*---------------------------------------------------------------------------------------------------------*/ #include <stdio.h> /*---------------------------------------------------------------------------------------------------------*/ /* Include hear file */ /*---------------------------------------------------------------------------------------------------------*/ #include "NUC1xx.h" /*---------------------------------------------------------------------------- Define variable ----------------------------------------------------------------------------*/ static uint32_t TimerCOUN=0; static uint32_t TimerCOUN1=0; static uint32_t TimerCOUN2=0; static uint32_t TimerCOUN3=0; /*---------------------------------------------------------------------------- Function subroutine ----------------------------------------------------------------------------*/ void Delay(uint32_t delayCnt) { while(delayCnt--) { __NOP(); __NOP(); } } uint32_t GetTDR(void) { return TIMER0->TDR; } uint32_t GetTDR1(void) { return TIMER1->TDR; } uint32_t GetTDR2(void) { return TIMER2->TDR; } uint32_t GetTDR3(void) { return TIMER3->TDR; } /*---------------------------------------------------------------------------- Interrupt subroutine ----------------------------------------------------------------------------*/ void TMR0_IRQHandler(void) // Timer0 interrupt subroutine { TIMER0->TISR.TIF =1; TimerCOUN++; } void TMR1_IRQHandler(void) // Timer1 interrupt subroutine { TIMER1->TISR.TIF =1; TimerCOUN1++; } void TMR2_IRQHandler(void) // Timer2 interrupt subroutine { TIMER2->TISR.TIF =1; TimerCOUN2++; } void TMR3_IRQHandler(void) // Timer3 interrupt subroutine { TIMER3->TISR.TIF =1; TimerCOUN3++; } /*---------------------------------------------------------------------------- MAIN function ----------------------------------------------------------------------------*/ int32_t main (void) { //unsigned int TEMP; //uint32_t TEMP; GPIOA->PMD.PMD2=1; //分别设连接LED管脚为,IO模式 GPIOA->PMD.PMD3=1; GPIOA->PMD.PMD4=1; GPIOA->PMD.PMD5=1; NVIC_DisableIRQ(TMR0_IRQn); //Disable Timer0 interrupt outpw(&TIMER0->TCSR ,0 ); //Disable Timer0//清Timer0的中断标志 /* Step 1. Enable and Select Timer clock source */ SYSCLK->CLKSEL1.TMR0_S = 4; //Select 22Mhz for Timer0 clock source SYSCLK->APBCLK.TMR0_EN =1; //Enable Timer0 clock source /* Step 2. Select Operation mode */ TIMER0->TCSR.MODE=1; //定时器工作在周期模式.当中断使能时, //一旦定时器计数器的值(24位递增计数器)等于比较寄存器(TCMPR)的值, //就会触发定时器中断。 /* Step 3. Select Time out period = (Period of timer clock input) * (8-bit Prescale + 1) * (24-bit TCMP)*/ TIMER0->TCSR.PRESCALE=0; // Set Prescale [0~255] TIMER0->TCMPR= 2765;//TICR = 2765; // Set TICR(TCMP) [0~16777215] // (1/22118400)*(0+1)*(2765)= 125.01usec or 7999.42Hz /* Step 4. Enable interrupt */ TIMER0->TCSR.IE = 1; TIMER0->TISR.TIF = 1; //Write 1 to clear for safty NVIC_EnableIRQ(TMR0_IRQn); //Enable Timer0 Interrupt /* Step 5. Enable Timer module */ TIMER0->TCSR.CRST = 1; //Reset up counter TIMER0->TCSR.CEN = 1; //Enable Timer0 TIMER0->TCSR.TDR_EN=1; // Enable TDR function //以下是TIMER1的设置 /* Step 1. Enable and Select Timer clock source */ SYSCLK->CLKSEL1.TMR1_S = 4; //Select 22Mhz for Timer0 clock source SYSCLK->APBCLK.TMR1_EN =1; //Enable Timer0 clock source /* Step 2. Select Operation mode */ TIMER1->TCSR.MODE=1; //定时器工作在周期模式.