一个资源超级多的单片机,大家看看好用不?
2040|4
 楼主| yejingang 发表于 2011-10-19 14:24 | 显示全部楼层 |阅读模式
1.1 Features
High Performance 8051 μC Core
● Instruction set compatible with standard 8051
● High performance processor architecture that executes instructions in one to eight clocks, speed up to 33 MHz
Memory
● 64/4K bytes of program flash with In-System Programming (ISP) capability
● 0/60K bytes of program flash with In-Application Programming (IAP) and ISP capability
● 1280 bytes of data RAM
- 256 bytes internal RAM
- 1K bytes auxiliary RAM (AUXRAM)
● FLASH memory with security protection
● Hardware In-System Programming (ISP) without boot code
Digital Peripherals
● Five 8-bit I/O ports
- Configurable I/O with quasi-bidirectional, input, push-pull, and open-drain modes
- 5 V tolerant I/O
● Three 16-bit timers/counters (Timer0/1/2)
● Full-duplex serial port (UART)
● Single Master and Slave I2C interface for external device communication
● 4-channel Programmable Counter Array (PCA) with PWM, Capture and Compare polarity setting for each channel
wzf3151 发表于 2011-10-19 17:46 | 显示全部楼层
没感觉超多
dong_abc 发表于 2011-10-19 18:29 | 显示全部楼层
楼主还活在旧社会。
ddtx 发表于 2011-10-19 20:39 | 显示全部楼层
没感觉很厉害啊,呵呵,很多单片机都比它强
wisology 发表于 2011-10-19 21:14 | 显示全部楼层
落后了
