【IoT】Arduino 实现 ESP32 BLE 与 Android 手机的数据交互
4038|2
 楼主| 观海 发表于 2018-10-26 12:51 | 显示全部楼层 |阅读模式
版权声明:本文为博主原创**,未经博主允许不得转载。        https://blog.csdn.net/liwei16611/article/details/80949777
1、效果描述:
通过简单的 Android APP 实现与 ESP32 的双向蓝牙通信。
2、实现步骤
Step 1:ESP32 硬件支持
1、支持蓝牙 4.0 以上协议的安卓手机;
2、支持 Micro USB 的 ESP32 dev board;
Step 2:配置 Arduino IDE 环境
1、下载 Arduino IDE:https://www.arduino.cc/en/Main/Software;
2、安装 ESP32 支持包:https://github.com/espressif/arduino-esp32/blob/master/docs/arduino-ide/windows.md
根据网站步骤安装 GIT 工具,并根据提示下载 BLE 支持开发包
在 Arduino 编写实例:
    Video: https://www.youtube.com/watch?v=oCMOYS71NIU
    Based on Neil Kolban example for IDF: https://github.com/nkolban/esp32-snippets/blob/master/cpp_utils/tests/BLE%20Tests/SampleNotify.cpp
    Ported to Arduino ESP32 by Evandro Copercini
   Create a BLE server that, once we receive a connection, will send periodic notifications.
   The service advertises itself as: 6E400001-B5A3-F393-E0A9-E50E24DCCA9E
   Has a characteristic of: 6E400002-B5A3-F393-E0A9-E50E24DCCA9E - used for receiving data with "WRITE"
   Has a characteristic of: 6E400003-B5A3-F393-E0A9-E50E24DCCA9E - used to send data with  "NOTIFY"
   The design of creating the BLE server is:
   1. Create a BLE Server
   2. Create a BLE Service
   3. Create a BLE Characteristic on the Service
   4. Create a BLE Descriptor on the characteristic
   5. Start the service.
   6. Start advertising.
   In this example rxValue is the data received (only accessible inside that function).
   And txValue is the data to be sent, in this example just a byte incremented every second.
#include <BLEDevice.h>
#include <BLEServer.h>
#include <BLEUtils.h>
#include <BLE2902.h>
BLECharacteristic *pCharacteristic;
bool deviceConnected = false;
float txValue = 0;
const int readPin = 32; // Use GPIO number. See ESP32 board pinouts
const int LED = 2; // Could be different depending on the dev board. I used the DOIT ESP32 dev board.
//std::string rxValue; // Could also make this a global var to access it in loop()
// See the following for generating UUIDs:
// https://www.uuidgenerator.net/
#define SERVICE_UUID           "6E400001-B5A3-F393-E0A9-E50E24DCCA9E" // UART service UUID
#define CHARACTERISTIC_UUID_RX "6E400002-B5A3-F393-E0A9-E50E24DCCA9E"
#define CHARACTERISTIC_UUID_TX "6E400003-B5A3-F393-E0A9-E50E24DCCA9E"
class MyServerCallbacks: public BLEServerCallbacks {
    void onConnect(BLEServer* pServer) {
      deviceConnected = true;
    void onDisconnect(BLEServer* pServer) {
class MyCallbacks: public BLECharacteristicCallbacks {
    void onWrite(BLECharacteristic *pCharacteristic) {
      std::string rxValue = pCharacteristic->getValue();
      if (rxValue.length() > 0) {
        Serial.println("*********");
        Serial.print("Received Value: ");
        for (int i = 0; i < rxValue.length(); i++) {
          Serial.print(rxValue);
        Serial.println();
        // Do stuff based on the command received from the app
        if (rxValue.find("A") != -1) {
          Serial.print("Turning ON!");
          digitalWrite(LED, HIGH);
        else if (rxValue.find("B") != -1) {
          Serial.print("Turning OFF!");
          digitalWrite(LED, LOW);
        Serial.println();
void setup() {
  Serial.begin(115200);
  pinMode(LED, OUTPUT);
  // Create the BLE Device
  BLEDevice::init("ESP32 UART Test"); // Give it a name
  // Create the BLE Server
  BLEServer *pServer = BLEDevice::createServer();
  pServer->setCallbacks(new MyServerCallbacks());
  // Create the BLE Service
  BLEService *pService = pServer->createService(SERVICE_UUID);
  // Create a BLE Characteristic
  pCharacteristic = pService->createCharacteristic(
                      CHARACTERISTIC_UUID_TX,
                      BLECharacteristic::PROPERTY_NOTIFY
  pCharacteristic->addDescriptor(new BLE2902());
  BLECharacteristic *pCharacteristic = pService->createCharacteristic(
                                         CHARACTERISTIC_UUID_RX,
                                         BLECharacteristic::PROPERTY_WRITE
  pCharacteristic->setCallbacks(new MyCallbacks());
  // Start the service
  pService->start();
  // Start advertising
  pServer->getAdvertising()->start();
  Serial.println("Waiting a client connection to notify...");
void loop() {
  if (deviceConnected) {
    // Fabricate some arbitrary junk for now...
