[应用相关]
7026规格书
1403|6
TI, AN, TE, IO, AC
Chrontel
CH7025/CH7026
Brief Datasheet
CH7025/CH7026 TV/VGA Encoder
Features                                                        General Description
•   TV encoder targets the handheld devices and other appropriate display devices used in consumer
products. (i.e. automobile)
•   Support multiple output formats. Such as SDTV format (NTSC and   PAL),   HDTV   format   for
480p,576p,720p   and   1080i, analog RGB output for VGA. Sync signals can be provided in separated
or composite manner (programmable composite sync generation).
•   Three   on-chip  10-bit   high  speed   DACs   providing   flexible output  capabilities.  Such
as  single,  double  or  triple  CVBS outputs,  YPbPr  output,  RGB  output  and  simultaneous
CVBS and S-video outputs.
•   16Mbits SDRAM is used as frame buffer. Supporting for frame rate conversion.
•   Flexible up and down scaling engine is embedded including de- flickering capability.
•   Programmable    24-bit/18-bit/16-bit/15-bit/12-bit/8-bit    digital input  interface  supports
various   RGB   (RGB888,   RGB666, RGB565 and etc), YCbCr (4:4:4 YCbCr, ITU656) and 2x or 3x
multiplexed input. CPU interface are also supported.
•   Support   for   flexible   input   resolution   up   to   800x800   and 1024x680.
•   Pixel   by   pixel   brightness,   contrast,   hue   and   saturation adjustment  for  each
kind  of  output  is  supported.  (For  RGB output, only brightness and contrast adjustment is
supported).
•   Pixel  by  pixel  horizontal  position  adjustment  and  line  by  line vertical position
adjustment are supported.
•   90/180/270 degree image rotation and vertical or horizontal flip functions are supported.
•   Macrovision   7.1.L1   for   SDTV   is   supported   in   CH7025. (CH7026 is Non-Macrovision
part.)
•   MacrovisionTM  copy  protection  support  for  progressive  scan TV (480p, 576p CH7025 only)
•   CGMS-A support for SDTV and HDTV
•   TV/Monitor connection detect capability. DAC can be switched off based on detection result.
(Driver support is required)
•   Programmable power management.
•   Flexible  pixel  clock  frequency  from  graphics  controller  is supported.   (2.3MHz
–120MHz)   Flexible   input   clock   from crystal or oscillator is supported. (2.3MHz – 64MHz)
•   Only slave mode supported.
•   Offered in BGA or QFP package.
•   Fully programmable through serial port.
•   IO and SPC/SPD voltage supported is from 1.2V to 3.3V.
The    CH7025/CH7026    is    a    device    targeting handheld and similar systems which accept
digital input   signal,   and   encodes   and   transmits   data through 10-bit DACs.  The device
is able to encode the   video   signals   and   generate   synchronization signals    SDTV
format    for    NTSC    and    PAL standards  and  HDTV  format  for  480p,576p,720p and  1080i.
Analog  RGB  output  and  composite SYNC   signal  are   also  supported.     The  device accepts
different data formats including RGB and YCbCr (e.g. RGB565, RGB666, RGB888, ITU656
like YCbCr, etc.). 16Mbit SDRAM is embedded in package. Frame rate conversion and Image rotation
are possible.
Note: the above feature list is subject to change without notice. Please contact Chrontel for more
information and current updates.
