请教stm32 i2c轮询为什么要在此处关闭中断
3220|0
 楼主| haov000 发表于 2011-9-24 10:57 | 显示全部楼层 |阅读模式
  1. while (NumByteToRead)
  2.     {
  3.
  4.         if (NumByteToRead != 3) /* Receive bytes from first byte until byte N-3 */
  5.         {
  6.             while ((I2C_GetLastEvent(I2C1) & 0x00004) != 0x000004); /* Poll on BTF */
  7.             /* Read data */
  8.             *pBuffer = I2C_ReceiveData(I2C1);
  9.             pBuffer++;
  10.             /* Decrement the read bytes counter */
  11.             NumByteToRead--;
  12.         }
  13.
  14.         if (NumByteToRead == 3)  /* it remains to read three data: data N-2, data N-1, Data N */
  15.         {
  16.
  17.             /* Data N-2 in DR and data N -1 in shift register */
  18.             while ((I2C_GetLastEvent(I2C1) & 0x000004) != 0x0000004); /* Poll on BTF */
  19.             /* Clear ACK */
  20.             I2C_AcknowledgeConfig(I2C1, DISABLE);
  21.             __disable_irq();
  22.             /* Read Data N-2 */
  23.             *pBuffer = I2C_ReceiveData(I2C1);
  24.             pBuffer++;
  25.             /* Program the STOP */
  26.             I2C_GenerateSTOP(I2C1, ENABLE);
  27.             /* Read DataN-1 */
  28.             *pBuffer = I2C_ReceiveData(I2C1);
  29.              __enable_irq();
  30.             pBuffer++;
  31.             while ((I2C_GetLastEvent(I2C1) & 0x00000040) != 0x0000040); /* Poll on RxNE */
  32.             /* Read DataN */
  33.             *pBuffer = I2C1->DR;
  34.             /* Reset the number of bytes to be read by master */
  35.             NumByteToRead = 0;
  36.
  37.         }
  38.     }
请教下,为什么在禁能了ack后,要先关闭中断,再去读data N-2数据和data N-1数据呢,如果不管中断会造成什么后果,请指教?