    txValue = analogRead(readPin) / 3.456; // This could be an actual sensor reading!
    // Let's convert the value to a char array:
    char txString[8]; // make sure this is big enuffz
    dtostrf(txValue, 1, 2, txString); // float_val, min_width, digits_after_decimal, char_buffer
//    pCharacteristic->setValue(&txValue, 1); // To send the integer value
//    pCharacteristic->setValue("Hello!"); // Sending a test message
    pCharacteristic->setValue(txString);
    pCharacteristic->notify(); // Send the value to the app!
    Serial.print("*** Sent Value: ");
    Serial.print(txString);
    Serial.println(" ***");
    // You can add the rxValue checks down here instead
    // if you set "rxValue" as a global var at the top!
    // Note you will have to delete "std::string" declaration
    // of "rxValue" in the callback function.
//    if (rxValue.find("A") != -1) {
//      Serial.println("Turning ON!");
//      digitalWrite(LED, HIGH);
//    else if (rxValue.find("B") != -1) {
//      Serial.println("Turning OFF!");
//      digitalWrite(LED, LOW);
  delay(1000);
Step 3:下载安装 APP 测试工具
可以在资源栏下载:https://download.csdn.net/download/liwei16611/10526621
 楼主| 观海 发表于 2018-10-26 12:53 | 显示全部楼层
3、代码解释
3.1、库文件:
创建 BLE 设备:
创建 BLE server:
创建 BLE service:
添加 characteristics:
启动广播:
3.2、定义 service 和 characteristic UUID:TX | RX
3.3、蓝牙连接回调函数
class MyServerCallbacks: public BLEServerCallbacks {<br>    void onConnect(BLEServer* pServer) {
3.4、数据接收回调函数
class MyCallbacks: public BLECharacteristicCallbacks {<br>    void onWrite(BLECharacteristic *pCharacteristic) {
      std::string rxValue = pCharacteristic->getValue();</p><p>      if (rxValue.length() > 0) {
        Serial.print("Received Value: ");</p><p>        for (int i = 0; i < rxValue.length(); i++) {
          Serial.print(rxValue[i]);
        }</p><p>        Serial.println();</p><p>        // Do stuff based on the command received from the app
古美门 发表于 2019-2-15 15:15 | 显示全部楼层
上个月,ESP-EYE的参考设计正式上线,利用该设计,就可以轻易试水人脸识别的开发。
这里和还没注意到的各位朋友分享一下!
以下是入门指南 :
https://github.com/espressif/esp-who/blob/master/docs/zh_CN/get-started/ESP-EYE_Getting_Started_Guide.md
基于搭载 ESP32 芯片、200 W 像素摄像头、数字麦克风、8 MB PSRAM 和 4 MB Flash,开发者就可动手人脸识别的 AI 应用开发。重点来了: 因为有图传功能,用上PSRAM,就可作为内存缓冲功能,存储计算空间多了,视觉上的识别性能表现当然更优,而我的公司就是生产PSRAM的厂商。利用ESP-EYE能开发的应用方面,我来举例一下:
最主打的,应该是 : 门禁、考勤、自动售卖设备、智能储物锁、VIP识别系统,这些基於人脸识别的系统,都可利用ESP EYE的基础去进行深度开发。
另外,识物应用也有很广泛的应用可能性。如工厂生产线的图像检查、警报装置、环境监察、农作物品质分类。
此外,该开发板还支持 Wi-Fi 图像传输、Micro USB 调试和供电,可以实现语音唤醒,可协助用户开发高度集成的 AI 解决方案。
希望以上一些分享能对大家有帮助,欢迎交流~~