209-1000-004      Rev. 1.1,          12/3/2008
CHRONTEL                                                           CH7025/CH7026
SDRAM
RGB/YCbCr
CSB WEB
VSYNC DIN
Input data format decoder
CPU
interface
MUX
CSC
(YCbCr to RGB)
Scaler
MUX
CSC
(RGB to YUV)
HUE SAT BRI CON VP HP
TV formater
SPC
SPD
XI
XO
Serial port
PLL
MUX
BRI CON VP HP
DAC 1
DAC 2
DAC 3
R/Y/CVBS/Y_Svideo
G/Pb/CVBS/C-Svideo
G/Pr/CVBS
H,V,DE
SYNC
position adjust
Composite sync generation
CSYNC VSYNC HSYNC
Figure 1: CH7025/CH7026 block diagram
1.0   Pin-out
1.1     Package Diagram
1           2           3           4           5           6           7           8           9
A
                     A
B
                      B
C
                      C
D
                     D
E
                      E
F
                      F
G
                     G
H
                     H
J
                       J
K
                     K
L
                      L
1           2           3           4           5           6           7           8           9
Figure 2: BGA Package
HSO        1
VSO        2
CSYNC        3
ATPG        4
AS        5
ResetB        6
AGND        7
AVDD        8
GNDQ_MEM        9
VDDQ_MEM       10
AGND       11
AVDD       12
GND_MEM       13
VDD_MEM       14
NC       15
NC       16
NC       17
VDDQ_MEM       18
GNDQ_MEM       19
NC       20
CH7025/CH7026
60        D[8]
59        D[7]
58        D[6]
57        D[5]
56        D[4]
55        D[3]
54        D[2]
53        D[1]
52        D[0]
51        VDDIO
50        GCLK
49        AVDD
48        AGND
47        GND_MEM
46        GND_MEM
45        VDD_MEM
44        VDD_MEM
43        NC
42        NC
41        NC
Figure 3: 80 Pin LQFP Package
1.2     Pin Description
Table 1: Pin Name Description (BGA Package)
Pin #                                Type         Symbol                   Description
A3, E4, B4, A4,
E5, B5, A5, D4,
D5, D6, A7, E6,
B7, A8, F6, B8,
B9, C9, C8, D9, D8, E8, F7, E9
In               D[23:0]                    Data[0] through Data[23] Inputs
These  pins  accept  the  24  data  inputs  from  a  digital  video port  of  a  graphics
controller.    The  swing  is  defined  by VDDIO.
C2                                    In/Out        V                              Vertical Sync
Input / Output
When the SYO control bit is low, this pin accepts a vertical sync input for use with the input
data.  The amplitude will be 0 to VDDIO.
When the SYO control bit is high, the device will output a vertical sync pulse.  The output is
driven from the VDDIO supply.
B3                                    In/Out        H/WEB                   Horizontal Sync Input /
Output
When the SYO control bit is low, this pin accepts a horizontal sync input for use with the input
When the SYO control bit is high, the device will output a horizontal sync pulse.  The output is
It is also the WEB signal of CPU interface.
A2                                    In               DE/CSB                  Data Input Indicator
When the pin is high, the input data is active. When the pin is low, the input data is blanking. It
is also the CSB signal of CPU interface
D2                                    In               AS                           Address select
F5                                    In               ATPG                      ATPG Enable
(Internally pull-down)
This  pin  should  be  left  open  or  pulled  low  with  a  10k resistor  in  the  application.
This  pin  configures  the  pre- condition for scan chain and boundary scan test when high.
Otherwise it should be low. Voltage level is 0 to 3.3V.
C1                                    In               ResetB                     Reset * Input
When  this  pin  is  low,  the  device  is  held  in  the  hardware reset condition.   When this
pin is high, reset is controlled through the serial port.
K9                                    In/Out        SPD                         Serial Port Data
Input / Output
This pin functions as the bi-directional data pin of the serial port. External pull-up resister is
required.
L9                                    In               SPC                         Serial Port
Clock Input
This  pin  functions  as  the  clock  pin  of  the  serial  port. External pull-up resister is
required.
L4                                    Out            DAC0                      CVBS, S-video, YPbPr
or Analog RGB output Full swing is up to 1.3v
L3                                    Out            DAC1                      CVBS, S-video, YPbPr
L2                                    Out            DAC2                      CVBS, S-video, YPbPr
L5                                    In               ISET                        Current Set
Resistor Input
This  pin  sets  the  DAC  current.   A  1.2k  Ω,  1%  tolerance resistor   should   be   connected
  between   this   pin   and AGND_DAC using short and wide traces.
K7                                    In               XI                            Crystal Input
/ External Input
For some situation of the slave mode, a parallel resonance crystal ( 20 ppm) should be attached
between this pin and XO.   However, an external 3.3V CMOS compatible clock can drive the XI/FIN
input.
K8                                    Out            XO                           Crystal Output
between this pin and XI / FIN.  However, if an external CMOS clock is attached to XI/FIN, XO should
be left open.
