[菜农助学交流]
请指点寄存器操作定时器0的计数方式测脉冲宽度
2858|1
iam80|  楼主 | 2011-10-26 20:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请高人指点下怎样配置寄存器来操作定时器0的计数方式测脉冲宽度(调用函数库很影响速度在10US左右,所以要直接配置寄存器来操作),我按以下配置后无法使用,仿真时出现*** error 65: access violation at 0x4001000C : no 'read' permission
#include <stdio.h>
#include "NUC122.h"
#include "DrvGPIO.h"
void Delay(uint32_t delayCnt)
    while(delayCnt--)
        __NOP();
        __NOP();
uint32_t GetTDR(void)
    return  TIMER0->TDR;
int32_t main (void)
    uint32_t TEMP=0;
    UNLOCKREG();
    SYSCLK->PWRCON.XTL12M_EN = 1;
    Delay(5000);
    LOCKREG();
TIMER0->TCSR.DBGACK_TMR = 0;
    NVIC_DisableIRQ(TMR0_IRQn); //Disable TIMER0 interrupt
    outpw(&TIMER0->TCSR ,0 );   //Disable TIMER0
    /* Step 1. Enable and Select Timer clock source */
    SYSCLK->CLKSEL1.TMR0_S = 0; //Select =4(22Mhz) =0(12MHZ) for TIMER0 clock source
    SYSCLK->APBCLK.TMR0_EN =1;  //Enable TIMER0 clock source
    /* Step 2. Select Operation mode */
    TIMER0->TCSR.MODE=1;        //Select periodic mode for operation mode
    /* Step 3. Select Time out period = (Period of timer clock input) * (8-bit Prescale + 1) * (24-bit TCMP)*/
    TIMER0->TCSR.PRESCALE=1;    // Set Prescale [0~255]
    TIMER0->TCMPR = 300000;        // Set TCMPR [0~16777215]
                                // (1/12000000)*(1+1)*(3000000)= 500ms
    /* Step 4. Enable interrupt */
  //  TIMER0->TCSR.IE = 1;
  //  TIMER0->TISR.TIF = 1;       //Write 1 to clear for safty
  //  NVIC_EnableIRQ(TMR0_IRQn);  //Enable TIMER0 Interrupt
    /* Step 5. Enable Timer module */
    TIMER0->TCSR.CRST = 1;      //Reset up counter
    TIMER0->TCSR.CEN = 1;       //Enable TIMER0
    TIMER0->TCSR.TDR_EN=1;      // Enable TDR function
    Delay(1000);
    while(1)
    TEMP = GetTDR();        //Get value of up counter
iam80|  楼主 | 2011-10-27 18:16 | 只看该作者
请高人
高人在哪里啊。。。。。。。。。。
