看这张图中,晶振上顶了个什么东西?
28834|143
computer00 发表于 2008-10-6 11:30 | 显示全部楼层
哈哈……这么好玩,我再顶上去……
sxfsyl 发表于 2008-10-6 11:50 | 显示全部楼层
6652
乐乐误乐
oufuqiang 发表于 2008-10-6 13:03 | 显示全部楼层
我知道了!
我知道了
oufuqiang 发表于 2008-10-6 13:04 | 显示全部楼层
其实我还是不知道……
awey 发表于 2008-10-6 13:09 | 显示全部楼层
●●●晕!!又一次误入,请版主移除此贴●●●
tyw 发表于 2008-10-6 14:00 | 显示全部楼层
水,牛,晕,溜!
<br /><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><br /><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><br /><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><br /><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><br /><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif"><img src="https://bbs.21ic.com/upfiles/img/200711/20071121141647475.gif">
xianrenly 发表于 2008-10-6 15:14 | 显示全部楼层
忽悠
呵呵。电路板上也来“小高层”?
杨真人 发表于 2008-10-6 15:51 | 显示全部楼层
4楼的猜测,10楼的评价.
这样处理的确是比较二
awey 发表于 2008-10-6 16:10 | 显示全部楼层
★★ 00变态,还说好玩,我都被它烦死了 ★★
已经不小心踩进来N此了`~~~
fa2008 发表于 2008-10-6 17:49 | 显示全部楼层
答案公布
那是楼主焊上去的,哈哈<br /><br />没事逗大家玩呢。
圆圈 发表于 2008-10-6 18:40 | 显示全部楼层
我看楼主是闲着没事干&nbsp;&nbsp;&nbsp;&nbsp;焊个电阻上去发张图片,&nbsp;&nbsp;&nbsp;然后躲在一边偷笑~~~&nbsp;&nbsp;&nbsp;
hpzax 发表于 2008-10-7 10:08 | 显示全部楼层
是个电阻。没啥用的吧?
是个电阻。没啥用的吧?
computer00 发表于 2008-10-7 10:15 | 显示全部楼层
哈哈~~~踩进来就顺便看看嘛~~~所以我建议21IC搞这个一个功能
鼠标指到回复的主题,就能自动弹出主帖的标题,这样就不会误入了……
computer00 发表于 2008-10-7 11:04 | 显示全部楼层
其实这是一个防伪标志~~~~如果别人也这么干,估计是抄的6
zyok 发表于 2008-10-7 12:21 | 显示全部楼层
严重赞成93楼,早就有这个想法....
fjfjja 发表于 2008-10-7 16:50 | 显示全部楼层
估计就是个编号而已!
估计就是个编号而已!
hibernation 发表于 2008-10-8 00:28 | 显示全部楼层
确实奇怪,看来不能用正常人的思维了,哈哈
那个电阻在电路上完全没有任何作用,充其量就是做的标识。掩盖频率也不用这样,至于用于引线就更不必这样了。
無智 发表于 2008-10-8 13:45 | 显示全部楼层
100楼
纯粹为了加盖!<br />
linqing171 发表于 2008-10-8 17:15 | 显示全部楼层
电阻是z599不是6652
这个电阻可能是为了固定高度。串口线上接的东西,外壳可能不怎么好固定,放上这个纯粹的是为了固定高度。<br /><br />另外也不排除忽悠客户。<br />还有忽悠看这个帖子的。<br />电阻是z599不是6652,感觉599是精密电阻,但是665不怎么像。<br /><br />其实480M的总线照样用的是12M的晶振,芯片里面倍频就是了,可能是怕让消费者看到12M几个字误以为是usb低速的。
haisizzm 发表于 2008-10-8 20:01 | 显示全部楼层
倒底是什么东西呀