F9                                    In               GCLK                     External Clock
Inputs
The input is the clock signal input to the device for use with the H, V, DE and D[23:0] data.
B1                                    Out            VSO                        Vertical sync
signal output
B2                                    Out            HSO                        Horizontal sync
signal output
A1                                    Out            CSYNC                   Composite sync output
F8                                    Power        VDDIO                   IO supply voltage
(1.2-3.3V)
B6                                    Power        DVDD                     Digital supply voltage
(1.8V)
D1, F1, L7, G9                Power        AVDD                     Analog supply voltage (2.5 –
3.3V) K6                                    Power        AVDD_PLL            PLL supply voltage
(1.8V)
K4                                    Power        AVDD_DAC          DAC power supply (2.5 – 3.3V)
E2, H1                             Power        VDDQ_MEM         SDRAM output buffer supply voltage
(2.5V)
G2, J8, H6                       Power        VDD_MEM            SDRAM device supply voltage (2.5V)
A6                                    Power        DGND                     Digital supply ground
F4, F2, L6, G8                 Power        AGND                     Analog supply ground K5
                            Power        AGND_PLL            PLL supply ground
K3                                    Power        AGND_DAC          DAC supply ground
E1, J1                               Power        GNDQ_MEM         SDRAM output buffer supply
ground F3, H9, H8                       Power        GND_MEM            SDRAM device supply ground
Table 2: Pin Name Descriptions (LQFP80 Package) Pin #           Type             Symbol
      Description
52 - 67
70 - 77
79                In/Out           V                             Vertical Sync Input / Output
78                In/Out           H/WEB                   Horizontal Sync Input / Output
80                In                  DE/CSB                 Data Input Indicator
CSB signal input of CPU interface
5                  In                  AS                          Chip address select 0: 76h
1: 75h
4                  In                  ATPG                     ATPG Enable (Internally pull-down)
This pin should be left open or pulled low with a 10k resistor in the application.  This  pin
configures  the  pre-condition  for  scan  chain  and boundary  scan  test  when  high.  Otherwise
6                  In                  ResetB                    Reset * Input
When  this  pin  is  low,  the  device  is  held  in  the  power-on  reset condition.  When this
38                In/Out           SPD                        Serial Port Data Input / Output
resister is required.
39                In                  SPC                        Serial Port Clock Input
This pin functions as the clock pin of the serial port. External pull-up resister is required.
29                Out               DAC0                     CVBS, S-video, YPbPr or Analog RGB
output
27                Out               DAC1                     CVBS, S-video, YPbPr or Analog RGB
output
25                Out               DAC2                     CVBS, S-video, YPbPr or Analog RGB
output
31                In                  ISET                       Current Set Resistor Input
be connected between this pin and AGND_DAC using short and wide traces.
35                In                  XI                           Crystal Input / External Input
XI/FIN input.
36                Out               XO                          Crystal Output
XO  should  be  left open.
50                In                  GCLK                     External Clock Inputs
2                  Out               VSO                       Vertical sync signal output,
The amplitude of this pin is from 0 to AVDD
1                  Out               HSO                       Horizontal sync signal output,
3                  Out               CSYNC                  Composite sync output,
51                Power           VDDIO                   IO supply voltage (1.2 – 3.3V)
69                Power           DVDD                    Digital supply voltage (1.8V)
8, 12
37, 49
Power           AVDD                    Analog supply voltage(2.5 – 3.3V)
33                Power           AVDD_PLL           PLL supply voltage(1.8V)
24, 28          Power           AVDD_DAC         DAC power supply(2.5 – 3.3V)
14, 44
45
Power           VDDQ_MEM        SDRAM output buffer supply voltage(2.5V) Power           VDD_MEM
       SDRAM device supply voltage(2.5V)
68                Power           DGND                    Digital supply ground
7, 11, 34
48
32                Power           AGND_PLL           PLL supply ground 26, 30          Power
9, 19            Power           GNDQ_MEM        SDRAM output buffer supply ground
13, 46,
47
2.0   Package Dimensions
A1  Conrer
1          2          3          4
5           6          7          8           9
9          8          7          6
5          4          3          2
A1  Conrer
A
                                A
B
                                B
C
                                C
D
                                D
D
E
                                E
C        F
F
G
                                G
H
                                H
J
                                 J
K
                                K
L
                                L
F
(  Top  View  )
        E
B
(  Bottom  View  )
K
H        I        J
G
Figure 4: 80 Pin BGA Package
Table of Dimensions
No. of Leads        SYMBOL
80 (5 X 6 mm)            A           B           C           D           E           F           G
          H            I          J         K
Milli-
Min
6.00       5.00       5.00       0.50       4.00       0.50
0.22
0.30     0.60     0.30
meters        Max
          1.20         0.30
Notes:
