void PWR_EnterSTOPMode(uint32_t PWR_Regulator, uint8_t PWR_STOPEntry) { uint32_t tmpreg = 0; /* Check the parameters */ assert_param(IS_PWR_REGULATOR(PWR_Regulator)); assert_param(IS_PWR_STOP_ENTRY(PWR_STOPEntry)); /* Select the regulator state in STOP mode ———————————*/ tmpreg = PWR->CR; /* Clear PDDS and LPDSR bits */ tmpreg &= CR_DS_MASK; /* Set LPDSR bit according to PWR_Regulator value */ tmpreg |= PWR_Regulator; /* Store the new value */ PWR->CR = tmpreg; /* Set SLEEPDEEP bit of Cortex-M0 System Control Register */ SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk; /* Select STOP mode entry ————————————————–*/ if(PWR_STOPEntry == PWR_STOPEntry_WFI) { /* Request Wait For Interrupt */ __WFI(); } else { /* Request Wait For Event */ __WFE(); } /* Reset SLEEPDEEP bit of Cortex System Control Register */ SCB->SCR &= (uint32_t)~((uint32_t)SCB_SCR_SLEEPDEEP_Msk); }
