[设计心得]最后才发现它是xilinx的AR
2363|6
 楼主| hjjnet 发表于 2011-10-10 23:04 | 显示全部楼层 |阅读模式
问题描述:
    下载线缆编程XC18V04 ,verify 总是fail
 楼主| hjjnet 发表于 2011-10-10 23:05 | 显示全部楼层
老问题了,解决办法:二话不说,直接把编程速度降到最低,issue 消失
 楼主| hjjnet 发表于 2011-10-10 23:06 | 显示全部楼层
后来在网上看了一下,竟然还是一个AR,感叹不已
        Programming/Verifying 18V00 PROMs with Platform USB cable fails
        Description
        Keywords: 18v04, 18v02, 18V01, 18V512, error, program
iMPACT reports "Programming Failed" or "Verify Failed" when I use a Platform Cable USB to program and verify a XC18V512, XC18V01, XC18V02 or XC18V04 PROM.
        Solution
        This problem has been observed when using iMPACT version 8.2 to 7.1i sp2 to program PROMs with markings of "AEN" and running Platform USB cable at 6 MHz or above.
To work around this problem, set the cable speed as follows:
- 3 MHz or lower when using 7.1 or 8.1
- 1.5 MHz or lower when using 8.2 or later Design Environment Tools.
PROMs with "ART" or "BRT" marking will not be affected by this problem and can be run at full speed.
 楼主| hjjnet 发表于 2011-10-10 23:07 | 显示全部楼层
示波器, google一样也不能少,呵呵
lxAPP 发表于 2011-10-10 23:29 | 显示全部楼层
不错啊~~谷歌V5
AutoESL 发表于 2011-10-11 10:11 | 显示全部楼层
google很强大,喜欢
个人签名:Devere Hu E-mail: deverehu@comtech.com.cn Tel: 027-87568667 Mobile  :13545000634 Comtech (Wuhan), Xilinx FAE
170