1.    All dimensions conform to JEDEC standard MO-216.
A B
I
A    B
H
C               D                                                     J
F          E
G
Figure 5: 80 Pin LQFP Package
LEAD
CO-PLANARITY
.004 “
Table of Dimensions
No. of Leads        SYMBOL
80 (10 X 10 mm)          A              B              C              D              E
F              G              H               I               J
Milli-
MIN         11.90         9.90
0.40
0.13          1.35          0.05
1.00
0.45          0.09            0°
meters        MAX        12.10        10.10
0.23          1.45          0.15
0.75          0.20            7°
Notes:
1.  Conforms to JEDEC standard JESD-30 MS-026D.
2.  Dimension B: Top Package body size may be smaller than bottom package size by as much as 0.15
mm.
3.  Dimension B does not include allowable mold protrusions up to 0.25 mm per side.
Disclaimer
This document provides technical information for the user.   Chrontel reserves the right to make
changes at any time without notice to improve and supply the best possible product and is not
responsible and does not assume any liability for misapplication or use outside the limits
specified in this document.  We provide no warranty  for  the  use  of  our  products  and  assume
no  liability  for  errors  contained  in  this  document.   The customer  should  make  sure  that
they  have  the  most  recent  data  sheet  version.    Customers  should  take appropriate
action  to  ensure  their  use  of  the  products  does  not  infringe  upon  any  patents.
Chrontel,  Inc. respects valid patent rights of third parties and does not infringe upon or assist
others to infringe upon such rights.
Chrontel PRODUCTS ARE NOT AUTHORIZED FOR AND SHOULD NOT BE USED WITHIN LIFE SUPPORT SYSTEMS  OR
NUCLEAR  FACILITY  APPLICATIONS  WITHOUT  THE  SPECIFIC  WRITTEN  CONSENT  OF
Chrontel.  Life support systems are those intended to support or sustain life and whose failure to
perform when used as directed can reasonably expect to result in personal injury or death.
ORDERING INFORMATION
Part Number          Package Type               Copy
Protection
Operating Temperature Range
CH7025B-GF          80TFBGA, Lead-free     Macrovision™     Commercial : -20 to 70C CH7025B-GFI
     80TFBGA, Lead-free     Macrovision™     Industrial : -40 to 85C CH7025B-TF          80LQFP,
Lead-free        Macrovision™     Commercial : -20 to 70C CH7025B-TFI         80LQFP, Lead-free
    Macrovision™     Industrial : -40 to 85C CH7026B-GF          80TFBGA, Lead-free     None
            Commercial : -20 to 70C CH7026B-GFI         80TFBGA, Lead-free     None
   Industrial : -40 to 85C CH7026B-TF          80LQFP, Lead-free        None
Commercial : -20 to 70C CH7026B-TFI         80LQFP, Lead-free        None
2008 Chrontel    All Rights Reserved.
Chrontel
Chrontel International Limited
129 Front Street, 5th floor, Hamilton, Bermuda HM12 www.chrontel.com
E-mail: sales@chrontel.com
深圳市北七星|  楼主 | 2019-3-22 17:20 | 只看该作者
需要各类规格书的请联系楼主0755-23128029
深圳市北七星|  楼主 | 2019-3-22 17:21 | 只看该作者
国内IC代理,有需要的朋友请加Q:867784767
keaibukelian| | 2019-4-9 10:36 | 只看该作者
7026是什么啊
heimaojingzhang| | 2019-4-9 11:26 | 只看该作者
是st的芯片吗?
guanjiaer| | 2019-4-9 11:29 | 只看该作者
全英文看不懂啊
观海| | 2019-4-9 11:45 | 只看该作者
这个是单片机?
