串口中断通讯求解
3073|4
 楼主| a38128895 发表于 2011-10-31 14:45 | 显示全部楼层 |阅读模式
我用STM32固件库3.5开发,设置串口波特率是9600,为什么PC上接收需要设定成19200才能正确接收到?
程序:
int main(void)
  /* System Clocks Configuration */
  RCC_Configuration();
  /* NVIC configuration */
  NVIC_Configuration();
  /* Configure the GPIO ports */
  GPIO_Configuration();
  USART_Configuraton();
  while (1)
  * @brief  Configures the different system clocks.
  * @param  None
  * @retval None
void RCC_Configuration(void)
  /* Enable GPIO clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1| RCC_APB2Periph_AFIO, ENABLE);
  * @brief  Configures the different GPIO ports.
  * @param  None
  * @retval None
void GPIO_Configuration(void)
  /* Configure USAR1 Rx as input floating */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /* Configure USAR1 Tx as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  /*配置LED*/
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_2 | GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_7;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
   GPIO_Init(GPIOD, &GPIO_InitStructure);
  * @brief  Configures the nested vectored interrupt controller.
  * @param  None
  * @retval None
void NVIC_Configuration(void)
  NVIC_InitTypeDef NVIC_InitStructure;
  /* Configure the NVIC Preemption Priority Bits */
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
  /* Enable the USART1 Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;   //通道设置为串口1中断
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;   //中断占先等级0
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;          //中断响应优先级0
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;             //打开中断
  NVIC_Init(&NVIC_InitStructure);                             //初始化
void USART_Configuraton(void)
    USART_InitTypeDef USART_InitStructure;
    USART_InitStructure.USART_BaudRate = 9600;
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;
    USART_InitStructure.USART_StopBits = USART_StopBits_1;
    USART_InitStructure.USART_Parity = USART_Parity_No;
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
    USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
    /* Configure USARTy */
    USART_Init(USART1, &USART_InitStructure);
    /* Enable USARTy Receive and Transmit interrupts */
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
    //USART_ITConfig(USART1, USART_IT_TXE, ENABLE);
    /* Enable the USARTy */
    USART_Cmd(USART1, ENABLE);
 楼主| a38128895 发表于 2011-10-31 14:52 | 显示全部楼层
用的是STM32107VC芯片,晶体25M
请如实填写 发表于 2011-10-31 15:17 | 显示全部楼层
库函数里面的波特率好像是在外接8MHz的情况下计算的
外接晶振4~16MHz 我记得好像是
你可以查下手册
接其他晶振自己算下就可以了
shuaibaobao 发表于 2011-11-27 22:04 | 显示全部楼层
添加过了,还是有问题啊,呵呵。
