分享LM3S8962开发板SPI读取铁电代码
5003|5
 楼主| lilihua0721 发表于 2011-10-3 20:27 | 显示全部楼层 |阅读模式
分享LM3S8962开发板SPI读取铁电代码前面很多网友提问LM3S的SPI不好用或者用不了,通常用GPIO模拟,经过我2天的调试,SPI完全能用,效率还不错,下面提供主要函数和代码,调试时根据布板情况先从低波特率往上加,我是从9600开始调,最高1M没有问题,再高有点不稳定因为我电路板是飞线的线有点长,后面附逻辑分析仪截图,我写的铁电型号是FM25L256
//SSI初始化
void SSIInit(void)
  SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);//使能GPIOA
  SysCtlPeripheralEnable(SYSCTL_PERIPH_SSI0);//使能SSI
  SSIDisable(SSI0_BASE);
  GPIOPinTypeSSI(GPIO_PORTA_BASE, (GPIO_PIN_2 | GPIO_PIN_3 | GPIO_PIN_4 | GPIO_PIN_5));
  GPIODirModeSet(GPIO_PORTA_BASE, GPIO_PIN_3, GPIO_DIR_MODE_OUT);//配置片选管脚为输出
  GPIOPadConfigSet(GPIO_PORTA_BASE, GPIO_PIN_2 | GPIO_PIN_3 | GPIO_PIN_4 | GPIO_PIN_5, GPIO_STRENGTH_8MA, GPIO_PIN_TYPE_STD_WPU);
  SSIConfig(SSI0_BASE,SSI_FRF_MOTO_MODE_3, SSI_MODE_MASTER, 9600, 8);//配置SSI
  SSIEnable(SSI0_BASE);//使能SSI
//使能SPI
void SPIEnable()
    unsigned long ulTemp;
    SSIConfig(SSI0_BASE, SSI_FRF_MOTO_MODE_3, SSI_MODE_MASTER, 9600, 8);
    GPIOPinTypeSSI(GPIO_PORTA_BASE, GPIO_PIN_3);
    GPIOPadConfigSet(GPIO_PORTA_BASE, GPIO_PIN_3, GPIO_STRENGTH_8MA, GPIO_PIN_TYPE_STD_WPU);
    GPIOPinWrite(GPIO_PORTA_BASE, GPIO_PIN_3, ~GPIO_PIN_3);
    while(SSIDataGetNonBlocking(SSI0_BASE, &ulTemp) != 0)//清除FIFO
//禁止SPI
void SPIDisable()
    GPIOPinTypeGPIOOutput(GPIO_PORTA_BASE, GPIO_PIN_3);
    GPIOPinWrite(GPIO_PORTA_BASE, GPIO_PIN_3, GPIO_PIN_3);
//发送一个字节
void Send_Byte(unsigned char data)
   unsigned long NullData;
   SSIDataPut(SSI0_BASE, data);
   SSIDataGet(SSI0_BASE, &NullData);
//接收一个字节
unsigned char Get_Byte(void)
   unsigned long ReadData;
   SSIDataPut(SSI0_BASE, 0xff);//发送一个无效字节,以产生接收时钟
   SSIDataGet(SSI0_BASE, &ReadData);
   return (unsigned char)ReadData;
//----------main主函数------------------------------------
SSIInit();//初始化SPI
SPIEnable();//使能铁电
Send_Byte(0x3);//发送读命令
Send_Byte(0x0);//读取数据地址高字节
Send_Byte(0x0);//读取数据地址低字节
sfbuf[0]=Get_Byte();//读取数据
sfbuf[1]=Get_Byte();
sfbuf[2]=Get_Byte();
sfbuf[3]=Get_Byte();
SPIDisable();//禁止铁电
SysCtlDelay(100*(TheSysClock/3000));
SPIEnable();
Send_Byte(0x06);//发送写使能命令
SPIDisable();
SPIEnable();
Send_Byte(0x02);//发送字节数据烧写命令
Send_Byte(0x0);//发送2个字节的地址信息
Send_Byte(0x0);
Send_Byte(0x60);
Send_Byte(0x61);
Send_Byte(0x62);
Send_Byte(0x63);
SPIDisable();
SPIEnable();//使能铁电
SPIDisable();//禁止铁电
写铁电截图
读铁电截图
heartthrob 发表于 2012-4-8 23:02 | 显示全部楼层
在写的操作中,为什么在发送写使能命令后,还要来个CS的上升下降沿
我准备使用25CL64B,但还没有测试
在PDF中的时序图中,可以看到写写使能和写存储器命令中间,不需要CS无效后再有效
不知楼主是基于哪方面的考虑,将CS这样处理??
larrybird 发表于 2012-4-9 17:10 | 显示全部楼层
用什么截的图片啊?
TI_MCU 发表于 2012-4-9 21:16 | 显示全部楼层
感谢楼主分享~要是有时间把DMA功能加上就好啦
TomCOTO 发表于 2013-5-10 17:41 | 显示全部楼层
感谢分享,学习中
1988020566 发表于 2013-5-13 22:31 | 显示全部楼层
学习的。
