[PIC32/SAM] 恭喜Microchip SAMA5D2 System-on-Module荣获2018年度最佳产品奖!
1799|6
 楼主| MCHPMPU 发表于 2019-1-21 10:15 | 显示全部楼层 |阅读模式
恭喜Microchip SAMA5D2 System-on-Module荣获2018年度Electronic Products最佳产品奖!!
Microchip Technology
www.microchip.com
There is extensive design effort and complexity associated with creating an industrial-grade MPU-based system running a Linux operating system, said Microchip, and even experienced developers spend a lot of time on PCB layout to guarantee signal integrity for the high-speed interfaces to DDR memory and Ethernet PHY while complying with EMC standards.
The SAMA5D2 system-on-module (SOM) simplifies design by integrating the power management, non-volatile boot memory, Ethernet PHY, and high-speed DDR2 memory on a small, single-sided PCB. Microchip’s SAMA5D2 SOM is a single-sided PCB with 169 components including the Arm Cortex-A5–based SAMA5D2 SiP that integrates DDR2 memory in a single package, simplifying designs by removing high-speed memory interface constraints from a PCB.
All of Microchip’s Linux development codes for the SAMA5D2 SiP and SOM are mainlined in the Linux communities, so customers can connect external devices with minimal software development. The SOM1-EK1 development board provides an evaluation platform for both the SOM and the SiP.
https://www.electronicproducts.com/News/Electronic_Products_announces_winners_of_the_2018_Product_of_the_Year_Awards.aspx
麦小播 发表于 2019-1-21 10:51 | 显示全部楼层
Microchip公司表示,创建一个运行Linux操作系统的工业级基于MPU的系统需要大量的设计工作和复杂性,甚至经验丰富的开发人员也花费大量时间在PCB布局上,以保证高速接口的信号完整性。 DDR存储器和以太网PHY,符合EMC标准。
SAMA5D2系统级模块(SOM)通过在小型单面PCB上集成电源管理,非易失性启动存储器,以太网PHY和高速DDR2存储器,简化了设计。 Microchip的SAMA5D2 SOM是一款单面PCB,包含169个元件,包括基于Arm Cortex-A5的SAMA5D2 SiP,它将DDR2存储器集成在一个封装中,通过消除PCB的高速存储器接口限制简化了设计。
所有Microchip针对SAMA5D2 SiP和SOM的Linux开发代码都在Linux社区中得到了强化,因此客户可以通过最少的软件开发来连接外部设备。 SOM1-EK1开发板为SOM和SiP提供评估平台。
谢谢楼主分享
小播插播个google翻译版简介,方便下各位网友了解。
小卡 发表于 2019-1-21 15:43 | 显示全部楼层
恭喜了
dongnanxibei 发表于 2019-1-21 23:47 | 显示全部楼层
这,怎么玩?
 楼主| MCHPMPU 发表于 2019-1-22 11:39 | 显示全部楼层
这是模块,可以理解为核心板。我们有SAMA5D27-SOM1-EK,这个就可以玩了
https://www.microchip.com/Develo ... ATSAMA5D27-SOM1-EK1
yjmeishao 发表于 2019-1-24 19:33 | 显示全部楼层
又有一款基于Microchip SAMA5D27C-D1G MPU的开源硬件板准备发布:估计又会是一款爆红的创客利器
希望能够像树莓派一样有更多更好的应用和库的支持
With the release of the ATSAMA5D27C-D1G, its made linux possible in such a small form factor.
Listed below are the specs and current pinout of the board.
Specs:
  • Microchip SAMA5D2 ARM® Cortex®-A5 Processor 500MHz
  • 128MB DDR2 RAM built-in to the SiP
  • 6X 12-Bit ADC with 3.3V Reference
  • 4X 16-Bit PWM
  • ADC external trigger
  • PWM external trigger
  • 1X I2C
  • 1X SPI
  • 1X UART
  • Full 3.7V LIPO support for portable projects
  • Micro SD for OS and storage
  • 4.14 linux kernel
bear1 发表于 2019-12-16 13:46 | 显示全部楼层
啥价格?
