[STM32F1] 读取max6675温度
3339|13
 楼主| aa911 发表于 2019-5-1 12:24 | 显示全部楼层 |阅读模式
得到的温度波动很大,不准确,串口打印的数据如图所示,哪里出了问题?
main.c
  1. int main(void)
  3.         char key_code = 8;
  4.         float t;
  5.
  6.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
  7.         uart_init(115200);
  8.         delay_init();
  9.         LED_Init();
  10.         Key_User_Init();
  11.         Exti_User_Init();
  12.         TIM3_User_Init(9999, 7199);//频率10KHz,重装载值9999+1 ms
  13.         max6675_init();
  14.
  15.                 while(1)
  16.                 {
  17.                         delay_ms(500);
  18.                         t = max6675_readTemperature();
  19.                         printf("the temperature is:%.2f\n",t);
  20.                         printf("\n");
  21.
  22.                 }
  23. }
max6675.c
  1. #include "max6675.h"
  2. #include "sys.h"
  3. #include "delay.h"
  4. #include "usart.h"
  5. /*max6675初始化程序*/
  6. void max6675_init(void){
  7.     GPIO_InitTypeDef GPIO_InitStructure;
  8.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE );//PORTB时钟使能
  9.         //CS
  10.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
  11.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;  //PB7推挽输出  GPIO_Mode_AF_PP
  12.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  13.         GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化GPIOB8
  14.         //SO
  15.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  16.         GPIO_InitStructure.GPIO_Mode =GPIO_Mode_IPU;//PB9上拉输入
  17.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  18.         GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化GPIOB7
  19.         //SCK
  20.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  21.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;  //PB8复用推挽输出  GPIO_Mode_AF_PP
  22.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  23.         GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化PB11
  24. }
  25. u16 max6675_readRawValue(void)
  26. {
  27.   u16 tmp=0;
  28.   u16 i;
  29.   MAX6675_CS_L;//cs低
  30.   /*按位读取电平*/
  31.   for(i=0;i<16;i++)
  32.   {
  33.                   /*创建一个沿,按沿读取PB7的端口电平*/
  34.                 MAX6675_CK_H;
  35.                 delay_us(10);
  36.                 if(MAX6675_SO)
  37.                 {
  38.                         tmp|=0x0001;
  39.                         printf("tmp%d---:%d\n",i,tmp);/*这是为了检查错误时按位打印每个数*/
  40.                 }
  41.
  42.                 tmp<<=1;//按位左移
  43.             MAX6675_CK_L;
  44.                 delay_us(10);
  45.    }
  46.   MAX6675_CS_H;//cs高
  47.   if (tmp&0X04)
  48. {
  49.     tmp = 0; //未检测到热电偶
  50.         // printf("未检测到热电偶\n");//测试用
  51.   }
  52.   else
  53. {
  54.         tmp<<=1;//去掉D15位
  55.         tmp>>=4;//去掉D0、1、2位
  56.   }
  57.         return tmp;
  58. }
  59. float max6675_readTemperature(void)
  60. {
  61.         u16 d;
  62.         float i,S;
  63.         S=2.142857;//实验数,用温水和热水 环境测得的一个实际差量
  64.         delay_ms(300);
  65.         d=max6675_readRawValue();
  66.         i=d*1023.75/4095/S;
  67.     return i;
  68. }
wangjiahao88 发表于 2019-5-1 16:13 | 显示全部楼层
请问一下 这个准吗?
读数准吗?
内部是靠什么做的滤波啊?
 楼主| aa911 发表于 2019-5-1 17:14 | 显示全部楼层
请问一下 这个准吗?
读数准吗?
从打印出来的数据看,读数不准,不知道代码哪里出了问题。
 楼主| aa911 发表于 2019-5-3 12:15 | 显示全部楼层
自己顶一下
dsyq 发表于 2019-5-4 09:36 | 显示全部楼层
用SPI读取吧!
我用F1的SPI读“没问题”,但用F072的SPI读出的数始终有问题。
感觉有十分之一的数据会变得离谱,不知是否该软件滤掉。
 楼主| aa911 发表于 2019-5-4 12:15 | 显示全部楼层
用SPI读取吧!