当中断使能时, //一旦定时器计数器的值(24位递增计数器)等于比较寄存器(TCMPR)的值, //就会触发定时器中断。 /* Step 3. Select Time out period = (Period of timer clock input) * (8-bit Prescale + 1) * (24-bit TCMP)*/ TIMER1->TCSR.PRESCALE=20; // Set Prescale [0~255] TIMER1->TCMPR= 2765;//TICR = 2765; // Set TICR(TCMP) [0~16777215] // (1/22118400)*(0+1)*(2765)= 125.01usec or 7999.42Hz /* Step 4. Enable interrupt */ TIMER1->TCSR.IE = 1; TIMER1->TISR.TIF = 1; //Write 1 to clear for safty NVIC_EnableIRQ(TMR1_IRQn); //Enable Timer0 Interrupt /* Step 5. Enable Timer module */ TIMER1->TCSR.CRST = 1; //Reset up counter TIMER1->TCSR.CEN = 1; //Enable Timer0 TIMER1->TCSR.TDR_EN=1; // Enable TDR function //以下设TIMER2的设置 /* Step 1. Enable and Select Timer clock source */ SYSCLK->CLKSEL1.TMR2_S = 4; //Select 22Mhz for Timer0 clock source SYSCLK->APBCLK.TMR2_EN =1; //Enable Timer0 clock source /* Step 2. Select Operation mode */ TIMER2->TCSR.MODE=1; //定时器工作在周期模式.当中断使能时, //一旦定时器计数器的值(24位递增计数器)等于比较寄存器(TCMPR)的值, //就会触发定时器中断。 /* Step 3. Select Time out period = (Period of timer clock input) * (8-bit Prescale + 1) * (24-bit TCMP)*/ TIMER2->TCSR.PRESCALE=10; // Set Prescale [0~255] TIMER2->TCMPR= 2765;//TICR = 2765; // Set TICR(TCMP) [0~16777215] // (1/22118400)*(0+1)*(2765)= 125.01usec or 7999.42Hz /* Step 4. Enable interrupt */ TIMER2->TCSR.IE = 1; TIMER2->TISR.TIF = 1; //Write 1 to clear for safty NVIC_EnableIRQ(TMR2_IRQn); //Enable Timer0 Interrupt /* Step 5. Enable Timer module */ TIMER2->TCSR.CRST = 1; //Reset up counter TIMER2->TCSR.CEN = 1; //Enable Timer0 TIMER2->TCSR.TDR_EN=1; // Enable TDR function //以下设TIMER3的设置 /* Step 1. Enable and Select Timer clock source */ SYSCLK->CLKSEL1.TMR3_S = 4; //Select 22Mhz for Timer0 clock source SYSCLK->APBCLK.TMR3_EN =1; //Enable Timer0 clock source /* Step 2. Select Operation mode */ TIMER3->TCSR.MODE=1; //定时器工作在周期模式.当中断使能时, //一旦定时器计数器的值(24位递增计数器)等于比较寄存器(TCMPR)的值, //就会触发定时器中断。 /* Step 3. Select Time out period = (Period of timer clock input) * (8-bit Prescale + 1) * (24-bit TCMP)*/ TIMER3->TCSR.PRESCALE=2; // Set Prescale [0~255] TIMER3->TCMPR= 2765;//TICR = 2765; // Set TICR(TCMP) [0~16777215] // (1/22118400)*(0+1)*(2765)= 125.01usec or 7999.42Hz /* Step 4. Enable interrupt */ TIMER3->TCSR.IE = 1; TIMER3->TISR.TIF = 1; //Write 1 to clear for safty NVIC_EnableIRQ(TMR3_IRQn); //Enable Timer0 Interrupt /* Step 5. Enable Timer module */ TIMER3->TCSR.CRST = 1; //Reset up counter TIMER3->TCSR.CEN = 1; //Enable Timer0 TIMER3->TCSR.TDR_EN=1; // Enable TDR function while(1) { Delay(10); //TEMP = GetTDR(); //Get value of up counter if (TimerCOUN>1000) { GPIOA->DOUT ^= BIT2; TimerCOUN=0; } //TEMP1 = GetTDR1(); //Get value of up counter if (TimerCOUN1>1000) { GPIOA->DOUT ^= BIT3; TimerCOUN1=0; } //TEMP2 = GetTDR2(); //Get value of up counter if (TimerCOUN2>1000) { GPIOA->DOUT ^= BIT4; TimerCOUN2=0; } //TEMP3 = GetTDR3(); //Get value of up counter if (TimerCOUN3>1000) { GPIOA->DOUT ^= BIT5; TimerCOUN3=0; } } } 程序打包:
收藏0 举报
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
等级类勋章
发帖类勋章
时间类勋章
人才类勋章
2404
7008
68
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
