51模拟iic读取24c16的数据总是0xff,求解。
1881|8
yzcook|  楼主 | 2019-5-28 19:34 | 显示全部楼层 回帖奖励 |倒序浏览 |阅读模式
简单的模拟,但是读取的数据总是0xff,请教各位。iic的函数应该不会有问题,因为是之前学开发板的标准程序 复制过来的。
但是怎么改都是0xff
已经改了两天了。还是这样。
麻烦各位帮忙解答一下 谢谢
void main()
    unsigned char dat;
                Init_Uart();
                E2WriteByte(0x02,0x01)  ;
    dat = E2ReadByte(0x02);
                SendByte(dat);
    while (1);
unsigned char E2ReadByte(unsigned char addr)
    unsigned char dat;
    I2CStart();
    I2CWrite(0x50<<1);
    I2CWrite(addr);
    I2CStart();
    I2CWrite((0x50<<1)|0x01);
    dat = I2CReadNAK();
    I2CStop();
    return dat;
void E2WriteByte(unsigned char addr, unsigned char dat)
    I2CStart();
    I2CWrite(0x50<<1);
    I2CWrite(addr);
    I2CWrite(dat);
    I2CStop();
void I2CStart()
    I2C_SDA = 1;
    I2C_SCL = 1;
    I2CDelay();
    I2C_SDA = 0;
    I2CDelay();
    I2C_SCL = 0;
void I2CStop()
    I2C_SCL = 0;
    I2C_SDA = 0;
    I2CDelay();
    I2C_SCL = 1;
    I2CDelay();
    I2C_SDA = 1;
    I2CDelay();
bit I2CWrite(unsigned char dat)
    bit ack;
    unsigned char mask;
    for (mask=0x80; mask!=0; mask>>=1)
        if ((mask&dat) == 0)
            I2C_SDA = 0;
        else
            I2C_SDA = 1;
        I2CDelay();
        I2C_SCL = 1;
        I2CDelay();
        I2C_SCL = 0;
    I2C_SDA = 1;
    I2CDelay();
    I2C_SCL = 1;
    ack = I2C_SDA;
    I2CDelay();
    I2C_SCL = 0;
    return (~ack);
unsigned char I2CReadNAK()
    unsigned char mask;
    unsigned char dat;
    I2C_SDA = 1;
        I2CDelay();
        I2C_SCL = 1;
        if(I2C_SDA == 0)
            dat &= ~mask;
        else
            dat |= mask;
        I2CDelay();
        I2C_SCL = 0;
    I2C_SDA = 1;
    I2CDelay();
    I2C_SCL = 1;
    I2CDelay();
    I2C_SCL = 0;
    return dat;
unsigned char I2CReadACK()
    unsigned char mask;
    unsigned char dat;
    I2C_SDA = 1;
        I2CDelay();
        I2C_SCL = 1;
        if(I2C_SDA == 0)
            dat &= ~mask;
        else
            dat |= mask;
        I2CDelay();
        I2C_SCL = 0;
    I2C_SDA = 0;
    I2CDelay();
    I2C_SCL = 1;
    I2CDelay();
    I2C_SCL = 0;
    return dat;