我也想用SPI,但是这个电路就这样了,而且实际项目用的MCU就是F072
 楼主| aa911 发表于 2019-5-4 12:24 | 显示全部楼层
可以看看你的代码吗?
dsyq 发表于 2019-5-4 13:23 | 显示全部楼层
可以看看你的代码吗?
extern SPI_HandleTypeDef hspi1;
uint16_t max6675_readRawValue(void)
  uint8_t rx[2];
        HAL_StatusTypeDef halStatus;
        uint16_t tmp;
        HAL_GPIO_WritePin(GPIOA,GPIO_PIN_4,0);
        HAL_Delay(1);
        halStatus=HAL_SPI_Receive(&hspi1,(uint8_t*)&rx[0],1,100);
        HAL_Delay(1);
        halStatus=HAL_SPI_Receive(&hspi1,(uint8_t*)&rx[1],1,100);
        HAL_GPIO_WritePin(GPIOA,GPIO_PIN_4,1);
        if(halStatus!=HAL_OK)
                return 0;
  tmp=rx[0]; //read MSB
  tmp<<= 8;
  tmp|=rx[1]; //read LSB
  if (tmp & 4)
    tmp = 4095;
  else
    tmp = tmp >> 3;
  return tmp;
  return (max6675_readRawValue() * 1024.0 / 4096);
#ifndef __MAX6675_H
#define __MAX6675_H
#include "main.h"
#define MAX6675_CS1_CLK   RCC_APB2Periph_GPIOA
#define MAX6675_CS1_PORT  GPIOA
#define MAX6675_CS1_PIN   GPIO_Pin_4
uint8_t max6675_readWriteByte(void);
uint16_t max6675_readRawValue(void);
float max6675_readTemperature(void);
#endif
dsyq 发表于 2019-5-4 13:25 | 显示全部楼层
换个评估板试试吧!
我调试CAN收发和MAX6675,用103R8T6都可以,用072R8T6与103C8T6都不行.
 楼主| aa911 发表于 2019-5-4 21:18 | 显示全部楼层
换个评估板试试吧!
我调试CAN收发和MAX6675,用103R8T6都可以,用072R8T6与103C8T6都不行. ...
好 的,谢谢,我试试看
maximQ820270087 发表于 2020-4-15 11:58 | 显示全部楼层
具体源程序如下 :
# include < reg51. h >
# include < absacc. h >
sbit SO= P1.1;
sbit CS= P1.2;
sbit SCK= P1.3;
unsigned char resulth ,resultl ;
unsigned char flag;
void read(void)
unsigned char i ;
resulth = resultl = 0 ;
SC K = 0 ;
CS = 0 ;
SC K = 1 ;
SCK= 0 ; / / 输出数据 D15
SCK= 1
for(i=4;i> =1;i- - ) //读取转换结果的高四位
{ SCK=0;
resulth^0 = SO ; / / 读取 SO 输出的字节
resulth=resulth< <1;  //数据左移
SCK=1;
for(ℹ=8;i>=1;i--)//读取转换结果的低8位
SC K = 0 ;
resultl^0 = SO;
resultl = resultl < < 1 ;
SC K = 1 ;
SC K = 0 ;
flag = SO ; / / 读取断偶标志
SC K = 1 ;
SCK= 0 ; / / 输出数据 D0
maximQ820270087 发表于 2020-6-9 11:51 | 显示全部楼层
MAX31855
冷端补偿热电偶至数字输出转换器
高精度热电偶数字转换器IC,
【硅天下备样信息】
MAX31855KASA+T    -200°C to +1350°C     8SO
MAX31855JASA+T     -40°C to +750°C      8SO
MAX31855NASA+T    -200°C to + 1300°C    8SO
MAX31855SASA+T     -50°C to +1600°C     8SO
MAX31855TASA+T     -250°C to +400°C    8SO
MAX31855EASA+T     -40°C to +900°C     8SO
MAX31855RASA+T     -50°C to +1770°C    8SO
【MAX31855关键特性】
冷端补偿
14位、0.25°C分辨率
转换器的温度分辨率为0.25°C,
温度读数为-270°C 至+1800°C,
对于K型热电偶,在-200°C至+700°C温度范围内,保持±2°C精度。
提供K、J、N、T和E型热电偶器件版本
简单的SPI兼容接口(只读)
检测热电偶对GND或VCC短路
检测热电偶开路
应用
电器设备
汽车
HVAC
工业
【MAX31856关键特性】
提供高精度热电偶温度读数
包括8种热电偶的自动线性度修正
±0.15%(最大值,-20°C至+85°C)热电偶满幅和线性度误差
19位、0.0078125°C热电偶温度分辨率
内置冷端补偿,将系统元件数量降至最少
转换器的温度分辨率达0.0078125°C,
允许读取高达+1800°C以及低至-210°C(取决于热电偶类型)的温度读数
±0.7°C(最大值,-20°C至+85°C)冷端补偿精度
±45V输入保护,系统性能可靠
简化系统故障管理和诊断
检测热电偶开路
过温和欠温故障检测
50Hz/60Hz噪声抑制滤波,提高系统性能
14引脚TSSOP封装
maximQ820270087 发表于 2020-6-9 11:52 | 显示全部楼层
推荐MAX31855  31856 都可以 带自动补偿的,56还自带抗干扰电路,线性优化,性价比 比6675高很多,max6675要停产了哦
