCount;
void I2C_SlaveTransferHandleIRQ(I2C_Type *base, void *i2cHandle)
    assert(i2cHandle);
    uint16_t status;
    bool doTransmit = false;
    i2c_slave_handle_t *handle = (i2c_slave_handle_t *)i2cHandle;
    i2c_slave_transfer_t *xfer;
    volatile uint8_t dummy = 0;
    /* Add this to avoid build warning. */
    dummy++;
    status = I2C_SlaveGetStatusFlags(base);
    xfer = &(handle->transfer);
#ifdef I2C_HAS_STOP_DETECT
    /* Check stop flag. */
    if (status & kI2C_StopDetectFlag)
        I2C_MasterClearStatusFlags(base, kI2C_StopDetectFlag);
        /* Call slave callback if this is the STOP of the transfer. */
        if (handle->isBusy)
            xfer->event = kI2C_SlaveCompletionEvent;
            xfer->completionStatus = kStatus_Success;
            if ((handle->eventMask & xfer->event) && (handle->callback))
                handle->callback(base, xfer, handle->userData);
        return;
#endif /* I2C_HAS_STOP_DETECT */
#if defined(FSL_FEATURE_I2C_HAS_START_STOP_DETECT) && FSL_FEATURE_I2C_HAS_START_STOP_DETECT
    /* Check start flag. */
    if (status & kI2C_StartDetectFlag)
        I2C_MasterClearStatusFlags(base, kI2C_StartDetectFlag);
        xfer->event = kI2C_SlaveRepeatedStartEvent;
        if (!(status & kI2C_AddressMatchFlag))
            return;
#endif /* FSL_FEATURE_I2C_HAS_START_STOP_DETECT */
    /* Check NAK */
    if (status & kI2C_ReceiveNakFlag)
        /* Set receive mode. */
        base->C1 &= ~(I2C_C1_TX_MASK | I2C_C1_TXAK_MASK);
        /* Read dummy. */
        dummy = base->D;
        if (handle->transfer.dataSize != 0)
            xfer->completionStatus = kStatus_I2C_Nak;
        else
#ifndef I2C_HAS_STOP_DETECT
#endif /* !FSL_FEATURE_I2C_HAS_START_STOP_DETECT or !FSL_FEATURE_I2C_HAS_STOP_DETECT */
    /* Check address match. */
    else if (status & kI2C_AddressMatchFlag)
        xfer->event = kI2C_SlaveAddressMatchEvent;
        /* Slave transmit, master reading from slave. */
        if (status & kI2C_TransferDirectionFlag)
            /* Change direction to send data. */
            base->C1 |= I2C_C1_TX_MASK;
            /* If we're out of data, invoke callback to get more. */
            if ((!xfer->data) || (!xfer->dataSize))
                xfer->event = kI2C_SlaveTransmitEvent;
                if (handle->callback)
                /* Clear the transferred count now that we have a new buffer. */
                xfer->transferredCount = 0;
            doTransmit = true;
        else
            /* Slave receive, master writing to slave. */
                xfer->event = kI2C_SlaveReceiveEvent;
            /* Read dummy to release the bus. */
            dummy = base->D;
    else if (status & kI2C_TransferCompleteFlag)
            doTransmit = true;
        else
            uint8_t data = base->D;
            if (handle->transfer.dataSize)
                /* Receive data. */
                *handle->transfer.data++ = data;
                handle->transfer.dataSize--;
                xfer->transferredCount++;
                if (!handle->transfer.dataSize)
                    /* Proceed receive complete event. */
    else
        /* Read dummy to release bus. */
        dummy = base->D;
    /* Send data if there is the need. */
    if (doTransmit)
            /* Send data. */
            base->D = *handle->transfer.data++;
        else
            /* Switch to receive mode. */
            dummy = base->D;
            /* Proceed txdone event. */
 楼主| hanzhen654 发表于 2018-9-17 09:19 | 显示全部楼层
void I2C0_DriverIRQHandler(void)
    I2C_TransferCommonIRQHandler(I2C0, s_i2cHandle[0]);
#if (FSL_FEATURE_SOC_I2C_COUNT > 1)
void I2C1_DriverIRQHandler(void)
    I2C_TransferCommonIRQHandler(I2C1, s_i2cHandle[1]);
#endif /* I2C COUNT > 1 */
#if (FSL_FEATURE_SOC_I2C_COUNT > 2)
void I2C2_DriverIRQHandler(void)
    I2C_TransferCommonIRQHandler(I2C2, s_i2cHandle[2]);
#endif /* I2C COUNT > 2 */
#if (FSL_FEATURE_SOC_I2C_COUNT > 3)
void I2C3_DriverIRQHandler(void)
    I2C_TransferCommonIRQHandler(I2C3, s_i2cHandle[3]);
晓伍 发表于 2018-10-9 10:36 | 显示全部楼层
OLED 是什么呀请问
观海 发表于 2018-10-9 11:32 | 显示全部楼层
OLED 是什么呀请问
有机发光二极管(Organic Light-Emitting Diode, OLED)又称为有机电激光显示、有机发光半导体。由美籍华裔教授邓青云(Ching W. Tang)于1979年在实验室中发现。OLED显示技术具有自发光、广视角、几乎无穷高的对比度、较低耗电、极高反应速度等优点。但是,作为高端显示屏,价格上也会比液晶电视要贵。
paotangsan 发表于 2018-10-9 12:39 | 显示全部楼层
非常感谢楼主分享
木木guainv 发表于 2018-10-9 14:56 | 显示全部楼层
非常感谢楼主分享
